Question about Dell Wireless Keyboard Optical Mouse w0147
Keyboard will not type onto computer screen, and wireless mouse not working either.
    Guru:
  • Dell Master
  • 2,178 Answers
Check the transceiver dongle that's connected to the USB port on the computer. Disconnect it and reboot your computer. Once the computer is booted and running, reconnect the dongle and allow Window to discover the device and load the driver. Wait until Windows says it's ready for use. If it doesn't get detected, then the dongle may be bad.
Posted on Nov 11, 2010
CANT ENTER MY PASSWORD TO GET IN MY COMPUTER KEYS NOT TYPING ON SCREEN ITS LIKE THE WIRELESS KEY BOARD IS NOT RESPONDING
My advice would be to put new batteries in the keyboard and see if that works, failing that, pick up a wired keyboard and mouse to log in to your system then re-connect the wireless set to re-install the drivers.
Jun 04, 2010 | Dell Wireless Keyboard Optical Mouse w0147
Unable to log onto computer keyboard double spacing and double ch
Try a different keyboard, if a different keyboard works properly then your original one is defective. If another keybaord does the same thing then its a setting in the operating system for the keyboard that needs to be changed.
May 01, 2010 | Dell Wireless Keyboard Optical Mouse w0147
How to turn keyboard and mouse on
make sure there is new batteries in both the mouse and keyboard. Also the wireless receiever that connects to the computer is responding as well.
After you get new batteries put in and also have the receiever plugged in. press the caps lock, num lock keys and see if they light up on the receiver. If they light up then things are working, if they don't then bring up the notepad and see if any of the keys show up in notepad when you type and also see if the cursor on the screen moves for your mouse.
Hopefully both of them will work once you change batteries. If both don't work after changing batteries then you'll need to get a new wireless keyboard/mouse kit.
Jun 29, 2009 | Logitech Wireless Access Duo Optical...
Keyboard not responding
Have you tried a USB keyboard and mouse wired.try also to hook up the normal keyboard and Mouse with out any usb devices hooked on the computer
May 05, 2009 | Logitech 967461-0403-PK Keyboard/Mouse
Dell wireless keyboard not working
What o/s are you using? If Vista(and your mouse works) you can access the onscreen keyboard to log into your computer and access the utility to reconnect your keyboard.
Jan 23, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Wireless mouse doesn't work
This problem was happening on my system but i managed to fix it easily! What has happened is your itouch software has become corrupt so it will only recognise your keyboard thus the usb connection. You will need to download/install off disc onto your computer again but do NOT go to uninstall program manager on windows as it will not appear there because even though you can access the itouch configuration panel, the database is corrupt and the administrative system will not recognise this. Just download/install via disc and it will just install with no alerts unlike most programs which will recognise the program is already installed onto the system. Once the setup is 92% it will freeze for a second then the found new hardware window will appear on screen go through that process and your mouse is back to normal and your keyboard will work via itouch software.
(Please note that this will only work on windows)
Nov 26, 2008 | Logitech Cordless iTouch Keyboard/Cordless...
Microsoft wireless optical desktop 2000 - keyboard and mouse
There are a number of things that may be causing your problem.
The first thing I would check would be the batteries, with these units having a wireless connection if the batteries become weak they will transmit a weaker signal and thus make it harder for the unit to read. Battery life is variable depending on how often you use your keyboard and mouse, and how far away from the transmitter the keyboard and mouse sit.
Also because the units are wireless there may be interference coming from other wireless devices in your household. Some possible guilty devices maybe cordless phones, Wifi adapters, and even some remotes.
Also Have you installed the intellitype and Intellipoint software for your Mouse & Keyboard. If so you can use it to check your battery life/ signal strenth and set you mouse sensitivity and type repeat rate.
On the bottom of your keyboard & Mouse and on the top of the wireless transponder there are reset buttons. Pushing the transponder 1st and then either or both the mouse and keyboards buttons should resysnc them without the need for a reboot.
Hope this helps
Dave
Nov 06, 2008 | Microsoft Wireless Optical Desktop Comfort...
Moving mouse, interrupts typing on MS Wireless Keyboard Combo
1.?Open the Start?Menu and click Devices?and?Printers . The Devices And Printers panel opens, in which you can access all the external devices connected to your computer, including your printer .
m-ydpxpf3wblkuljzof3anecxv-4-0.png Windows 10 - Control Panel - Keyboard - Settings
Apr 11, 2017 | Microsoft Multimedia Optical...
Logitech s510 keyboard
I had this problem for a very long time as well. Turns out this is an encryption issue. It's off-balance. You need to reset the encryption, and here's how:
On the LEFT side of your wireless keyboard press and hold Ctrl+Alt, and press F12, then release all three buttons. Now push the Connect button on your Wireless Receiver, then the connect button on your wireless keyboard. Now press Esc. Try it. See if it works. It did for me.
Nov 09, 2007 | Logitech Wireless Access Duo Optical...
Wireless mouse won't work on hp multimedia cordless keyboard and mouse
Try changing the batteries in the mouse and then press the little sync button of both the mouse and the wireless receiver.
Nov 09, 2007 | HP Multimedia Cordless Keyboard/Mouse...
Dell Wireless Keyboard Optical Mouse w0147 Logo
65 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
