Question about Maytag Dryers
Dryer tumbler makes noise as it begians to spin
  • 33 Answers
Its getting wore out
Posted on Nov 11, 2010
Dryer making loud vibrating noise
In all likelihood, the belt that runs the tumbler is loose, causing the tumbler to rotate off center. While it takes a few minutes, the front of the dryer should be removable and you can take the tumbler out and replace the belt.
Oct 11, 2014 | Amana Dryers
Grinding noise when drum spins
they r hard rubber attachments that keep the tumbler from grinding metal to metal. go to local appliance center 15bucks a set. easy fix
Mar 17, 2013 | Maytag ADE7005AYW Dryer
The tumbler is making alot of noise and the dryer is getting extremely hot.
check that the drumb (tumbler) is turning, sounds like ur belt is broken and not turning but the pulley wheel is spinning and making a racket...
Apr 15, 2011 | Kenmore Dryers
Maytag atlantis dryer all the sudden will not turn on or make any noise.
I suspect the door safety switch is broken. If not check one, some dryers have two, high limits. These are safety switches that keep the tumbler from spinning when door opened, and prevent the dryer from overheating
Feb 01, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Drum fails to operate at times and making a screaching noise. Sometimes drum needs to be spun by hand to get it operating and spinning.
All dryers have to have a way of allowing the tumbler (that's the thing you put the clothes in) to turn freely, not all of them are the same tho,some use bearings, some use slides,others use rollers. Over time these rollers will need to be oiled,the slides will get thin and start metal to metal contact causing a noise, The rear bearings will then start to make their way to china and cause the tumbler to rub into the heating element and OUCH! These things will cause the motor to prematurely DIE! Its best to examine the dryers, rollers, and slides when you first hear the noise, but who does?
Sep 13, 2009 | Dryers
Dryer is making a thumping sound as it spins
Dryer tumbler does not spin freely. Makes grinding noise. checked belt and pulley. ok. two wheels that the tumbler rests on, one wheel is free wheeling, while other is stiff.
These wheels are your drum rollers,and you should go ahead and change them both out while you're in there. We have parts so callus with your brand and model number and we'll be sure to get these out to you right away to get you up and running again!
Sep 11, 2009 | Dryers
Beko tumble dryer was making strange noise now no heat but still spinning
How old is your dryer? strage noise usually take place if the unit is old and worn out. I dont know of any washer or dryer doesn't make noise after years of using. The more you use the more ware and tear and noise come from the unit. Noise can be the belt loose or tumbler padding or flange, connected to a simple bushing is worn out, making the unit woobily noisy. No heat mean your heating elements probably burnt out need replacing which will cost 80-100 bucks. its fairly easy to replace once you remove the back cover. To find out what making that noise, the best thing to do is run the dryer with the back cover off by look and listhen and see what making that noise.
Jul 08, 2009 | Dryers
Rubbing noise
Try checking the glide's under the front of the drum, the drum rest on the glide's to help it spin with little or no friction.
Apr 06, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Electric dryer makes a rumbling when tumbler is turning.
Check the drum bearing, a load noise, and often spinning problems are symptoms of a bad drum bearing.The bearing is at the base of the drum and accessing it is not easy.
You can find diagrams and replacement parts entering model number here.
Jan 06, 2009 | Maytag PYE2300AY Electric Dryer
Dryers Logo
50 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
