Question about Lexmark X4550 InkJet Printer
X4550 not being able to communicate with pc. unplugged power, usb, installed updated drivers, restart did all things that it said to do, and still wont talk to pc-printer working yesterday not working today
    Problem Solver:
  • 19 Answers
All I can think of is make sure that your printer is up and online before you turn on your computer.
and
depending on what operating system your are using, you can go to mycomputer and right click on it go to properties in new window click on it, then goto device manager and click on it.
Device manager lists all the devices that the operating system sees. If you have an explenation mark next to the printer, you may have to locate the printer driver and left click it should drop down the printer driver, then right click on the printer driver then click properties and look at the driver specifics. If it is not the new driver you can uninstall or update and install the correct printer driver. After you make a correction restart your computer, and it should see the printer.
Posted on Nov 11, 2010
Lexmark X4550 Scanner not working
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Jan 05, 2012 | Lexmark X4550 Multifunction Wireless Color...
Lexmark x4550 scan problem
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/g8G3VP. Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 13, 2011 | Lexmark X4550 Multifunction Wireless Color...
Hi - my x4550 lexmark printer wont print, can you help?
If your printer won't print when you're making a copy using the Copy button on the operator panel, it could be due to your ink cartridges. Try to re-seat your ink cartridges into the printer and make sure they are properly seated.
If you're not able to print from your computer, it could be a communication problem. A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if usb-connected), reboot your computer and unplug/replug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Try to print again.
You may refer to this article for Wi-Fi connection issues: How to identify a Wireless Communication Problem and Resolution Tips
Aug 11, 2011 | Lexmark X4550 Multifunction Wireless Color...
I cant communicate with printer. i tried checking usb, unplugging power and restarting pc. still doesnt work.HELP
install drivers first with printer not connected. the connect. drivers are free after free registration at drivers.com. also probably available at the manufacturer's website.
Sep 04, 2010 | Lexmark X4270 All-In-One InkJet Printer
Ext hdd wd3200me does not detect on my com.. Its using intergrated usb controller method..any suggestions..
Update the drivers for the communication. You can download from the manufacture's website of the EXT hdd.
They are usually under the download or support tab.
Just down the drivers, double-click on the file to install them into your pc, then restart pc then connect.
Jun 27, 2010 | Western Digital Elements powered by WD 320...
My Lexmark 4550 will not sacn wirelessly, how do I
Hello. Try to run the installation cd in your computer again. If you haven't tried to uninstall the software from your computer, the cd should give you three options: Install a Printer, Repair/Update and Install Additional Softwares. Choose Repair/Update and just let it run and finish the installation. Also, make sure to allow all Lexmark and printer communications in your firewall. Try to scan wirelessly again. If problem needs further troubleshooting, I advise you to call Lexmark.
Mar 31, 2010 | Lexmark X4550 InkJet Printer
Printer not communicating with computer but I have tried unplugging/disconnecting USB and restarting - nothing works - help
Delete the printer and all of its software ... reindtall according to the manufacturer instructions. You may find updated driver and instructions at the manufacturers web site
good luck
a
Oct 04, 2009 | Computers & Internet
Left cartridge incorrect message after installing a genuine lexmark replacement cartridge
There are a small number of #23/#24 cartridges that are not properly recognized by the printer. Lexmark has a firmware upgrade to correct this issue. The upgrade for the X3430 is available from Lexmark at:
To install the firmware upgrade,
  1. Make sure the printer is ON and connected with a USB cable.
  2. Download and run the appropriate firmware upgrade for your computer.
  3. Be sure not to disconnect or power off the printer until the upgrade is complete
When the update finishes the printer will restart and will accept the cartridges. Please contact Lexmark support if this does not fix the problem.
This works for the X3550 and X4550 models. A similar patch is available for the X3430 and Z1420 models. See http://bit.ly/LoXxv
Jun 04, 2009 | Lexmark X4550 InkJet Printer
No communications computer to printer
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install:
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the software asks for the printer connect it and continue
Jan 21, 2009 | Lexmark X75 MF All-In-One InkJet Printer
Printing problem
To delete the file from printer cue, unplug printer, restart computer with printer unplugged, and delete file.
If it still does not work after deleting files, reinstall all printer software using software CD provided with the printer.
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Sep 12, 2008 | Lexmark X4550 InkJet Printer
Lexmark X4550 InkJet Printer Logo
53 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
