Question about HP OfficeJet 4315 All-In-One InkJet Printer
I printed from Ron Hazelton on how to install a glass sliding door. Now it won't stop printing the document. It won't let me send anything. ;;it tells me I am not on line. The fax says that my phone is off the hook. I don't know to fix this.
  • HP Master
  • 7,733 Answers
How do i enlarge print when it too small to read after printing
Reading what a Word Document, PDF, the printed paper? I am so curious. For printed paper, you have to go back to the old days of a magnifying glass. For Word to enlarge the text, you can use the slide at the bottom of the document for press CTRL + Mouse Wheel Scroll. In Adobe they are also CTRL +/-. That is CTRL and "+" to zoom in and CTRL and "-" to zoom out. For web browsers, both these tips should work. Tip: Always save from the web prior to printing. Even if it is a web page. Web browsers have never done real well with printing. That is why most sites give you a PDF to print from. !!! Note: DO NOT send sensitive information to the following suggestion !!! There are even web sites that will create a PDF of web content that you need printed nicely: pdfmyurl.com.
Apr 01, 2013 | Dell Computers & Internet
My HL 2270DW won't stop printing goobldegook. One or so lines on each page, and the printer job does not show in the cue so it can not be cancelled. I can not print any jobs because of this malfun
Has it worked before? Many of these newer printers can print what are called Postscript documents, and you may have a Postscript driver instaled instead of the regular driver, or both and have selected the wrong driver when sending the job ORyou have an internal circuit board that'sgone bad
Jan 07, 2013 | Brother HL 2270DW Laser Printer
Minolta di200f
Mam/sir
does this line appear if you put the original on the big glass and make a copy? If not then when you use the document feeder you do not use the big glass, you use the small glass check the small glass for dirt etc. and clean it. DO you print to this machine are prints OK? then narrows the field down. IF the line appears using the big glass check the image unit or the fuser the hot part can open the right door open the hot part Wait to let it cool down check that neither fuser roller has a scratch or line on it. for the image unit try to print and stop the machine by open the right door to try to catch the paper before it goes thru the hot part does you line appear if so image unit is bad .
Apr 18, 2012 | Minolta - DI200F Printer
My HP Pro 7780 has recently started making copies (through the feeder) with 2 large blank streaks down the middle of the page (lengthwise). I am worried that this is also happening when I send a fax as...
Does this happen when you print, or only when you copy? If you print out a configuration or user settings page, or print a page from the computer, is it also missing two vertical lines of print or is it only when you are copying?
If it happens when you print, you may need a cleaning, or you may need to replace the toner or drum cartridge. If it's an inkjet machine, there's a possibility there is some ink or grease on the encoder strip (a small belt-like plastic strip that goes through the print-head carriage).
If it only happens when you copy, test both the flatbed and the document feeder. If it happens on both then you may have a bad scanner. If it only happens when using the document feeder, you likely have some whiteout (or something) on the glass. When you make a copy in the flatbed, the scanner moves across your document. When you make a copy using the document feeder, the document moves across the scanner. In this case, if there is anything on the scanner glass (like whiteout) your copies will be missing a vertical line of print data (it could be white if there is whiteout on the glass, or it could be dark if something dark is on the scanner glass).
Usually you can lift the flatbed cover and look at the glass to see if anything is on it (usually at the left side of the scanner). Clean the glass, first with alcohol to remove the obstruction, and then with a little windex to remove anything the alcohol may have left behind.
Sep 23, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
Door Open
i would start by looking at the door sensor can't be closing fully hope this helps regards Jim
Apr 28, 2009 | Dell 1320c Laser Printer
Programs Lock until Printing Finished
1. Click on START, CONTROL PANEL, PRINTERS AND FAXES (or PRINTERS AND OTHER HARDWARE).
2. Right click your printer, and select PROPERTIES. (If your printer is not listed, click on VIEW INSTALLED PRINTERS first).
3. Select the ADVANCED tab.
4. Select SPOOL DOCUMENTS BEFORE PRINTING.
5. Click on APPLY (if applicable), then OK.
6. Restart your computer.
7. Try printing now.
Aug 14, 2008 | Epson Stylus Photo R300 InkJet Printer
HP PSC 1300 All in one Printer
  1. Turn on the HP PSC and lower the print-carriage access door.
    The print carriage will move into the access area. Figure 1: Opening the print-carriage access door
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot.
      NOTE: The black cartridge is on the right side of the print carriage.
    Figure 2: Removing the print cartridge
      NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab.
      CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles.
    Figure 3: Removing the plastic tape
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place.
      CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle.
    Figure 4: Inserting the print cartridge
  5. Close the print-carriage access door.
Using a photo print cartridgegtabtop.gif To use the photo print cartridge, remove the black print cartridge and insert the photo print cartridge in its place.
The photo print cartridge can be purchased separately and will optimize the quality of printed photos.
With the tri-color print cartridge and photo print cartridge installed, you have a six-ink system, which provides enhanced quality photos. For printing regular text documents, use the black print cartridge.
Use a print cartridge protector to keep either print cartridge secure when it is not being used. Figure 5: Storing the print cartridge
c00034854.jpg 1 - Inserting the print cartridge
2 - Removing the print cartridge
Aligning the print cartridgesgtabtop.gif After installing or replacing a print cartridge, the HP PSC will automatically print a cartridge alignment page.
  1. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  2. Press Scan .
    The HP PSC will align the print cartridges. During the alignment the button LED will blink until the alignment is complete.
Aug 04, 2008 | HP PSC 1350 All-In-One Thermal Printer
Just bought this product and cannot install print cartridges
Below is the document that has a Detailed Step on how to install the print cartridges.
CLICK HERE TO VIEW ==>> DOCUMENT
Thank you so much.
adonscott
Jul 19, 2008 | HP Officejet J5780 All-In-One InkJet...
HP OfficeJet 4315 All-In-One InkJet Printer Logo
64 people viewed this question
Seeker5211
Seeker5211
