Motorola V3a but I have found the "Location" menu under settings. Thanks anyway.Motorola V3a but I have found the "Location" menu under settings. Thanks anyway.
Go to the settings app: On most tablets, the settings app can be found in the app drawer or on the home screen.
Locate the location settings: Look for a section labeled "Location" or "Location & Security". The location settings may be located under the "Device" or "System" section.
Turn on location services: Make sure that the location services toggle switch is turned on.
Change the home location: Look for a setting labeled "Home" or "Home Address". Tap on this option to open a map view. Use your finger to move the pin to the correct location.
Save the changes: Once you have the correct location set, tap on "Save" or "Set as Home".
Note: The steps may vary slightly depending on the specific model and operating system of your tablet. If you are unable to find the location settings, try searching for "location settings" in the device's search bar or help center.
It is very easy to deal with UAC Settings in windows 7.You dont need to completely disable UAC, if you really dont want to do. Here is the step to be followed to disable UAC in windows 7Step
1: Access UAC settings by typing UAC in the start menu or control panel search OR Go to start -> Control panel - > user accounts
Once you double click on user accounts you will get a window like below. There double click on Change user account control settings option
Now you will get options to change user account control settings. You can move the slide to 4 different posiotions according to your choice. The first is more secure and the last means its disabled
Disable UAC via Registry Editor 1.Type regedit in the Start -> Search bar. 2.GotothefollowingKey:HKEY_LOCAL_MACHINESoftwareMicrosoftWindowsCurrentVersionPoliciesSystem 3.Locate REG_DWORD: EnableLUA 4.Set the value of EnableLUA to 0. 5.Locate REG_DWORD: ConsentPromptBehaviorAdmin 6.Set the value of ConsentPromptBehaviorAdmin to 0 7.Restart
Disable UAC via Group Policy
Type “gpedit.msc” in the Start -> Search bar.
Double-Click: Computer Configuration -> Windows Settings -> Security Settings -> Local Policies -> Security Options.
Locate: “User Account Control: Behavior of the elevation prompt for administrators in Admin Approval Mode” and modify to “Elevate without prompt”
.Locate: “User Account Control: Detect application installations and prompt for elevation” and modify it to “Disabled”
Locate: “User Account Control: Run all administrators in Admin Approval Mode” and modify it to “Disabled”
Locate: “User Account Control: Only elevate UIAccess applications that are installed in secure locations” and modify it to “Disabled”
Hi, go to settings--Privacy--Location Services--below you will see Apps that you share your location. Select the app(s) you want, you can set the allow location access to Never if you don't want to share your location with the app.
If you're wanting an app to update your current location, make sure when you load the maps application that it is loading your actual current location.
Also, check your settings under Settings->General->Location Services and make sure you have location services turned on.
1. Under International set the Region Format to "United States" 2. Under Time Zone set thid to where ever you are e.g. Miami, USA 3. Then under Location Services switch this on
Then go to maps and when prompted let it allow you to use your current location
i dont see a brand so i will give a genrealized answer. By current location i assume the opening screen display reverts to a default location which is what location it was initially set at or is a default in the unit. Most GPS give you an option to set Your STATE and home location. this is usually in SETTINGS Menu. The time and data are also changable inthe same area using you country location and then the State and any daylight savings offset that might apply. These are sometimes, volatile as there is no power to keep these settings alive when in off mode only in standby mode. the button on front of unit. If the master on/off is selected your settings weill revert back to default so its wise to keep it well charged if you use it every day and want to maintain your preferred settings. Hope that helps you
2) Use the iPhoneGPS receiver to locate your position
3) Settings > Enable 3G change to On.
There are two positioning systems in the iPhone 3G, one is the 3G network, and the second is the GPS receiver. The problem occurs when the data from the two systems doesn't match.
please tell us which mobile you are using
