Question about Xerox WorkCentre 4150 Black and White Copier
How do i perform an on demand overwrite the error is 16 100 on a xerox 41550
I've lost my enablement code for my Xerox WorkCentre 5655. Can you tell me the enablement doce please sir?
Contact Your Xerox Sales Representative
If the enablement code is not known, whether this is a new machine or not, contact your Xerox Sales Representative to obtain the code. Only the Xerox Sales Representative will have access to the enablement codes.
Unfortunately, there is no way to obtain an enablement code outside of calling your Xerox sales rep for the following features:Scan to File (Network Scanning), Scan to Email, Server Fax, Network Accounting, Embedded Fax, Internet Fax, or Overwrite Security
I hope this helps///
Unfortunately
Mar 05, 2015 | Xerox Office Equipment & Supplies
This is a PEST (Print Engine Self Test) error = Printhead Left jetstack disconnect. The Left Jetstack is not drawing the expected power from the power supply.
Devices sharing the printer's AC outlet or circuit, such as another printer, coffee maker, space heater, may be placing intermittent demand on the AC circuit. This sudden demand creates a momentary AC voltage sag that causes the PEST test to fail. Verify the AC power source prior to replacing any parts for this error. Xerox recommends this printer be plugged directly into the wall outlet and not into a surge protector, battery backup or multi-outlet strip.
If none of these conditions exist, then the printhead is bad and will need replaced.
046K00530 Printhead (8500/8550)
Jan 29, 2014 | Xerox Phaser 8500/DN Printer
Xerox Phaser 8860 error code 04, 025,.46:0?
Want to resolve your printer issues online then, dial Xerox Printer Support Phone Number1877-778-8@9@6@9 anytime as you like. For further Info Click:https://goo.gl/Co2Bom
Jul 02, 2012 | Xerox 8860dn Phaser All-In-One Thermal...
I have error on my Xerox Phaser 6180MFP: 116-324 I have unplugged , restarted, checked all connections...help?
116-324: Controller Error (Illegal Exception)
To access Service Mode, press Up and Down Arrows at power ON.
Go to EEPROM Test
EEPROM Test
? Start
? Processing
? Check OK
Performs write/read/verification of the test patterns (0xff, 0xaa, 0x55, and 0x00) on one byte at every 0x400 from the first address of EEPROM.
Sep 14, 2011 | Xerox Office Equipment & Supplies
My Xerox Wokcentre 4260 is stuck on one job. Some pdf file prints first 4 pages and then just sits there not doing anything, and the job still have "printing" status, and blocks all other tasks....
Solution : Perform an On Demand Image Overwrite (ODIO) Image Overwrite Security protects against unauthorized retrieval of confidential data from the machine by removing image data that is left when jobs are processed. When started, all of the physical areas of the hard disks holding job data are overwritten with a series of alphanumeric patterns.
There are two options for On Demand Image Overwrite: Standard and Full Overwrite. Standard ODIO will overwrite all jobs stored in image data as well as fax card image data. Standard ODIO will not overwrite fax mailbox, Poll store (mailbox 0) and dial directory information, or folders created with the Store Job feature, if these features are installed on the machine. Standard overwrite takes about 30 minutes. Full overwrite takes approximately 160 minutes to complete.
NOTE: Full ODIO will overwrite and delete all fax image data, including mailboxes, Poll store and dial directories on the fax card. Full ODIO will also overwrite any images that have been stored in folders created with the Store Job feature. When On Demand Image Overwrite is initiated, the machine is taken offline until the overwrite is completed. Any existing jobs in the queue are terminated, including print, fax and LAN fax jobs.
NOTE: Overwrites can also be performed on a per-job basis, immediately after each job has been processed, using Immediate Image Overwrite. See the Related Items below for additional information.
CAUTION: The machine should not be in Diagnostics mode when the overwrite is started. (The Touch Screen indicates a status of "Diagnostics Mode". This mode is used by Customer Service Representatives when servicing the machine.)
Do not power off the machine while an overwrite is in progress.
To perform an On Demand Image Overwrite from the Control Panel:
  1. Access the Tools screen. See the Related Items below for additional information.
  2. Select [Security Setting].
  3. Select [Image Overwrite Security].
  4. Select [On Demand Image Overwrite].
  5. Select the [Standard / Full Overwrite] button to switch between the two options, and select the required option.
  6. Select [Overwrite Now].
  7. The Overwrite Confirmation screen will be displayed. Select the [Overwrite] button to begin, or select [Cancel] to cancel the On Demand Image Overwrite. The machine will be taken offline and will be unable to receive any incoming jobs. The Image Overwrite will proceed to overwrite all image data on the hard disk.
