Question about LG Studioworks 700S 17" CRT Monitor
How can i open mylg e700.
Sir can u please tell me how do i open the back cover of my monitor. when i turn on my monitor, the green is blinkin ver y fast and my monitor didn;t turnon
  • jalees_21 Jul 23, 2008
    sir can u please tell me how do i open the back cover of my monitor. when i turn on my monitor, the green is blinkin ver y fast and my monitor didn;t turnon
  • karthik_vish Aug 27, 2008
    I have Studiowors 700E Black Monitor. When I poered on the led Blinks very fastly. There is no display. I want to Know How To Open the Back Cover. Please Help me.
    Welcome Back:
    Visited the website for 2 consecutive days.
I have repaired various LG monitor & they all seem to suffer the same problem with the led flashing. The fault is fixed by replacing Q719 which is a Mosfet IRFS640 & C744 100uf100v cap, also check caps in power supply a couple of 220uf63v pop from the bottom. I have had the line output transistor s/c.If its the one Im thinking of, to take the back off . Tip the screen on its face & with a pair of long nose pliers wedge them into the clip at the bottom & use a flat blade screwdriver to prise the bottom slightly away. Then place the monitor upright using your screwdriver you have to pop the top. Push 2 inches from each corner. You have to push hard. Good luck.
Posted on Sep 04, 2008
  • grabba Sep 04, 2008
    Note to replace Q719 you may have to remove the heat sink as well.
Nokia bluetooth device unable to connect my computer..always blinking green light please can u explain about these problem thank u very much sir, regards, sridhar
first hold start button for 8 to 10 second...when it start blinkin then open bluetoth device and click ADD tab. and search your device.when it will appear,it will ask for a unique pass.then choose your pass key.PLEASE MIND THAT THE PASS KEY MUST BE FOUR TIMES ZERO (0000) and then will connect......
Nov 11, 2010 | Nokia BH-104 Bluetooth Headset
Monitor light blinks no picture
(Please be advise that if you don't have the knowledge, the proper skills and the right tools to open the back cover of your monitor and replace its part...don't risk it...
Otherwise, bring your unit to a credible technician and avail of warranty if there is any.....) If you have guts.. then do the following steps..
You said your monitor will blink but no picture display... well, there are possible reasons why this problem occur..
1. Open the back cover of your monitor..Check the power supply section for possible loose connections and blown capacitors.. Resolder any loose terminal connection on the pcb. Check for any blown capacitor, replace the capacitor with exact value, and also replace any bulging capacitor..If you have successfully replace the parts you can try to turn it on and connect the vga cable in it to the video card of your computer. Turn on also the cpu, if the monitor led turn green and the display came out..that fixed it.
2. In case you have successfully repaired the power supply section and the led of the monitor stays green.. then the problem will be in the inverter board section....Turn off your monitor... open the back cover...on the inverter board section.. check and replaced burnt or overheating high voltage transformer..if one or more of this overheats, it is enough to affect the supply current from the power supply section and that may cause to blow your capacitor...If the ballast transformer is working fine the last thing to check is the backlight inverter (the light that illuminate causing display in your monitor) Replace any busted lamp.. that should fix the black screen on your monitor. ..
If you find this information very useful..please be kind to rate this solution and vote for this on the help below...thanks..
Much appreciated if you rate this help...thanks...
Jun 02, 2010 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Sevice tool light blinkin and error c05
To clear this code requires you be in front of the machine, to the right side of the machine, just below the large glass is a cover remove it if you copiers is networked the cover is where the network cable connects. Once the cover is removed look inside you will see a small black button press it then get back to the operator panel you will see "Please wait" then you will see a small dot on the screen on the lefthand side of the screen when you see the dot press "3" you will see a 'TROUBLE RESET" PRESS the OK letb the machine go thur the motions this time when you see the dot do noting. Once ready to copy, turn off the machine both power switches main sw is in the back left side of machine then turn the pwr switches back on if this is not done your Start button will continue to blink on/off. If the code comes back your fuser unit needs replacement or worse the main board:(
Sep 02, 2009 | Minolta bizhub 350 Black and White Copier
I need the elctronic layout of monitor lg flatron 775ft
May 12, 2009 | LG Flatron 775FT 17" CRT Monitor
This could be a sign that the monitor is failing, but it could also be a very simple solution as well. There should be two cables that come from the back of the monitor - one is the power cord and the other goes to the back of the computer. You will want to disconnect the cable from the back of the computer and then blow out the end with the pins in it (either with a deep breath or a can of compressed air. Now connect the cable back to the computer. You may need a screwdriver to remove the cable and you definitely want to make sure the cable is screwed in after you reinsert it even if it wasn't when you removed it.
If the display still shows a green tint, perform the same steps where the cable connects into the monitor. Some displays don't allow this part of the cable to be disconnected from the monitor, so you may be unable to perform this step.
Hope this helps,
Mar 23, 2009 | LG Studioworks E700S 17" CRT Monitor
My computer shutdown and im using a emachine e17t6w tft lcd flat
Dear sir,
Moniter Modale No E700,
E700 modeleprablem, Power splay prablem, but transister, Divaid all componets ok
Becouse power on that puse shout way to andstrading the prablem, please solve prablem
Mar 19, 2009 | Computers & Internet
Sir Help me with my Compaq monitor MV520 it won't turn the power led flashing orange to green continously
it could be th epower supply and it could be the monitor.
power ON button should not flash orange regardless what you do. it should stay green. then orange. not orange to green to orange.
try the monitor on another PC if you can fine one.
the other thing is are the 2 monitor similar (CRT to CRT and LCD to LCD), you can't mix the the two, they will work but need different video driver to function correctly.
Oct 20, 2008 | Compaq MV 540 15" CRT Monitor
Check this on ( its regional site
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 11, 2008 | Acer AC713 17" CRT Monitor
Multisync E700 Monitor Problem
try the moniter on another p.c. see if it works then
Feb 03, 2008 | Gateway FPD2275W LCD Monitor
MultiSync E700 Monitor Issue
I thins the trinitron core is also can be the cable which connects it to the video card..trey to check this one..if not..sorry for your old great monitor...
Feb 03, 2008 | NEC MultiSync FE700 17" CRT Monitor
LG Studioworks 700S 17" CRT Monitor Logo
177 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
