Question about Sony Cyber-shot DSC-H9 Digital Camera
My flash will not go off the little arrow has a red slash through it. when i try to change it, it won't let me,says the setting cannot be changed
    Brigadier General:
  • 11,967 Answers
In some modes, the flash cannot be changed. What mode are you in?
Posted on Nov 11, 2010
How do i get the flashed turned on
First, check to make sure you're not in the macro mode. There's a slide switch on the end of the camera, near the SD card slot. Slide the switch away from the flower toward the mountain to take it out of macro mode. The flash won't fire in macro mode.
Then, if the flash still doesn't fire, take a look at the flash mode. Press the up-arrow button to bring up the flash menu. If it's currently set in the lightning-bolt-in-a-circle-with-a-slash-through-it symbol, you've got the flash turned off. Set it to the lightning-bolt-and-"A" for automatic flash or the lightning-bolt for forced flash.
If the flash still doesn't fire, then it's broken.
Sep 10, 2011 | Vivitar ViviCam 5024 Digital Camera
I have a easy share c533 and thought it had capability of the flash NOT going off - apparently i am hitting the red eye button - it looks like a flash zaggy arrow pointing down - what is this where is the...
The lightning bolt is the fill-flash symbol. Red-eye reduction is the eyeball symbol. Flash off is the lightning bolt in a circle with a slash through it. There's also an auto flash mode, represented by a lightning bolt with the letter "A".
Repeatedly press the flash button on the top of the camera to cycle through the flash modes.
Dec 11, 2010 | Cameras
Hello, I can't turn off the flash on my nikon coolpix L20. Can anyone help me out?
In the shooting mode, press up-arrow on the multiselector (marked with a lightning bolt). Select the no-flash icon (lightning bolt in a circle with a slash through it), then press OK.
Oct 31, 2010 | Nikon COOLPIX L20 Digital Camera
How do i turn OFF the flash on my kodak C643? I press the flash button on top, but, flash still goes when I take a pic
You may have to press the flash button several times
there are several settings
Flash on, Flash on auto, anti red-eye and flash off.
Sooooooooo.
Press the button and watch the screen on the back, if theres no menu when you press once, look for a small icon, it should change each time you press the button. You want the one the looks like a lightning bolt with a slash across it.
You can download the instructions from here:-
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/urg00531/C643_C603_GLB_en.pdf
for free.
Jun 21, 2010 | Kodak EasyShare C643 Digital Camera
How do u turn off the flash on the olympus fe-170? im going to a clapton concert tonite and i need the flash to be set to off i tried everything and i cant turn it off....please help!...thanks!
Press Right-arrow (marked with the lightning bolt) repeatedly to select the flash mode. In this case, you want the lightning bolt inside a circle with a slash through it, indicating "no flash".
After the concert, don't forget to set it back to Auto, or the flash will never fire again :-)
Feb 25, 2010 | Olympus FE-170 Digital Camera
Ink red light on . which colour is out?
When red ink light flashes - one or more ink cartridges is low. When you print, a message on your screen will tell you which one(s).
When red ink light remains on - one or more ink cartridges is empty. When you try to print, a message on your screen will tell you which one(s).
Furthermore: When following the procedure for installing a new cartridge, if the red ink light was on or flashing, pressing the ink button will cause the carriage to stop with the cartridge that needs replacing under the "ink out mark" (ink droplet with a slash through it).
Jan 08, 2010 | Epson Stylus C66 Inkjet Printer
Canon mv 830, grey horizontal lines across screen when replaying and a flashing red symdol which looks like a bowl with a slash across it and an arrow pointing down into it
Hi - I have just managed to fix this issue of grey stripes across my screen on playback on my canon mv800 by going into the audio format settings in the menu and changing the format from 12 bit to 16 bit - good luck everyone else! Sharon
Jun 12, 2009 | Canon MV800i Mini DV Digital Camcorder
Black screen on camcorder
I think you have two different issues here. The black screen may be due to a CCD failure. Canon has a worldwide service notice regarding this issue, and will repair your unit at no cost if they determine this is the problem (it sounds like it is).
The little red symbol indicates your backup battery (or date/time battery) CR1616 needs to be replaced. It is located behind a small square panel which you can see to the left of the menu buttons when you open the LCD panel.
Dec 08, 2008 | Canon ZR70MC Mini DV Digital Camcorder
Olympus Stylus 410
try to clean the pad using water damped cotton if you are techie, professional fix is needed if you're not.
Sep 07, 2007 | Olympus Stylus 410 / ? 410 Digital Camera
Sony Cyber-shot  DSC-H9 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
