Question about LaCie Rugged All-Terrain (301017) Hard Drive
My Lacie hard drive worked perfectly for a period of time. I use it to make films and store all my files and final work on it. It now no longer appears on my desktop and I cannot access it in any way. It does not show on the system profiler. I use a mac book pro running OS X 10.6.4. It does mount up on older computers running older versions of OS X. I have been in touch with lacie and even returned the drive to them. They said there was no problem. Can any one help
    Brigadier General:
  • 10,406 Answers
> it does NOT show on ... Macbook Pro running OS X 10.6.4
> it DOES mount up on older computers running older versions of OS X
> Lacie ... said there was no problem
So, the problem is "local" to ONE of your computers.
Be sure that your computer is connected to AC power, not running solely on its battery.
Try some other USB device in the USB port, to confirm that the USB port is working.
Posted on Nov 11, 2010
My mobile hard drive lacie rugged crashed, doesn't show on laptop or iMac and i need to recover my data stored in it
You may need to send it out to a data recovery lab. Before that try a remote access data recovery service like http://FreeDataRecovery.us
They operate an online data recovery service via the internet and also offer do-it-yourself data recovery assistance.
Oct 16, 2012 | LaCie Rugged All-Terrain (301017) Hard...
Running a lacie hard drive with mac mini - after 2 years will not show up on desktop or in utility disk window
There are several possible reasons for this.
The most common is a short or failure in the Lacie enclosure caused by mixing up power/AC adapters. If your two Lacie drives are different models and you accidentally used the wrong adapter you may have damaged the circuitry.
The second possiblilty is that your power adapter or USB/Firewire cables could be damaged. Try switching USB/Firewire Cables First. If this fails to work then check if you have a smae sized adapter with the exact same Output Voltage and Amps on both adapters. Only if they are identical try switching adpaters from the working unit. If they are not proceed to the below solution.
Finally if the unit was dropped, bumped or unplugged while it was running it is quite possible that you may have damaged either the drive or the file structure on it, either of which would cause it to stop showing up.
Solution:
Try the cable swaps if able, if they work, replace the USB cable or replace the entire enclosure if the power adapter is the issue.
If neither works then you have either a failed hard drive or failed enclosure. Go to your local PC store (not a big box and yes PC, they tend to have more experience and parts to work with in this type of situation), have the techs there remove the drive from the Lacie enclosure and place it in a new enclosure for testing. They may not be able to see your files but they will be able to tell if the drive is working. If it is, buy the enclosure, then connect the drive back to your Mac. If it works you're done.
If the drive works but the Mac still doesn't recognize it(doesn't show up on the screen), then comment back and I will get you the link to a program you can use to retrieve the lost files.
If the drive simply fails to show up at the store in the new enclosure you will need the help of a pro to recover any important files. If that is the case reply with your location, Country, State and City and I will recomend an appropriate facility for you.
Hope this helps FixYa,
Chris
Jan 30, 2010 | LaCie Computers & Internet
Hello i plug my lacie 1tb external hard drive into my ps3 and it does not get regconise but when i plug it into my pc it works perfectly
ps3 is designed to take certain drive formats. I'm no sure which ones but you could test. Just back up all the files and reformat it with FAT32, FAT...and if it doesn't work just restore the files because gaming consoles were never designed to take externals used by computers.
Dec 01, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
XP doesn't recognize 500GB external Lacie after almost 2 years
try it on different usb ports on your system
try replacing the cable which connects the hard drive with the usb port
if this does not works the problem lies in the portable hard drive and i think it would be under warranty period so get it checked
Jul 09, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
LACIE 500 GB HARD DRIVE
i use my external hard disk many times but now when i connect my lacie external H.D to PC it dose not recognized
Jan 30, 2009 | LaCie (300951U) 500 GB Hard Drive
Lacie drive makes popping noise, goes offline, corrupts files
I'm afraid your hard drive is cactus. The popping noise is most likely the read head hitting the cylinder. This is causing more and more physical damage to the PC as it attempts to read the files. You will most likely need to consult the supplier of the equipment for a warranty replacement, or go through the vendor. If the drive is out of warranty I suggest buying a new one and throwing the old away.
There is no way to recover a drive that is physically colliding the head with one of the drive plattes.
Apr 15, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Lacie 320 GB Hard Drive acting as if full when it's not.
Simplest solution: back up the data on the drive and repartition it (which will wipe it). Otherwise it sounds like it could be a problem with the file tree or structure of the drive, the configuration files could be corrupt, some program could have stored temporary files in a hidden place that cannot be deleted without making the program delete them, etc. If you are on a mac, spotlight Disk Utility and use it to repartition. If you are on a PC use the search thing from the start menu and find a program called disk management (or something similar to that, you'll know it when you see it.) external drives are annoying. i kick mine into the wall periodically for good measure.
Mar 22, 2008 | LaCie (300950) 400 GB Hard Drive
Lacie drive won't mount
I solved the problem. It was a power supply problem. It seems after searching boards on the net, this is a common problem with the lacie hard drives. Just replace the power if your hard drive is clicking and not mounting. I think many people must be throwing the drives away thinking they are lost when it is just the power supply. Try this first before trashing it or spending a lot of money on data recovery programs/
Nov 13, 2007 | LaCie 250GB Ext/Firewire 7200 250 GB Hard...
URGENT HELP NEEDED (editing a film) G4 0S 10.4
It sounds as if the enclosure has failed. IF THE DRIVE IS GETTING POWER, but not making strange noises, you may just need to extract the drive from the enclosure. Keep your fingers crossed. If the drive has been affected, data recovery may be the solution. Good luck.
Sep 06, 2007 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
LaCie Rugged All-Terrain (301017) Hard Drive Logo
342 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
