How do we replace lid switch on a top loading washing machine. Model # 22622100 E-mail hesnana1725s@aol.com
  • 33 Answers
Take the cover off the back behind the timer
Posted on Nov 11, 2010
Model 110 22622100 wont spin or drain
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 13, 2011 | Washing Machines
@aol.comhave to slam the lid hard to get it to start to wash
its the lid safety switch,its located under the control panel and you need to remove the panel,then the 2 brass colored clips then remove outer unit cover and replace the switch
May 28, 2011 | Whirlpool LSR5132PQ Top Load Washer
Won't go into rinse and spin cycle
The most common cause of the problem you just described is a lid switch malfunction or lid strike (actuator) problem. Symptoms may include, filling and stopping on the intial fill cycle, stopping right after the wash cycle, not advancing to rinse or spin cycles, and a wash tub that will not drain.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike" or "Actuator") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
NOTE: You do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Your model number is actually "110.22622100". Use this as your search criteria if you order parts on line. The part number for a replacement switch is 3949238. The actuator part number is 350733.
The average price of a replacement lid switch is about $20 - $30 if you perform the repair yourself. Prices will vary between sites so shop and compare. If you have questions, or need additional assistance, please post back and let me know. This is a very simple repair that you can easily perform without the assistance of a repairman.
If this advice does not help you enough, repairclinic.com has a Repair Manual you can order to assist you with all your repairs. The part number is 1170635 and is priced at about $20. Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful to you.
Jul 04, 2010 | Kenmore 24032\24036 Top Load Washer
Require a new lid switch to fit a model 22622100 type 111 Kenmore washer, also require a service manual to find out how to remove the washer top to instal the new switch
http://www.appliancepartspros.com/part_details.aspx?part_id=3100001&rdr=%2fmodelsearch_model.aspx%3fmodel_id%3d415134
Check out that link for the switch.
As for the washer top, you don't remove just the top, you remove the whole cabinet. Remove the two end cap trim pieces from the control panel, (just pry them off) remove the two screws securing the panel to the cabinet. Flip the control panel back on it's hinges. Unhook the lid switch wire harness, and use a screwdriver to pop out the two gold clips that secure the cabinet to the back panel. You should now be able to tilt the cabinet slightly forward (towards yourself) and pull off the base. You now have full access to replace the lid switch.
Dec 30, 2009 | Kenmore Washing Machines
My Kenmore washer 22622100 is broken - the washer stops between the rinse and spin cycle. It simply stops.
The following link explains step-by-step how to replace a lid switch:
http://www.fixya.com/support/r385198-replacing_lid_switch
Replacements can be purchased at searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com, or repairclinic.com. All these sites offer great service with competitive pricing, so shop all of them for the best deals. The first two web sites have excellent exploded view diagrams of your appliance to aid in parts location and assembly.
If you have any questions about this repair, or if you require additional assistance, please let me know. I hope this helps you.
Jul 19, 2009 | Kenmore 22422 Top Load Washer
I have a kenmore top load washer that will not go into spin. how can i check if the timer is good?model # 110 91278100
Most of these spin related problems are attributed to a lid switch malfunction. A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
Jun 29, 2009 | Kenmore 22422 Top Load Washer
I need to know how to replace or fix the spin cycle on a kenmore 80 top load washe, the waser will not spin.
A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
Jun 28, 2009 | Kenmore 23012 Top Load Washer
Kenmore 22622100 Top Load Washer won't drain the water, nor rinse
HI!!! you seem to have a bad lid switch on your washer..I would also check the timer on it good lucck.
Feb 13, 2009 | Kenmore 22422 Top Load Washer
Replacing lid switch
me too...exact same washer and same problem...how do u fix it?
Apr 20, 2008 | Washing Machines
Washing Machines Logo
88 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
