Question about Proform Exercise & Fitness
My Proform 730 worked great last spring when it was put away for the summer but now the belt pulses repeatedly for about 1 second on and then off. Any thoughts?
  • 42 Answers
Hi, do you have the instruction booklet if so check if your treadmill uses oil. alot of treadmills use oil just like a car. and if it dosent get some wd40 spray and with the power off give the motor a spray and the rollers. the same thing happened to me and i sprayed the motor every moving part i could see. then i left the treadmill on without standing on it for half an hour and its been working better than before. please note wd40 spray can smell abit so open the windows. hope i have helped!
Posted on Nov 11, 2010
Pro form 320x treadmill stops working when you get on it
How can I get my Proform 320X treadmill from stopping a ...
www.shopyourway.com > Manage My Life > Questions
How can I get my Proform 320X treadmill from stopping a few seconds after starting? ... -why-does-my-proform-treadmill-belt-only-move-a-few-seconds-stops
ProForm Treadmill 320x User's Guide ' ManualsOnline.com
fitness.manualsonline.com > ... > ProForm Treadmill
ProForm 320x Treadmill User Manual. Page 1. Page 2. Page 3. Page 4. Page 5. Page 6. Page 7. Page 8. Page 9. Page 10. Page 11. Page 12. Page 13.
Nov 03, 2015 | Exercise & Fitness
Unit doesnt cut on.
proform 730 performance treadmill was working just fine..son left for Air Force in May last yr.tried to use it today and electricals wont turn on..
Jul 05, 2012 | Proform 730 Folding Treadmill Model...
When i step on belt it stops moving
do the wheels lock up too that push the belt? if the wheels still spin than the belt might be too loose if that is the case look for an adjustment spot for the belt.
Jun 05, 2012 | Proform 730 Folding Treadmill Model...
Proform 730 treadmill,rusted screws won't remove to replace walking belt
Use WD40. Or go to a nearby hardware store an purchase a rust remover. Aply either one and wait for a bit. Then remove screws.
May 06, 2012 | Proform Exercise & Fitness
I need a wiring diagram for a pro form 730 treadmill
There are many different kinds of Proform 730 models. Please search for or find your specific Proform model here and look at the parts list for the accurate wiring diagram for your model.
Oct 20, 2011 | Proform 730 Folding Treadmill Model...
On my Sears ProForm 730 treadmill, I cannot make the belt move to the right (it is rubbing on the left side) by turning the left-side back belt screw clockwise (in any amount). The belt is walking back...
The belt does not need to be replaced more than likely. The problem is probably because that adjustment bolt is stripped out causing it loosen and keeping it over on that side. ProForm sells star washers that help them stay steady and not slip out. I would call them and ask for a couple of star washers and a new adjustment bolt for that left side.
Aug 16, 2010 | Proform 730 Folding Treadmill Model...
I am looking for a user manual for proform elleptical xp 730
To get an owners manual you can one of two things. First, go to
www.iconservice.com in the manuals link. There you can type your
model number/model name found on your machine usually on the bottom of bikes and ellipticals, and underneath the belt when the machine is in spacesaver position on treadmills. It will give you a PDF version that you can download for free. You can also call for a
hardcopy but it will cost around $20 with tax and shipping. The
number is 1-800-999-3756.
Aug 07, 2010 | Proform Exercise & Fitness
Belt is off alignment
If the walking belt is off-center, first remove the key and UNPLUG THE POWER CORD. If the walking belt has shifted to the left, use the allen wrench to turn the left rear roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the bolt counterclockwise 1/2 of a turn. Be careful not to over tighten the walking belt. Then, plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is centered.
May 31, 2010 | Proform 730 Folding Treadmill Model...
How do you adjust a belt on a Proform 385X. It is
If the walking belt is off-center, first remove the keyand UNPLUG THE POWER CORD. If the walking belt has shifted to the left, use the hex key to turn the left rear roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the left bolt counterclockwise 1/2 of a turn. Be careful not to over tighten the walking belt. Then, plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is centered
May 17, 2010 | Proform Exercise & Fitness
How do i change the belt on my 2005 jeep wrangler?
under the hood if you look carefully one of the pulleys is spring loaded and there is a square hole it, u put 3/8 ratchet in hole and pry away from belt to loosen take off belt and care fully look at where it runs and put new one in same way last u pry pulley again and put belt over tension pulley last. another choice is ask at parts store and they will likely show you pulley and if u purchase a chiltons repair manual for your cars for around $25 it covers most basic repairs and has steps and diagrams to help you fix many things great book to have
Jul 08, 2009 | 2005 Jeep Wrangler
Exercise & Fitness Logo
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
