Question about Harley Davidson HarleyDavidson FLHTCU Ultra Classic Electra Glide
I have a 2009 flhtc i started it up and revved it up it immediatley shut off and would't restart we checked the fuse box and found out the ecm fuse was blown we put in 3 more fuses and they all blew please help
  • 5 more comments
  • roadking_200 Nov 11, 2010
    there r 2 falt codes p1003 and u1016
    i have know idea what that means
    i was hoping i would't have to take it to dealer ok thanks for the info
    ok i will check the wires thank you
  • roadking_200 Nov 13, 2010
    the wires seem to be ok it's probably the ecm
  • roadking_200 Nov 18, 2010
    thank you boy i wish i would of talk to u a few days ago i talked to the harley dealership where i bought it they r going to take care of the it no charge thanks for your help pete
    President:
  • 1,509 Answers
You might have to go though a crash reset. The way to find a reason a fuse blew on any thing is to put a test light across where the fuse goes and disconect things till the ligh goes out. ( a test ligh is an ice pick looking tool with a wire coming out of the end of the handle with a clip on the end, the handle is clear and theres a light bulbinside and it's connected to the wire with the clip and the other side to the ice pick end). Connect this as the fuse and it'll light now remove electrical conectors till you disconected somthing thea makes the light go out sure the ecm is going to draw power but not enough to light the light the same as across the battery. the coil the oxogen sensers. the wire gets against the exhaust and melts and shorts to ground. the ecm has a conector unplug it and see if it stopps the short thenwith the test ligh tconnected to power and touch the end to each conectorin the plug and as the ones light the light follw them to where they go and see if it'sshortedor bad. Might take awhile to test as some of the wires will begrounds.
Posted on Nov 17, 2010
  • 2,299 Answers
You either have a wire that is shorted going to the ECM or the ECM is bad itself. Trace the wires between the fuse and the ECM to make sure that none of the wires are grounding out. If all of the wires all check out ok then more than likely something internally in the ECM has shorted.
Posted on Nov 11, 2010
  • 643 Answers
Evidently it has to be a wiring or a connection issue. The kicker is, it is under warranty so you shouldn't have to do a damn thing to it and let the dealer take care of it. I understand that it may mess up any weekend plans that you had, but....
Anyway if you feel the need, you would start buy pulling the fairing and checking the contacts at the back of the ignition switch and pulling the ignition switch off and checking it all out. If you don't find a problem there you would have to trace the wiring.Loosen your right handlebar clamp and make sure the wires are in the grove. If they are pinched you'll blow that fuse. Make sure the switch housing and the handlebar clamp are snug together. Did you have the grips changed at the dealer?
  • 4 more comments
  • Tre Elkins Nov 11, 2010
    P1003 System relay Contacts Open EFI,U1016 Loss of ECM Serial Data, Vehicle Speed, Vehicle Inhibit Motion or Powertrain Security Status TSM/TSSM
    that is what the codes are, you said p1003, and u1016
    p1003 system relay contacts open efi (electronic fuel injection)
    u1016 loss of ecm serial data,vehicle speed, inhibit motion or powertrain security status tcm/tssm
    the codes are referring to an ecm problem, not just the fuse it needs to be put on a digitach machine at the harley service center.
    Your welcome,sorry for the mix up earlier it was a misunderstanding.
  • Tre Elkins Nov 13, 2010
    it needs to go the dealer, there is a problem with the ecm.... needs to be put on a digitach machine to identify the cause of the error messages.
    did you find out anything about the bike, i ride too i was just wondering if your problem was solved?
Location of anti theft fuse on 2008 ford focus
Fuse 20 is the ECM fuse. No car would have one specifically for the antitheft circuit as you could pull the fuse and drive away. The ECM runs the antitheft system as well as the engine management. As long as the chip in the key matches the chip in the ignition lock, the ECM will release power to the ignition circuit.
