Question about Kodak EasyShare C533 Digital Camera
I have a Kodak easyshare c533 camera and it won't turn on. I've tried changing the batteries, but the green light sort of flashes, but nothing else happens
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Nov 11, 2010
I have a kodak easyshare c533 camera and it won't turn on. I tried new batteries but all it does is flash the green light. Any ways to fix this?
Green light flashed, turned red, lens would not open. Put in new rechargeable batteries, still nothing. Someone here suggested to try regular AA cheapie batteries. IT WORKED!
Nov 09, 2010 | Kodak EasyShare C533 Digital Camera
Kodak EASYSHARE M1063 won't turn on
For this problem try doing the following:
  • remove the battery and the memory card
  • clean the metal copper on the battery
  • power on the camera without the memory card
If problem persist call the 18002356325 for technical support for KODAK Digital cameras
Thanks
Hope this will help
Sep 23, 2009 | Kodak EASYSHARE M1063 Digital Camera
When the camera is turned on the green light flashes and then turns to red and won't turn on. Note: batteries have been replaced.
Your fix could be as simple as cleaning the camera's battery contacts, or it could be something more serious and expensive. First try removing the batteries and cleaning the camera contacts with a small metal brush, steel wool, or fine sandpaper. If that doesn't fix the problem, check the Kodak Help Center by clicking on the link below. It uses a simple Q&A format to diagnose problems and propose solutions.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Jul 12, 2009 | Kodak EasyShare C533 Digital Camera
Camera Crashes
hi
best is to use rechargable NIMH batteries of atleast 2200MAh or above
the red flashing light is a low batt indicator
cheers
pls rate if it was any help
Jul 05, 2009 | Kodak EasyShare C533 Digital Camera
Kodak c533 wont turn on
Your lens may need adjusting. This info may help . Other People solved problem. Lots of Info on this link.
http://www.fixya.com/support/t102982-e_18_problem
Mar 22, 2009 | Kodak EasyShare C533 Digital Camera
Camera wont turn on
goto http://www.digitalcamrepair.com/self_diagnosis_page.htm
for self diagnosis.please let me help you before leaving a bad feed back.
Apr 30, 2008 | Kodak EasyShare C533 Digital Camera
Kodak Easyshare C533 Won't turn "on"
Lens drive is shot - check Kodak for repair price Will be expensive - new camera perhaps on the way?
Jul 31, 2007 | Kodak EasyShare C533 Digital Camera
Kodak EasyShare C533 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
