Question about LG WM-2277HW Front Load Washer
Bobby pin is stuck under agitator in a front load machine Removed agitator cover by taking out one screw buy pin is still stuck under paddle.
  • 33 Answers
You might have to take it off
Posted on Nov 11, 2010
Not spinning
If its a front load, do you know about the clean out drain behind the lower front panel? Get ready with a bucket to catch all the water, lint, money and bobby pins coming at you. Under the door there is a panel, you will need a screw driver to get it off. Under that panel is a knob to unscrew a pull out.
Jan 01, 2014 | General Electric WHDSR316G Top Load Washer
The lock light turns on but it wont start
Had similar problem. I removed bottom front panel, took plug out let it drain then removed trash in it(coins,screws,just random stuff). Went a step further took pump out and removed back off it and found Bobby pins stuck in it. Put all back together and works fine. Make sure to have towels for when removing plug
Jun 06, 2012 | GE WSXH208A Front Load Washer
Not pumping out water how to clean filter
if this washer has a accsess panel to the water pump they usually have a filter that catches debris and bigger items before they go in the water pump and destroy it i have three girls at home who have lost small socks bobby pins and a multitude of other things in this cup it just simply screws out from the houseing by the water pump un plug your washer pull the acsess cover and uncrew the filter you should see it by the water pump if you could take a pic and put it on i could help direct you more
Mar 01, 2012 | Hotpoint Aquarius WD640 Front Load...
Coin stuck in agitator. how is agitator removed
Normally you can take the top of the agitator off with the use of a screw driver or by turning couter clockwise. Once the top is off you should see a nut or bolt. Removing this will allow the agitator to be removed.
Nov 12, 2010 | GE Profile WPRE6100G Top Load Washer
I think I have a bobby pin in my washer. It clicks when it agitates. How can I get into the drum to find if there is one?
I doubt that it's a bobby pin. The noise more than likely comes from the belt. Perhaps it's starting to fray. You can inspect it from the rear of the washer by removing the back. This diagram show the parts required to take the tub out if the belt is ok.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5226697&diagram_id=25498827#d25498827
Mar 03, 2010 | GE Energy Star WCVH6260F Front Load Washer
During the spin cycle, my maytag washer makes a rather loud clicking sound and stops spinning. It immediatly starts back and the process repeats every time the machine spins at top speed.
Hi
The problem most likely is something stuck in the water port of the drain pump.
The pump is located in the front right bottom of the machine and accessible by reoving the lower front panel, It is held in place by 4 small screws and is connected to the drain lines. Disconnect the plug for the outlet, then disconnect the power connection from the pump. Disconnect the drainlines after removing as much water possible from the drum as the water will come out of these liines when you remove them. Remove the pump, open the cover to see the impeller and hopefully the bobby pin, nail, screw, or whatever else is stuck there will be visible and easily removed. Put the pump cover back on, replace the drain lines and screws, and reconnect the power connection to the pump.
Thanks for contacting fixya.com
Sep 30, 2009 | Maytag MAV2755AWW Dependable Clean Top...
Bobby pin stuck in washing machine - high pitch noise during spin
I just had this exact issue and was able to solve it myself. I thought I was in for a $300-400 fix. It sounded like the bearings or transmission was going out it was so loud.
My first clue was from the bobby pins **** in the stainless wash tub. The first thing I would do is put a 2x4 underneath the front to prop it up and pull the belt off. Spin the three wheels down there and see if they're all smooth. In my case the water pump did not spin smooth, something was wrong.
To get to the water pump, you need to take a putty knife to push the clips in the top, one on either side and the whole top will prop open. Next there are two bolts you need to unscrew and the front will slide out. The water pump will be on the front right. You need to take a large plyers or vice grips and squeeze the clamps to pull the two hoses off (keep a towel handy because there's probably water in them yet too). Pull the hoses off and now you should be able to have access to the 3 x 10mm bolts the hold on the water pump. Pull the pump out and inspect that there isn't any thing obstructing the impeller blades. In my case two bobby pins were wedged in there making the racket. I was able to take a real long needle nose plyers and pull them out.
Putting it all back together is reverse of what is above.
Whew! thought I was going to be out some bucks for the repair tech coming out! Hopefully someone else finds this usefull!
Jan 28, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washer whines any time the agitator is moving or spinning, not while filling, etc. What might this be? I live in the middle of nowhere and my appliance repair man has died of old age. Literally.
We took the housing off the washer and started the machine, albeit carefully, and followed the squeal. Sounded like the water pump thingy in the front. Took that off from the machine but still connected to the hoses and the squeal stopped. Dipped and drained machine, removed water pump thingy and looked inside. Found a really beat up hairpin/bobby pin lodged inside! (I have two teen daughters at home) Removed pin, put back together, and wah-lah, a few hundred dollar miracle, no squeal!
Nov 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Item stuck between drum and washing tub
no has to be completely dismantled unless you can get it out throw hose, call sears buy service smart agreement will cover up to 500.00, its a 2hr 2 man job to take apart and needs new center seal , a serve smart agreement is coverage on already broken appliance and 1 yr warranty that covers taking dryer off and on
Jan 20, 2008 | Maytag MAH2400A Front Load Washer
Frigidaire affinity front loading washer
Any E20 code means your washer doesn't drain.  More than likely there is a screw, nail, coin, bobby pin, etc locking up your pump and causing it not to drain.  Keep in mind that your washer has a 1 yr warranty but some service companys will charge for this kind of repair because it is not technically covered under warranty.
Aug 21, 2007 | Frigidaire GLTR1670A Front Load Washer
LG WM-2277HW Front Load Washer Logo
154 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