Do you have an OBD11 code reader or access to one? That may tell you where the fault is.
http://www.gridgit.com/postpic/2009/11/ford-focus-fuse-box-diagram_486663.jpg
http://circuitswiring.com/2008-ford-focus-5d-r-fuse-box-diagram/
fuse on 2008 ford focus Google Search
Dec 18, 2016 | Ford Cars & Trucks
How to fix code p1682 Saturn aura 2009?
Look here about that code
http://engine-codes.com/p1682_saturn.html
Have you (or the dealer) checked the FUSES ???
Is the starter switch ok.?
Does it run OK ?
I dont think much of your so called dealer !!! "ECM will not ground powertrain relay" What sort of a report is that ??????
Sep 20, 2014 | Saturn 2009 Aura XE
Emergency fuel shut off
There is no emergency shutoff for the fuel pump. It is controlled from the ECM. There is a fuel pump relay in the relay/fuse box under the hood. But if you have power to the pump, it is probably ok. Having had a 1999 Dakota I had a situation where I was having intermittent shutdowns when driving that became more and more frequent. Sometimes I could restart immediately, other times I had to wait from 10-30 minutes before I could get a restart. I assumed a faulty fuel pump and replaced it only to find that it did not solve my problem. I researched the issue and found that the Dakotas and Durangos have a tendency to have faulty crankshaft position sensors. It will mimic a fuel pump issue since when the ECM loses sensor input, it shuts off the fuel pump. Test the pump this way - in a quiet setting, turn the key to the ON position, but do not crank the engine. With the drivers door open listen for a 2-3 second humming sound from the rear of the truck. This is the fuel pump priming the system to get fuel rail pressure. What then happens is once you start cranking and the engine fires, the ECM turns the pump on full-time. If the crank sensor is bad, the ECM cannot see that the engine is turning over and does not generate spark or fuel injector pulses, so even the fuel pump prime works, if it worked won't start the engine. At least if you hear the prime, you'll know the pump is functioning.
Sep 08, 2014 | 1999 Dodge Dakota
2009 flhtc wont start not turn over
Check your main fuse an get back with me, it's under seat 30a
Apr 27, 2014 | 2005 Yamaha YZF-R1
Engine cranks but won't start
ok first u should check all ur fuses and make sure that they all work and none r busted and then check the fuse box for the smell of brunt wires the fues box sometime needs to be checked
Nov 29, 2013 | Nissan Pathfinder Cars & Trucks
Suggested Solution 2002 Land Rover Discovery Series II Logo Problem with 2002 Discovery Series II Starts fine when cold, after running dies on idle then wont start 2002 land rover discovery, starts fine...
The ignition system is controlled by the ECM. Check power at fuse box in on right side under dash. Check fuses right side engine compartmentlower dash panel if all OK check power to ECM located right side "A" pillar in alloy box. this unit could be faulty if no spark at coils, assuming they have been connected correctly. may have to get tested for codes at L/R dealer or someone with test tool. Another source of problem may well be flat battery in transponder key. The indicator light on the dash willflash rapidly for 10 seconds if the vehicle has been unlocked with the remote and the drivers door is opened if the battery in remote is getting low
Dec 02, 2012 | 2004 Land Rover Discovery
Subaru impreza 1.6 2005- car was flooded about 4 inches inside. ECM programs were wiped out. Reprogrammed computers. Car statred and run. When swithed off, did not restart. Found that the programm was...
You must ensure everything is dry, including wire harnesses and realy/fuse boxes!!The computer may have gone bad or internally its has moisture!!
Sep 26, 2010 | 2005 Subaru Impreza
Harley Davidson HarleyDavidson FLHTCU Ultra Classic Electra Glide Logo
178 people viewed this question
Top Harley Davidson Toys Experts
Tre Elkins
ray gallant
L Pfaff
L Pfaff
Are you a Harley Davidson Toy Expert? Answer questions, earn points and help others
