Question about Clarion NZ409 Car DVD Player
How to by pass parking brake - Clarion NZ409 Car DVD Player
  • 400 Answers
Find the wire for the parking brake... Get a (interrupter) toggle switch. Ground one side of the switch to a grounding point in the vehicle close to where you are gonna have it. Hook the wire for the dvd up to the other side of switch....When you want to watch dvd, flip toggle switch...
Posted on Nov 11, 2010
Need a code to by pass parking brake feature
usually not a code. it is unlawful to drive without the parking brake feature hooked up.... but the way to do it is remove the wire from the parking brake and ground it. it will then think the parking brake is on
Feb 09, 2011 | Power Acoustik PTID-8300NR Car Video...
How to adjust parking brake. do you need to take anything apart?
You cannot adjust the cables on a minivan manually. the tension is automaitcally adjusted by the self adjuster on the pedal release.
The park brake cables on this vehicle have an automatic self adjuster built into the park brake pedal mechanism. When the foot operated park brake pedal is in its released (upward most) position, a clock spring automatically adjusts the park brake cables. The park brake cables are adjusted (tensioned) just enough to remove all the slack from the cables. The automatic adjuster system will not over adjust the cables causing rear brake drag.
Due to the automatic adjust feature of the park brake pedal, adjustment of the parking brake cables on these vehicles relies on proper drum brake.
When the park brake pedal is applied the self adjuster is by-passed and the pedal operates normally to engage the park brakes.
When a service procedure needs to be performed on the park brake pedal or the park brake cables, the automatic self adjuster can be manually locked out by the service technician.
Aug 25, 2010 | 2004 Dodge Caravan
Is the park signal wire supposed to be hooked to the ground side or power side of parking brake switch? I'm trying to install a kvt 512 for a buddy, and the dvd player wont work with out the park signal.
If you want to by-pass the parking brake wire, here's how.
Most wiring harnesses have a solid orage wire for illumination of the radio2_bing.gif and also have an orange wire with a white stripe for dimming purposes. Most radios do not use this dimming feature. Connect the brake wire to this wire and your able to watch your movies whenever you want. All the wire is looking for is a signal. It cannot differentiate between a parking brake signal and a non-parking brake signal.
Apr 13, 2010 | Kenwood KVT-512 Car DVD Player
Parking brake safety bypass
here is what you need to do is, get a toggle switch and hook one side to a ground and the other side to the parking brake wire on the unit.
use the switch as a brake because you have to set brake for a few seconds then release and set again but keep it on this time.
you will have to do this every time you start the car.
Jun 26, 2009 | Dual Electronics XDVDN8190 GPS Receiver
Tighten parking brake
Need your rear brakes adjusted or the brakes are just time to be replaced. Good luck.
Apr 06, 2009 | 1994 Chevrolet Lumina
Parking brake wont engage
Find a good shop and see if the parking brake ratchet assy is broke. This is common on chevy.. TY
Mar 11, 2009 | 1999 Chevrolet Blazer
How do i by pass the parking brake no video
Well on the eclipse unit you just ground the wire for the parking brake
Jan 09, 2009 | Dual XDVD8181 Car Video Player
Clarion NZ409 Car DVD Player Logo
213 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