    NOTE: If Embedded Fax is installed, all Embedded Fax compact flash data will also be overwritten.
  8. When the overwrite is complete, the On Demand Image Overwrite completion screen will be displayed.
  9. Select [Close]. The Disk Overwrite Confirmation Report will print. This details the status and time of the overwrite. The Network Controller will then reboot and network functionality will be unavailable for several minutes.
    When the machine has rebooted, verify that the overwrite operation has completed by viewing the Confirmation Report (under Confirmation Details). The Job Information: Status ESS Disk parameter should read "SUCCESS".
Apr 15, 2011 | Xerox WorkCentre 4260/S Multifunction...
What is the Xerox Phaser 8400 printer error code 07.010.43:43923? Much appreciated. Thank you.
Try this:
The printer has encountered an error state without the benefit of a code. Turn the printer off for 30 seconds, then power back on.
If the Printer Error message returns, press the i button on the printer's front panel. The actual error or fault number should be displayed. Note the error or message and search the knowledge base for the error.
Also:
Based on the problem description provided, we have determined that your printer needs service.
Please turn your printer off and use one of the methods below to make arrangements for service:
If using the local service provider website, please perform the following steps:
  1. Enter your zip code in the space provided.
  2. Choose a mileage distance. The search will locate a Service Provider within the specified range if available.
  3. Click Go. The web site will return a list of Authorized Service Providers (ASP) with their company name, address, phone number, and fax number.
Feb 12, 2011 | Xerox Phaser 8400 Laser Printer
I HAVE MISPLACED MY POWER CORD FOR MY XEROX XG71D. DO YOU HAVE ANY IDEAS WHERE I MIGHT BUY ANOTHER ONE? THANKS IN ADVANCE FOR YOUR HELP....
Power cord it not special item it available in any computer venders shop. for xerox demand high quality power cord
Mar 08, 2010 | Xerox XG-71D 17" Flat Panel LCD Monitor
We have a Xerox Workcentre Pro575; it has an error that says drum life warning; we replaced the drum with another drum that we know works, but the error stays on. What else can this error mean
NOTE: Perform the following procedure to reset the Drum Cartridge counter after you replace the Drum Cartridge. Do not perform this procedure at any other time.
  1. From the Standby Mode, press the [Menu] (up arrow) button, then press [5], [2], [0], [4]. The screen will display: Change drum.
    1. Yes
    2. No
  2. Press [1], then press [Enter]. The screen will display: Completed.
  3. Press [Stop] to return to the Standby Mode.
Nov 04, 2009 | Xerox Office Equipment & Supplies
Xerox Phaser fault 37,002,47:18505
37,0XX.xx Errors - PEST Faults
AC power supplied by power sources such as uninterruptible power supplies
(UPSs) or DC-to-AC inverter systems may not supply correct voltage to
properly power up the printer. Likewise, other devices sharing the same AC
circuit can cause AC voltage sags that cause the printer to fail its AC heater
PEST tests (Print Engine Self Test). The printer may produce any of the
following disconnected heater errors:
■ Printhead jet-stack 37,002.47 or 37,003.48
Error Messages and Codes
■ Reservoir heater, 37,004.40 or 37,005.41
■ Drum heater error 37,006.42
■ Preheater error 37,008.44
■ Ink melters errors 37,009.45 thru 37,013.40
The printer includes several heaters powered by AC. The printer itself can
power up despite insufficient or irregular AC voltage but it may fail its AC
heater tests. This is due the test not measuring sufficient current flowing
through the heater at the moment the test runs.
Devices sharing the printer’s AC circuit shared, such as a laser printer, a
coffee maker, or a space heater, may be placing heavy intermittent demand
on the AC circuit. This sudden inductive demand creates momentary AC
Verify the AC power source prior to troubleshooting these errors. For wiring
diagrams to aid in diagnosing PEST faults, see “Wiring Diagrams” on
page 10-1.
8400/8500/8550/8560 PEST Description
37,001.46: Generic PEST error.
Something went wrong during the PEST process.
37,002.47: PEST Error - Printhead Left jetstack disconnect. The left jetstack is
not drawing the expected power from the supply.
Mar 17, 2009 | Xerox Phaser 8400 Laser Printer
Xerox WorkCentre 4150 Black and White Copier Logo
1,010 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
