Question about Delta & Single Handle Shower Faucet
I have a Delta Monitor Series jetted shower faucet. How do you remove the spindle that secures the main handle?
Where is the grub screw that has to be removed as I can't find it?
plumbing - How do I remove a stuck faucet/tap cover ...
diy.stackexchange.com/questions/.../how-do-i-remove-a-stuck-faucet-tap...
Apr 18, 2011 - Anybody can ask a question; Anybody can answer; The best ... There are total six faucets in a bathroom, two made into a bathroom basin ... The other possibility is that there's a small plastic "decorative" cap covering the screw.
How-To: Replace A Shower Faucet Cartridge ' Toolmonger
toolmonger.com/2009/12/01/how-to-replace-a-shower-faucet-cartridge/
Dec 1, 2009 - In many modern shower faucets like Delta and Moen (which is what I have) .... About a year ago, one of the bathtub faucets in my other bathroom jammedopen. .... the exact faucet I have in my shower, so you answered my first question, ...I can tighten and loosen the screw but the handle just won't come off!
Problem Removing Handle Off Of Delta Monitor 1400 Series ...
www.diychatroom.com/.../problem-removing-handle-off-delta-monitor-...
May 20, 2009 - 15 posts - ‎12 authors
... from a Delta Monitor 1400 series tub/shower single handle faucet. ... sorry for the REALLY sxxxxx question. which way to turn (loosen) the set screw. ... only suggestions i have on the issue. when a setscrew will not back off i ...
REMOVAL OF STUCK CURVED FAUCET HANDLE WITH HEX SCREW ' DIY Forums
www.diyforums.net/removal-of-stuck-curved-faucet-handle-with-hex-sc...
Feb 03, 2016 | Home
How do I turn the shower on? I just moved into a place that has a Delta series 1400 Monitor shower handle, a smooth faucet, and NO mechanism whatsoever that I can see for switching from bath to shower. Is...
There should be a dirverter on the tub spout. It will be either a knob to pull up or a ring to pull down on and hold untill the water comes out the shower head.
If there is no dirverter go buy a new tub spout with one.. The prior owners may have installed the wrong spout.
Apr 01, 2011 | Delta & Single Handle Shower Faucet
I am trying to pry the plate off on my Delta Monitor shower faucet. It must be an older model and it is not the plastic handle but a smooth stainless steel handle. It has a plate on the front that will...
I believe the older ones were held on by center threaded on piece, after you remove the handle. It's threaded on behind the handle, round cover over stem. Turn counterclockwise to remove it, then plate should come off.
Oct 31, 2010 | Delta & Single Handle Shower Faucet
I'm not getting enough hot water from my delta 14 multi shower faucet. How do I set the temp?
Go to the link below then click on download. This will bring up a pdf file for the Delta 14 series. Scroll down to page 5 for instructions from Delta on how to adjust the temperature after removing the handle.
http://www.deltafaucet.com/customersupport/documentation/T14430-LHP%20H74%20A74.html?document=mi&documentIndex=0
Jun 03, 2010 | Delta & Single Handle Shower Faucet
How do you remove the temperature knob and cover from a delta shower faucet, model 1824 (Monitor 18 series)?
http://www.deltafaucet.com/customersupport/documentation/1824-74.html?document=pd&documentIndex=0 The very center piece of the temperature setter pops off with a screw driver. Remove the screw underneath it and everything else to the handle comes off. Firmly grab decorative sleev behind handle and pull. Firmly grab round brass collar and turn counterclockwise. carefull pry cartridge from brass body.
May 22, 2010 | Delta & Single Handle Shower Faucet
I have a Delta Series 1400 faucet in the tub/shower. The handle turns left and right for Hot & cold, but I do not know how to adjust total volumne. Is the round know supposed to pull out? It does not...
hi roger,
Sorry Delta 1300 and 1400 series valves do not have a volume control. Kinda odd but that is how they are made.
Please rate this response and Good Luck, Phil
Dec 30, 2008 | Delta T13420 Chrome Classic Single Handle...
Delta & Single Handle Shower Faucet  Logo
458 people viewed this question
Top Delta Home Experts
Mike
john h
Tim Whalen
Are you a Delta Home Expert? Answer questions, earn points and help others
