Question about Brother HL-2040 Laser Printer
How do you replace a pick up roller on a brother HL 2040. I bought the part.
  • Brother Master
  • 4,338 Answers
The pick up roller is in the paper tray. It is the roller in the middle front of the tray. Usually, you press the roller to one side and it will pop out. Install the new one doing the reverse. There is a seperation pad that may need cleaning, too. Rub it with a damp cloth.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 11, 2010
  • Bill1749 Jan 30, 2011
    Joe,
    I purchased the sparation roller and pick up roller, they came connected as a unit. The separation roller is what is connected to the printer. One side of the separation roller is held in place by a black metal clip which you can push back which frees up the one side. The other end of the separation roller fits on a round metal shaft of which there doesn't seem to be any play in to slide it off of.
    Any advise would be appreciated
  • JDTec
    JDTec Jan 30, 2011
    I do not have the manual for your unit. But the 4000 series manual shows the seperation pad and roller as one unit. Usually rollers have notches which allow them to slide off easily. If I find the correct manual I will point you to it with a link.
    Joe
Brother HL 2140 does not pick up paper from tray
Make sure your pickup roller clean.
If it's clean and still jams the problem is inside.
  1. Remove left cover (where the USB connection is located);
  2. Remove big black gear with a spring on it (you may need to unscrew the PCB that partially covers it);
  3. There is a clutch that sticks to the rubber pad behind this gear. You may put a piece of scotch tape towards to a rubber pad, so the plastic from clutch mechanism would'n stick anymore. http://www.phillycopiers.com/fix/hl-2040-2070-fix.jpg
Oleg Andrukh IT Specialist
PhillyCopiers.com 215 364 3774
Apr 09, 2010 | Brother HL-2040 Laser Printer
FUSER TROUBLE HL 2040
This is a paper jamb problem. There is a piece of torn paper stuck in the paper path that is stopping the printed page from exiting properly.
Sep 30, 2009 | Brother HL-2040 Laser Printer
Can the Brothers HL 2040 handle printing 65lb
It probably can but only from the front slot, the paper tray has to bend the paper around the roller in the front when feeding.
Aug 28, 2009 | Brother HL-2040 Laser Printer
Will not pick up paper from tray. Red light blinks indicating a paper jam. Prints fine if single sheet thru bypass slot.
Not picking up paper indicates either a worn nip roller (rubber on feed spindle) or you have a broken gear in the feed mechanism.
Aug 14, 2009 | Brother HL-2040 Laser Printer
Need to clean roller feeder. what solution is used?
soap solution will do. be sure to clean the rubber pad that's on the paper tray too
Mar 30, 2009 | Brother HL-2040 Laser Printer
Paper Jamb in Brother HL 2040 Printer
inside the printer their is a roller and if you turn the roller then it should feed the paper through it fairly easily. it may seem like you are turning really hard but it will work.
Nov 14, 2008 | Brother HL-2040 Laser Printer
Brother printer keeps whirring away
probably or definitely..check for paper jams, and then clean rollers
and by the way, get a fresh set of drivers here
Mar 05, 2008 | Brother HL-2040 Laser Printer
Replaced toner cartridge now doesn't work
If you pull out the paper tray you will see a rubber pick up roller. Clean that roller with a rag and some rubbing alcohol. It sounds as if the roller is slipping and not bringing the paper in fully. Good luck John
Jul 09, 2007 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
562 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
