CPU fan and chasis fan runs at twice the regular speed of 2k rpm and 1k rpm respectively. The cpu temperature is normal and pc is in a cold environment. This seems to happen more when I watch online streaming videos or movies. Does the problem lie with the fans or the cpu or something else?
  • 1,179 Answers
It is absolutely normal, CPU fan RPM can go as far as 3500 Rpm and Chassis fan as far as 2000Rpm. Best to have a cool PC, if you would like you can take a look at my tip entitled My Computer is not turning on!!! Is it dead!!! No POST!!! it explains every-thing.
Thanks
damnor01
Posted on Nov 11, 2010
I did everything (remove,check,clean,replace thermal past) for my qosmio F30-140's fans, but still they run normally without temperature level. Despite of high temperature, they run normally; before it...
Not sure if I understood the problem, but fan's speed is controlled by a motherboard. if it's intel CPU based laptop, usually the temperature might reach 80 C degrees before fans start to spin faster.
Oct 30, 2013 | Computers & Internet
Computer idles high then shuts down
When you say "idles high" do you mean you hear fans spinning faster or louder? If so, a fan spinning at higher than normal speeds is indicative of components/chips being run aggressively causing them to run at much higher temperatures. You may want to look into getting temperature monitoring software like CPU-Z to monitor the temperatures of your CPU and GPU. These components are the most common ones to be running at high temperatures. If any fan has failed on them the secondary fans (if there is one) will run at much higher speeds to compensate. Your PC may have a safety precaution to automatically shut down if certain temperatures are reached to prevent permanent damage to the components. Are you getting any blue screens before it shuts down?
Oct 16, 2013 | E-Machines eMachines Desktop PC
Processor thermal treat error while booting
Make sure that cpu fans are running normally. Go to BIOS (generally with F2 on intel motherboards), and there will be information about cpu temperature, also fan speed (in RPM). If fan speed is 0 or very low problem is in cpu fan. (connection problem might be). If cpu fan speed is normal (high value) and cpu temperature is high, I will suggest you to open your PC case (or notebook) and see whether cpu fan is dirty or not. This is very common problem. If so, clean it.
May 09, 2012 | Intel Computers & Internet
CPU FAN STUCK ON FULL SPEED.
I think if the CPU run always on full speed and the noise is evident and bothers you ..it means that it has something that force the CPU to run on a higher temperature than normal one ..
This can be the environment or a heat source you use in the room ..or just dust covering the heat dispenser and making necessary for the fan to run faster to compensate .
running the system for long hours and having a high temperature in the room is probably the cause..To avoid damage ..try to clean teh heat dispenser (the aluminum part under the fan )..or at least to remove teh system cover and leave it cool better ..you can also install a second fan and this way assure a better cooling for the CPU ..
Sep 16, 2011 | Acer Aspire X3910-U3012 (PTSED02010) PC...
I have a HP M1270N Media Center PC. The CPU Fan
The CPU fan is designed to run constantly to prevent the CPU from overheating. The speed depends on temperature condition of the room; slow in cold and fast in a hot room. However if you suspect that it runs too fast them try re-seating the CPU. WARNING: Re-seating should only be done if you are know how to do; don't experiment.
If it is running noisy, you can apply one or two drops of machine oil to the fan's spindle.
Other reasons include deposits of dust; use a blower to remove dust from the heat-sink.
To make sure you CPU is not in a critical state, log in the BIOS and in the hardware monitoring tab check the CPU temperature. It should be near 60 deg Celsius or 140 Fahrenheit.
One thing more, do not apply thermal grease in excess; its a conductive compound and can short the motherboard if it melts and deposits on the motherboard due to high CPU temperature.
May 25, 2010 | HP Media Center m1270n (PP132AA#ABA) PC...
Computer keeps shutting down.
Do the fan's spin when you power the PC on? All of the fans should spin up for at least a second upon initial boot. The CPU fan and video fan (if you have an external card) will spin the entire time the PC is on and vary in speed depending on temperature.
Try booting the PC with the side of the case off and note and fans that aren't spinning. The temperature to shut off the CPU is really high. If the temperature is getting hot enough to do this, you should notice a failure in a fan right away.
Mar 09, 2009 | Computers & Internet
Computer turns on but no display/cpu_fan slot not working.
The four-pin CPU fan connector is the same as the three-pin (red is for voltage, black is ground and yellow for the rpm reading) but also adds a blue wire used by some BIOS sets to adjust the RPM speed of the fan. The three-pin will fit into a four-pin connector without modification, using a jumper is DEFINITELY not recommended as it could short your board.
If your system has the four-pin fan, and it boots and runs without error, it may be that your CPU is running cool enough that the fan is not needed at the time. Check your BIOS for a hardware monitor to see the actual CPU temperature. Also, you may have added utilities in Windows to give the fan speed and CPU temperature in real time. You may also notice the CPU fan kicking in when doing CPU intensive operations (virus scans, etc.)
The four-pin fan would run from a three-pin connector but would always run at full speed because the RPM Adjust signal is not present.
Dec 27, 2008 | Intel Motherboard
Cpu fan not running fast enough
This will depend on the motherboard you are using.
however, you need to make sure that the CPU fan lead is plugged into the correct plug on the motherboard... for example, I have an Intel 975xbx motherboard and it has 4 fan plugs, but only one of those is for the CPU. The others are for front/rear/top fans. If the CPU fan is plugged into one of the secondary ports, the CPU fan wont speed up correctly.
Also, some BIOS settings in the motherboard allow you to enable or disable automatic fan speed adjustment, and also set the temperature points.
Dec 03, 2008 | Zalman Tech Computers & Internet
Cpu fan noisy/chip fan fail error messages
pils,
Yes. This sounds like a fan issue. The noise often comes from bearings failing within the fan. Also, a failing bearing can make things harder on the motor as it brings the fan up to speed. This is likely the reason that you see increased warnings during the fan speed check while booting because it comes to speed more slowly as bearing wear increases.
I give this a 90% chance that your CPU fan is causing the issue. Since a decent CPU fan will cost you ~$20 online, it's not much out of your pocket if you happen to uncover another culprit.
I'll keep an eye on this post. Let me know how things go.
Apr 03, 2008 | ASUS A8N-E Motherboard
Problem with the CPU cooling fan...!! :-(
Dear ARGHYA,
welll i can understand this, for this you can apply the Heatsink Grease between CPU and CPUFAN . it will help to reduce the CPU Temprature.
Cheerup
Mar 04, 2008 | Computers & Internet
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
