Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
We have Honeywell W7760C Plant Controller has fast blinking on LED light, how can that be solved.
LED puck lights blink fast. Why
Depends on how fast you're seeing. Cheap LED power supplies are what we call, "half wave". This means that they only work on half the AC cycle, and do blink 25 or 30 times per second (depending on where you are). If that's what you're seeing, it would be normal.
If they're blinking at some other rate, do you have them on a dimmer? Some dimmers don't get along well with LED power supplies, and blink at 1 to 10 per second.
Sep 08, 2015 | Televison & Video
What resistors do I need to fit LED tail lights to a 2012 PX Ford ranger ute
fast blinking light tells you that one of the bulbs is bad. replace the bad one and it should be fixed not need for resisters EVER
Jan 05, 2015 | Ford Cars & Trucks
What does a red light and a flashing yeallow light mean on a honeywell gsm radio
RED FAULT ON - No contact with network.
OFF- Normal.
SLOW BLINK - Loss of communication with the panel (ECP fault).
FAST BLINK - No network contact AND loss of communication with the panel.
YELLOW MESSAGE ON - Message transmission pending.
QUICK PERIODIC BLINK - Normal
FAST BLINK - Message waiting for network ACK.
SLOW BLINK - In unison with green LED - Registration in progress.
Hope this helps, all of this was found in the manual :P
http://site.geoarm.com/pdfs/Honeywell/gsmvlp-install-guide.pdf
Jul 21, 2014 | Honeywell Ademco / GSMVLP-KT - GSM Radio...
Installed LED turn signal lights. Turn signal now blinks too fast. Solution
Hi Dennis
the indicator blinking fast because the LED use less AMP then ordinary bulb, I know an old trick to solve this problem is to connect an extra bulb to each rear indicator by running an extra wires from the light connector to an extra bulb holder.
Good Luck
Mar 02, 2014 | Cars & Trucks
Led blinks three times and no ignition.
ignitor is bad or board not feeding it power or air switch is bad or draft motor not running fast enough
Nov 02, 2013 | Carrier Honeywell Gas Furnace Control...
Honeywell WV8840B1109 temp control valve on water heater. Status light @ 4 blinks between 3 seconds indicating "high temperature shutdown" even though lighting pilot with water cold. .
II have exactly the same problem: Honeywell WV8840B1109 temp
control valve on water heater. Pilot is on, but the burner won't
no matter how high I turn the temperature knob. Status light blink
4, which by the controller is "high temperature shutdown" and has
nothing to do with the problem. The real problem is that the
computer chip in the controller has gone bad. Problem is solved by
changing a new gas control valve/thermostat. The old Honeywell
control valve uses pure mechanical stuff and was very reliable,
almost never has a problem. I don't understand why they switch to
this new electrical one which use the tiny voltage generated by
the thermopile to run, easy to break, because of the electric
chips, and is more expensive. The only reason I can think of is
that they want to get more money from our pocket.
Nov 01, 2012 | Water Heaters
LED LIGHT BLINKS 7 TIMES FAST OVER & OVER
Call philips to talk you through the reset option or arrange a replacement it may have a higher warrenty
Dec 21, 2011 | Philips Televison & Video
YT-9014A1 will not sync
i just sync both of mine to my ps3 it was giving me difficult at first, but i noticed the when u first put in ur usb wireless thing it starts to blink really fast and when u push the p3 button on the controller twice it flashes really fast. so i took out the wireless usb thing then put it back in so the light on it would be flashing really fast like it was searching for somthing, then press the p3 button twice to make the lights flash really fast aswell so it will sync with it. Thats how i got both of my controllers synced we my ps3. the lights on on the wireless usb thing and the controller lights must be flashing fast at the same time to sync.
Mar 06, 2010 | Sony Wireless Controller for PS3
PS3 Controller mult lights lit on controller
IM not sure but on the main menu of the ps3 go to settings then to accesorries settings then go to reassign controllers then if its on another number than 1 put it to 1
Nov 29, 2009 | Sony Video Game Consoles & Games
Heating & Cooling Logo
51 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
