Question about Sentry Fireproof Safe
I have the right combo and key..following the manual exactly..safe wont open..any help?
  • 1 more comment
  • dennisk84 Nov 11, 2010
    OS3407
    Yes,
    The handle should be all of the way UP, in the horizontal position before attempting to dial out safe.
    Testing your combination: Your safe's combina- tion is printed on the front of this owner's manual. You will have a 3-number or 4-number combination depending upon the model purchased.
    3-NUMBER COMBINATION (Cannot be changed)
    1. To unlock and open
    Before dialing your combination, simply insert the key (if equipped) in the lock and turn until the plunger pops out. Remove key.
    NOTE: The safe will lock if key lock cylinder is pressed in with or without key.
    A. Start the dial at zero. B. Turn the dial to the left. Make sure ZERO
    passes the pointer at least THREE times. Then stop at the first number of your combination.
    C. Turn the dial to the right. Stop the SECOND time you reach the second number of your combination.
    D. Turn the dial to the left. Stop the FIRST time the pointer reaches the third number of your combination.
    2. To close and lock
    You can relock the safe in two ways. With the door closed, depress the key lock (if equipped) with your finger, or spin the combination dial one full turn. For greatest security, do both. (Make sure the door handle is in the horizontal position.)
    SORRY THE FONT IS SO SMALL
    are you still there?
    Sentry Fire Home Safe Model #OS3407..i have the right key, combo, and am doing the right procedure, following exactly what the manual says, and no luck opening. I have medication in the safe that I need. please help.
    President:
  • 1,961 Answers
Hi!
As a I know... the only help you can get is to ask for some technical experts to do the hands-on on breaking in your safe using a power tool..
I'm sorry for that!!!!
But I read a story of an owner with the same safe having the same problem like yours and a little trick does for him. This might help you too...
" If you have a safe sentry with a dial-type of combo lock....... try subtracting one from the middle number of the combination that was provided with the safe"
... It works for him...might work for you too....
Posted on Nov 11, 2010
  • 10,515 Answers
I would appreciate if you could provide the model number to me?
Are you sure that you are using the correct procedure to open the safe?
Thanks!!
I put my combo on my model s0310 safe for the first time and unable to open safe with the combo I inputed. is there a way to use th keys or bypass combo
The safe can be opened using the factory set 5 digit code found on the documentation that came with it. You can also call 1-800-828-1438 with the serial number and get help.
Dec 25, 2014 | Home Security
I have the combo, but what is the direction? Do
Locksmith Instruction manual on how to dial open sentry fire safes.
NOTE: If your safe doesn't have a key, skip Step 3.
Turn the dial to zero.
Insert your sentry safe key and turn it until the plunger pops out.
Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
Turn the dial to the left to the last number (stop the first time on your last number).
Pull the handle down; cracking Sentry Fireproof Safe open.
Nov 16, 2009 | Sentry Fireproof Safe
Key is not working
Nice looking safe. You can download an owner's manual from sentrysafe.com.
Some safes have provisions for supplying power to the combo in event of battery failure.
I don't know how it is supposed to operate with key.
Jul 31, 2009 | Sentry Fireproof Safe
Can't open sentry v260 safe
Make sure you are inserting key so the round hump on key matches red dot on lock, and turn key clockwise.
If that doesn't fix it, SentrySafe's support number is 1-800-828-1438.
I would think they can confirm the combination from your serial number. They probably won't give you the combination without a notarized letter, but if you have the right combination for that serial number safe, they may confirm that you are entering the right combination.
Be aware the 4 number combination V260's are changeable and if you HAVE changed it, you are on your own, they can't help you. The 3 number combinations are not changeable.
Mar 16, 2009 | Sentry Fireproof Safe
Have a Sentry V260 safe. The #1 button will not register when pressed. All other buttons register except for the #1. And the #1 button is in the combo. How else can I open it or how can I fix this button?
You can do a Key override
If your electronic lock fails or you do not have any codes
available, you may use a key override to access this unit.
1. Remove the battery cover, disconnect and remove the
battery holder.
2. Insert the skeleton key (second set of keys provided)
into the key hole inside the opening for the battery.
3. Turn the key to the right.
4. Turn the four-bitted key to the right.
5. Open the door.
You can download the user manual here:
http://www.sentrysafe.com/pdfs/OwnersManuals/172967.pdf
Dec 25, 2008 | Sentry Fireproof Safe
The number 1 button will not press
Key override
battery holder.
5. Open the door.
Dec 24, 2008 | Sentry Fireproof Safe
Factory code will not open model # DA3831 safe
i am a locksmith that has worked on several of these. The safe is manufactuered with three types of lock mechanisms 1. combo dial 2. digital 3. advanced digital the advanced digital is what you have there are no green lights on it. look at the manual carefully there are 2 seperate sections on the digital key pads yours will be the second.
Nov 23, 2008 | Sentry Fireproof Safe
Brinks safe model # 5054
go to honeywellsafes.com apparently brinks was bought out
Jul 28, 2008 | Computers & Internet
Sentry Fireproof Safe Logo
208 people viewed this question
Top Sentry Home Security Experts
Hannah Johnson
Level 1 Expert
ray012965
Michael Galve
Michael Galve
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
