Question about Brother MFC-8840D All-In-One Laser Printer
76 error on brother 8840d
I need to know how to clear this error after replacing the fuser
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 56 Answers
Usually this is a bad fuser. Replace the fuser with part number: LM2579001
Posted on Jan 15, 2009
The error code should reset after replacment. If it did not you may have a bad fuser or all connectors to the fuser are not connected or are bad or you may have a bad logic or power pcb.
Hope that helps...
Posted on Jun 17, 2008
Machine error 6D
I looked that error "6D" and could not find anything.
Although there is a error 6E that denotes a hardware problem with the machine.
Mar 12, 2010 | Brother MFC-8840D All-In-One Laser Printer
Brother DCP1200 Machine Error 76
This refers to a error with the fuser temperature you need it repaired by a service technician. Parts can be as little as $15 for the thermistor sensor or as much as $100 for a new fuser.
Jan 04, 2010 | Brother DCP-1200 Laser Printer
Machine error 76 is appearing
Error 76 is a fuser error, you can try going in and out of service mode, press the following key combination all within 2 seconds " features or function , * , 2 , 8 , 6 , 4 , " if done fast enough the all the lights willl be flashing. Them exit out of service by pressing 99. If the error returns after startup the fuser will have to be replaced.
Oct 28, 2009 | Brother IntelliFAX 4100 Laser Fax
Brother 8840D
Error 6B:
This is a heater warming up timeout error.
Heater does not reach 100 degree C in 15 seconds.
Service manual says that either the Termistor Assy. or the Halogen lamp needs to be replaced.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 05, 2009 | Brother MFC-8840D All-In-One Laser Printer
Machine error 76
Error 76 is a fuser error, sometimes it can be reset in service mode, but usually the fuser needs replacement.
Aug 19, 2008 | Brother Office Equipment & Supplies
Brother mfc-8840d: paper jam
The fuser gear on this fuser breaks alot. You are better off getting a new fuser if you know how to repair it.
Jun 30, 2008 | Brother MFC-8840DN (Bundle) All-In-One...
Brother fax machine intellifax 2600
Fuser or overheat error it will probably be followed by a 77. Menu, mode and 0 quickly in that order will give access to user maintenace mode (lights will flash once your into the mode). Hit 91 to reset the machine. If this doesn't work you have a major problem with your fuser unit and it will need to be replaced. DO NOT DO THE ABOVE PROCEDURE MORE THAN ONCE AS YOU WILL START TO MELT STUFF IF THERE IS A MAJOR PROBLEM.
Feb 07, 2008 | Brother IntelliFAX 2600 Fax
Machine Error 76
Machine error 76 is a bad fuser lamp. Machine error 78 is a bad thermistor. Machine error 77 means you hade either a Machine error 76 or Machine error 78 and turned the machine off.
Sometimes the machines will give a false code and can be reset. Unplug machine. Hold down the Menu key while powering back up. You should still get a Machine error message. Enter the number 9...The display should change to Maintenance 9 then enter 1. The Machine error will return. Enter 99 and then make a test print. If you get either a machine error 76 or 78 you will need to have service done on your machine to have either the lamp or thermistor replaced, and depending on the usage of the machine, it might not be a bad idea to replace the entire fuser.
Jan 18, 2008 | Brother IntelliFAX 2800 Laser Fax
Error Msg: PAPER JAM in Brother MFC-8840D
one of the jam switchs is stuck down or paper concertina in fuser assy
Dec 28, 2007 | Brother MFC-8840D All-In-One Laser Printer
How to clear a Machine Error 76
Error 76 is fuser error, you need to change the fuser but first just in case try to reset settings to factory defaults.
Nov 29, 2007 | Brother MFC 9600 All-In-One Laser Printer
Brother MFC-8840D All-In-One Laser Printer Logo
604 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
