Question about Saeco Spidem Villa
I have a Saeco Spidem Villa. Iâ??ve been
    Habit-Forming:
  • Saeco Expert
  • 147 Answers
I dont understand what exactly happen when you try to make coffee? Is the coffee comes out or no?
Posted on Apr 30, 2017
EsWorld
  • 1618 Answers
SOURCE: How do you take apart the grinderon Saeco Spidem Villa Household Coffee Machine
Remove all the beans in the hopper, there are 2-3 screws in the hopper. Remove and then lift hopper, this will give access to the grinder chamber and burrs.
Posted on May 30, 2009
  • 1089 Answers
SOURCE: how to descale Saeco Spidem Villa
Hi
Don't use vinegar. Its only 5% acid at full strength and if you mix it with water a lot less. It also leaves an after taste for about 2 weeks. Use descaling powder or other products especially made for espresso machines.
Remember, it is better to descale more often than not enough.
1. To decalcify your boiler, remove your water tank and fill it with hot water (100 to 120 degrees). Open a pack of decalcifier and mix into the water tank. Once it is dissolved, place the tank back on the machine, and then turn the machine on.
2. If you just open the steam knob and run approximately eight ounces of solution into a spare container. Turn the machine off and let set about 10 to 15 minutes. Longer is better. It is very important that the machine does not remain on to heat the boiler anymore than necessary.
3. Repeat step #2 for your machine. Do this until you have consumed the entire water tank of solution (approximately four to five cycles). (I do it at night before I go to bed and let the last cycle set in the boiler till morning.)
4. Remove water tank and rinse it with fresh water.
5. Refill water tank with fresh water and place it back on the machine.
Repeat step #2 to rinse the machine, only this time use the entire water tank at one time, and there is no need to let it set.
Posted on Jun 01, 2009
  • 143 Answers
SOURCE: Broken"ON" button on Spidem Villa by Saeco
see repair shop. It is a ***** to replace,
Posted on Sep 20, 2009
SOURCE: My Saeco Spidem Villa leaks after it despenses the
Take out the grounds box and the brew group. At the back there is an opening. If grounds get in the opening, it can't drain. Get some hot water in a squirt bottle and flush out that opening at the back ... this may end your problem with leaking after dispensing
Posted on May 19, 2010
  • 1089 Answers
SOURCE: Saeco Spidem Villa brews very slow
Hi
Yep.
Remove the brew unit. Holding the handle, the top left side is the brew head. There is an outlet pipe that exits the front side towards the door (looks like a long "L" pipe). 2screws hold it to the top. Remove the 2 screws while holding the manifold ("L" pipe assembly). Once they are removed, lift the l assembly off (be careful, there is an O-ring, spring and at the end a black rubber disk or crystal ball).
Now remove the brew screen, by holding the screen with your finger and twisting the thumbscrew (remember, thumbscrew), DON’T use the key to install the screen, use your fingers.
Once the screen is out look at where the screen was. There are 2 holes. A big one in the center and a small one to the side.
With the brew unit upside down over the towel, insert a paperclip into the small hole and force anything out the other side. I have gotten worms almost a 1" long from this passage. The paper clip has to go from this side to prevent damage to the seat on the other side.
Clean then reassemble. Brew unit on towel right side up. Drop the crystal ball in first. Then the spring small end first on the crystal ball.
Now the O-ring over the spring, then place the manifold on top of that with the pipe towards the machine. Insert your screws (I turn them backwards a little with a little downward pressure until they feel like they drop into the threads. They should turn down easily, if not back them up a little more ( we are trying to find the old threads) and tighten. Install screen, and tighten with your fingers. The screen just needs to be flush with the bottom of the brew head. That should do it.
Posted on Jul 06, 2010
Red light won't stop flashing. Parts are in place
Be sure all coffee grounds are cleaned from beneath the water tray and the grounds tray and the coffee brew group. We had the same problem but finally redid everything, including cleaning the coffee brew group under hot water, drying and replacing carefully until it clicked in place. The moving parts of brew group have to be in exactly the right place. Good luck!
May 12, 2012 | Saeco Spidem Villa
The water output on my Spidem Villa was decreasing so I descaled it (I've done this before). No it will not dispense any coffee or water/steam at all. Apparently some of the scale deposits are lodged...
Hi
The first place I would check is the steam wand. Remove the pannarrello (loosen the cap all the way and pull down on the bottom. Leave the cap and seals on the wand). Clean the tip of the wand and check to see if that cleared the blockage.
May 19, 2010 | Saeco Spidem Villa
My Saeco Spidem Villa leaks after it despenses the coffee. Have attempted to clean descale to no avail. Any suggestions?
Apr 05, 2010 | Saeco Spidem Villa
Repair spidem villa
A little spring felt off from the inside part when I was cleaning
Sep 23, 2009 | Saeco Spidem Villa
Sep 19, 2009 | Saeco Spidem Villa
New Saeco Villa Espresso won't Prime
check your steam wand and you can check does water get true to the pump,maybe you have air in hous
Aug 29, 2009 | Saeco Spidem Villa
How do you take apart the grinder on Saeco Spidem Villa Household Coffee Machine
There should be screws on the side or the bottom of the unit that will allow you to pull it apart. The problem seems to be that the two grinding wheels have gone bad and needs to be replaced. On this unit you cannot adjust the grinding as far as would need to be to fix the problem when the teeth get to small
Jun 03, 2009 | Saeco Spidem Villa
May 29, 2009 | Saeco Spidem Villa
How to descale Saeco Spidem Villa
Hi
Mar 17, 2009 | Saeco Spidem Villa
Saeco Spidem Villa not dispencing water or steam. Need Help!
mine just wont heat up... no hot water.. have only had it for a week... what can i do?
Feb 18, 2009 | Saeco Spidem Villa
Saeco Spidem Villa Logo
76 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
