Question about Akai PDP4294 42 in. EDTV-Ready Plasma Television
I have a 42in akai model pdp4294x/SMS an the picture went out the red light blinks when u press power I got sound but no picture
5 Suggested Answers
SOURCE: Akai Plasma TV's screen suddenly went blank -model PDP4294
MINE DID THE SAME, POWER SUPPLY WENT OUT, AKAI HAS NO REPLACEMENT PARTS, TV REPAIR PLACE SAID THROW IT IN THE GARBAGE, COMPLAINT TO AKAI AND THEY ARE SUPPOSE TO SEND ME A VOUCHER FOR A NEW TV...2 MONTHS AND NOTHING YET???
Posted on Jan 23, 2008
  • 8 Answers
SOURCE: akai tv turned itself off and now only have a red blinking light-tv will not turn back on model no. lct2701td tv is 2 1/2 yrs old
try looking at the board inside the TV for bulged capacitors see polaroid thread. this is the problem on the polaroid could be the same here.
Posted on Sep 16, 2008
  • 2337 Answers
SOURCE: lcd akai 2715 blinking red light
The solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Posted on Nov 27, 2008
kapishtech
  • 2272 Answers
SOURCE: RED LIGHT BLINKING AND NO RESPONSE AKAI LCT2715
The led is blinking due to fault in power supply board.
On the power supply board there are some capacitors and ICs .if any of those gets short or faulty the power supply board will create problems and the red light will start blinking. The components on the board needs to be checked with the help of multimeter and continuity tester.And the faulty components needs to be replaced with the help of soldering iron. the procedure to check the power supply board is as follows:---- 1) You are going to need a Phillips ( X ) Screwdriver for this procedure. The first thing you will want to do is find a suitable location to disassemble the TV. Try to find somewhere with plenty of space to work and preferably somewhere you will not have any hazards such as static (like carpet)
Lay the TV Flat on its face (picture side down) and remove the 4 screws from the back of the TV holding the base on.
Next you will want to process to remove the screws around the back cover. There are 12 screws you will need to remove (refer to picture for locations).
Carefully remove the back panel of the TV. It may snag on the coaxial connector so be careful.
2) Once you have the back off of the TV you can see the Main board and power supply covers.You will now need to remove the left (right side from the back) speaker cover to allow access to two of the screws holding the Power Supply Cover in place. This is easy and pretty straight forward and has 8 screws around the perimeter.
Once you have the speaker cover off you should be able to access the screws on the side and you will also want to remove the other screws from around the sides of the cover. Some TV's I have worked on only had 6 where others had 7 or 8. Just make sure to remove all of the screws before trying to remove the cover.
Once you have the cover removed you will see the Power supply. Remove the wiring harnesses from the power supply board. You will have 4 cables at the top of the power supply and one main power input at the bottom. The main power input may have some glue securing it in place. Simply cut this with a knife or pull it loose.
Once you have the cables off of the power supply you can remove it from the TV via the screws on the 4 corners. Be careful not to damage anything as you remove these screws. You now have the Power Supply removed from the TV.
you can now get the power supply repaired from any local tv repair technician.or get new replacement power supply from the service center.or from online stores like : www.partstore.com or from www.shopjimmy.com
Thanks. you can rate this solution and show your appreciation.
Posted on May 15, 2010
LG 42in Class 1080p 120Hz LCD HDTV red light stays
Hi
Your tv set is stuck in the standby mode as a components went shortcircuit in one of the power supply rails and should be serviced by qualified personnel.
Sully
Sep 29, 2013 | LG 42LC2D 42 in. LCD HDTV
TV went out and will not come back on. Power light shows red but no sound or picture. It's about 4-5 years old.
I have a akai tv, the tv went out but won't come back on. i'm still getting a red light but the tv just beep when I press the power button.
Sep 18, 2009 | Akai PT4799HD Rear Projection Television
BLINKING RED LIGHT AND NO PICTURE OR SOUND
The flashing light indicates a short circuit inside the power supply circuitry. This type of repair is not a DIY without a multimeter, desoldering iron and hand soldering skills. I repair these power supplies, if you need further info write to jah2mil@hotmail.com
May 27, 2009 | Akai LCT2701TD Television
I have an AKAI TV...Model Code #PT4250AX/SMS - Rear Projection TV. The TV was being used and a pop sound was heard and then the tv was black (no audio, no video). Now when you turn on the power the red...
My recommendation is to call a local svc co. Since you heard a pop, it could be anywhere in the set. It requires trouble shooting to isolate where the problem is. I hope this is help-full for you.
Feb 27, 2009 | Akai PT4298HD Rear Projection Television
Sony 42in- No picture or sound
You need to replace the bulb...very easy. You can do it yourself.
Dec 23, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Lcd akai 2715 blinking red light
Nov 19, 2008 | Akai LCT2715 27 in. LCD Television
Blinking red light
I DO HAVE THE SAME PROBLEM , ONLY THE RED LIGHT BLINKING ,NO SOUND NO PICTURE '
PLEASE I DO NEED HELP TO FIX IT .THNKS
Nov 15, 2008 | Akai LCT2715 27 in. LCD Television
No picture ; no sound
the red blinking light usually has a pattern that gives you a code to the possible problem.
Maybe you have a bad power supply board. You have to open the panel and do a few tests on the power supply's outputs to be sure.
It produces a variety of voltages for different parts of the tv ie. the plasma display panel and the audio system. The components supplying power to the audio system may have failed a year ago and recently the pdp.
plasma tv's are expensive to repair, most of the time you can get a better tv for the same price. You can reduce that cost by learning and troubleshooting it yourself.
Feb 23, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Akai PT5598HDX/SMS won't turn on
Just a thaught, I could be wrong, maybe a problem with the power button on the remote ? It might shut the TV off, and when you do keep pressing the remote button, the red light on the TV will keep flashing like that also. Ive seen this prob on a few other blogs, so seems to be pretty common. I know I like to keep the remote pointed at the TV all the time, maybe try pointing it away for a while, just to see.
Dec 30, 2007 | Akai PT5598HD 55" Rear Projection...
Same thing for me. TV just turned off one day and won't come back on. LED flashes red. Someone said it's because a cooling fan went out. If I can't find someone to fix it I'll take it apart and tinker myself. 32" with dvd built in was barely over a year old.
Nov 04, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Akai PDP4294 42 in. EDTV-Ready Plasma Television Logo
128 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
