Question about Sunpentown Heating & Cooling
Sunpentown WA-1220M room Air conditioner (on wheels whit exhaust hose...) can be run but 5-6 hours before the bucket it full of water. WE have had this unit for at least 2 years, I think 3, and this has only happened maybe three times. Now it happens every single night... The obvious answer is that I moved to the jungle, however, this is not true. I have not moved residences or even placement of the unit in the house.
  • swaggyp Jun 18, 2008
    the only hose is the exhaust hose that comes out the back that is in the window, is that what you mean? Or do I have to take this thing apart? Thanks for your help.
    Master:
  • 788 Answers
See here: http://www.allergyconsumerreview.com/dehumidifier-advice-troubleshooting.html
It would seem that the unit is working properly. Did you recentrly change it's location? Is it near a bathroom door?
Posted on Jun 17, 2008
    Master:
  • 555 Answers
Check the hose for a leak.
  • Matt Jurach
    Matt Jurach Jun 17, 2008
    What used to re-circulate might now be leaving the system via a leak.
My everstar blows hot air out the back and cold air in front i want all cold air
this style unit needs an exhaust hose attached to the rearand be placed out the window to exhaust the heat that is removed from the air in the room, you will also have to empty the condensate drain bucket when it gets full.
Jul 23, 2011 | Fedders Portable Dual Hose Electronic...
Ac is working fine on cool then it goes to fan and the air aint cold anymore
Fan mode only moves the air around the Room it will not cool make sure your on a cooling only setting
Jul 03, 2011 | Sunpentown WA-1200E Air Conditioner
It was working good last year, but this year we have to drain the water every 4 or 6 hours beacause the unit stop workin because all the water.
Normal Operation. Part of the unit's job is to dehumidify. If it is more humid this year than last, it will fill up quicker. One of the pains of a portable A/C unit.
Jul 18, 2010 | Sunpentown 12,000 BTU Portable Air...
Need instruction manual for Sunpentown WA-7500M
You can get the manual on the link below I hop it will help you.
http://www.sylvane.com/images/productpages/sunpentown/manuals/WA-7500M.pdf
Good Luck and please rate 4 thumbs up for the free answer
Jun 19, 2010 | Sunpentown 7500 BTU Portable Air...
Vent hose for a WA-903
Here is the Sunpentown Site, manufacturer of your A/C. They should be able to assist you with replacement parts for your unit, if available.
Hope this helps!
Mar 30, 2010 | Heating & Cooling
No water in bucket when AC tells me its full
remove the drain bucket and look inside. there should be a hose that runs from the evaperator to the drain bucket. if you can blow air through hose to see if it is clogged. or try to take casing off and pour a little bleach/water mixture down tube , it probably has some mold built up in it
Aug 18, 2009 | Danby DPAC8020 Air Conditioner
How do you get rid of the molding smell
Is a very siple solution, If is a ruge, need to steam vacum and then use to fans 20in for blowing in from a window and the other fan 20in at other window to exhust out the room to create a draft of air exshenge ontil the umidity dry. Depends the sise of the room and the amount of windows to select howmany fans you need.
Aug 11, 2009 | Sunpentown WA-1200H Air Conditioner
My Sunpentown WA-1210E airconditioner stopped working. It emitted several beeps and the power light is blinking continuously. When I unplug, wait a few minutes and replug in the unit, it shows the same...
Have you checked the water container in the unit? It has a float switch that when it is full it will not allow the unit to run so that it will avoid spilling water on to the floor. Hope this helps 2rns4u <*{{{>(
Jun 29, 2009 | Sunpentown WA-1210E Air Conditioner
My Sunpentown WA-1220E portable air conditioner is not working. Comp light is flashing (red light). Any idea what could be wrong?
Sounds like compressor failure, overheat or some other reason can't get started. Make sure everything is clear and unplug and let it set for a while and try again. If that don't help take it to shop.
Jun 28, 2009 | Sunpentown WA-1220E Portable Air...
Why is my sunpentown WA-1210H portable AC not blowing cold air anymore?
Might be a dirty filter, a burnt compressor wire or a bad capacitor. Or it could be a bad thermostat.
May 10, 2009 | Sunpentown WA-1220E Portable Air...
Heating & Cooling Logo
235 people viewed this question
Top Sunpentown Heating & Cooling Experts
Dan Webster
Dan Webster
Steve F
Mister Danger
Are you a Sunpentown Heating and Cooling Expert? Answer questions, earn points and help others
