Question about Kenmore Washing Machines
Kenmore Elite. When it spins it sounds like a screw or some metalic item is banging around, i wantr to remove the tub to see if there is any thing there.
  • 33 Answers
There is a bolt in the middle take it out
Posted on Nov 11, 2010
4 yr old Kenmore Elite HE when in spin cycle it makes a whining sound like a button is inside the tub.
Could be a bad bearing in the back or lots of lint somewhere causing frictions, Straighten out a metal clothes hanger and stick it around the edge, if lint starts coming out then maybe that's the problem there
Nov 08, 2014 | Kenmore Washing Machines
Sounds like loose pieces banging around during spin cycle
could be loose coins, pens, or other non-removed pocket objects.Check your drum very closely particularly around the bottom.
Aug 06, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
My kenmore 800 series has a problem during the spin cycle. more often than not the machine bangs all over the place. i redistribute the wet clothing multiple times so it spins in balance. but all the time....
unplug the machine,remove the two phillips screws that hold down the top console,flip up the console,with a screw driver pop the two metal clips,just stick the screw driver in the hole and on top of the clip and push back towards the wall and the clip will release,in between the clips you'll see the lid switch,a white plastic harness connector,unplug that then open the lid,grab the frame pull back and up and remove the frame of the washer,look at the bottom rear of the frame and the tub,you should see a spring hanging there,the hole that it was connected to rotted out,you need to drill a new hole and connect the spring to it,that spring keeps the machine from bouncing all around like it is
Nov 27, 2010 | Kenmore 22422 Top Load Washer
My kenmore elite washing machine ( TOP LOAD) is not agitating or spinning". is it the belt or the clutch. Modle # 11024952300
there's no belt in the kenmore washers,they have a motor coupling.take out the two screws that hold the top console down.flip up the console it's on hindges,next with a screw driver pop the two metal clips and unplug the lid switch harness that's in between the metal clips,then open the lid and grab the frame,pull the frame to you and up and remove the whole frame.on the bottom you'll see the pump,with a screw driver pop the two metal clips and slide off the pump.take out the two screws and pop the metal clips and slide off the motor.on the back of the motor you'll find the coupling broke,it sounds like alot of work but it takes around 20 minutes to do
Aug 30, 2010 | Kenmore 24032\24036 Top Load Washer
Bangs around when spinning
You most likely have a broken strut, or two. These are located in the bottom of the washer and can be inspected / accessed by removing the screws from the bottom of the front panel. The front access panel is seamed below the door trim and when the screws are removed you will have to pull the bottom of the panel forward slightly and allow it to drop down. The struts are a little tricky to replace and are usually held in with dowel like pins both to the tub and the base of the machine. The pins have a locking tab that will need to be pressed in to allow you to slide them out. You may have to tap them lightly with a hammer to get them to pop out after you press the tab in and start sliding them out of position.
DO NOT run the washer until you have replaced the struts as you may crack the outer tub and have a huge repair expense on your hands.
Good luck! Hope this helps you!
Jun 20, 2010 | Kenmore Elite 45986 Front Load Washer
Found broken part in my kenmore calypso washer
sorry any problem is a common problem on calypsos, its a techs nightmare. sounds like your better with new machine.
Mar 14, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite heavy duty top load washer
REMOVE 3 SCREWS FROM BOOTOM PANEL CLEANE OUT PUMP RESOLVES YOUR PROBLEM , GRINDING NOISE SOMETHIG STUCK IN PUMP WONT DRAIN,,,,
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Washer (He3t) front load
The bearing in the duet is attached to the outer rear tub of the washer. You have to remove the whole rear half of the outer tub. Take off the back and you will see all the screws around the tub where they attach together. you have to buy the whole rear half too. They wont let you replace just the bearings.
Nov 18, 2008 | Kenmore Elite 45986 Front Load Washer
Tub bangs and seems to be spinning out of round
One of the support arms on the back of the spin basket (stainless steel tub) is broken and causing it to spin in the fashion you describe. The only fix is to replace the spin basket. Using it in its current condition will cause serious damge to the outer tub shell. Let me know if you decide to replace it or need assistance locating a replacement tub. I can assist you in how to disassemble the washer and how to reinstall a new tub. Sorry...I wish this was better news.
Oct 03, 2008 | Kenmore Elite 45986 Front Load Washer
Washer tub bangs
Click on "troubleshooting" above and type "banging" after clicking "find solution", i have a couple of postings there. You could also read others.
Dec 02, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
21 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
