Question about Whirlpool LER5636P Electric Dryer
Dryer door won't stay closed
Took dryer door off hinges and then reassembled. The door closes but after a few seconds it pops open and won't stay closed.
  • 417 Answers
shut off the breaker- pull the female receptacle clasp out of the front with flat screwdriver and needle nose and squeeze the back of it gently with pliers, replace, if its busted and you get mad, you can buy a standard padlock and latch and install that, that helps in other ways as well, careful to steer clear and watch the inner wall for wires and clearances if your going to retrofit that.
J
Posted on Jul 11, 2008
Cannot get dryer door to close/latch properly.
Hi stay at home MOM
  1. what is the Model of Dryer?
  2. do you pull to open or push button to open DRYER Door?
  3. hinges on the right or the left?
  4. door inner n outer panels plastic?
  5. is there a door seal on the door?
  6. when you did your removal of lint, did you remove DOOR?
  7. picture front of dryer area and door of dryer will help.
Sep 27, 2014 | Dryers
My KitchenAid Dishwasher door won't stay closed. It keeps popping open after a few seconds.
I experienced the same problem after my tension cables broke. The door fell open with such force that it bent the hinges a little. If you've replaced the tension strings (which you should do every 5-8 years) then you don't have to replace the latch. I did and it didn't solve the problem.
Here's the solution:
Put a towel at the bottom of each side of the door by the hinge.
Push the door closed a couple of times to bend back the hinges.
Remove the towels and you're back in action.
Good luck
Aug 11, 2012 | KitchenAid Dishwashers
I HAVE A KENMORE 90 SERIES AND THE DOOR KEEPS ON OPENING, SO I TOOK ALL OF THE CLOTHES OUT TO SEE IF THERE WAS TO MUCH IN IT, AND EVEN WITH NO CLOTHES IT OPENS?? IT DOSENT APPEAR ANYTHING IS BLOCKING THE...
Inspect the door and when you open it, does the latch hold the door closed? If not the dryer door / latch may need to be replaced.
But check the door as it opens... the door hinges may have been damaged, causing the door to not close properly and the latch may not be damaged, only the hinges.
Good Luck!
Jan 03, 2010 | Kenmore 62602 Electric Dryer
Whirlpool Front Loader Dryer Door will NOT stay closed
I have the same issue with the door popping open. If you push hard on the bottom of the door then it snaps in. I think the bottom latch is broken or misalligned.
Oct 17, 2009 | Whirlpool GEW9250 Electric Dryer
Door does not stay closed
your door clip needs to be replaced or realign
your door
Jun 11, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Dyer door won't stay closed
replace the door latch...if someone put a load of clothes are use it for a table,,and bent the hinges to far down ,,replace hinge..if you need part number ..onthejob
Jan 06, 2009 | Kenmore 63942 Dryer
Dryer door pops open. leaves burn marks on clothes.
check to see if you have bent door hinges first, do this by opening the door all the way down and see if it is level with the floor. if it goes past level then the hinges are bent.
guess someone may have fell on the door or used it as a step.
if so, then you can take a hand towel and roll it up, then put it at the bottom of the door and close the door gently to "bend" the hinges back into place. this will aloow the door to stay closed and should also take care of the "burn" marks on your clothes.
i would guess the unit was overheating from the door not closing right allowing air to enter around the door. that will cause the unit to overheat and leave marks on your clothes.
Dec 28, 2008 | Kenmore 63942 Dryer
Sub-zero 500 series refrigerator door wont stay closed
If Your Refrigerator's Freezer Door Pops Open When You Close the Fresh Food Door... If a 'top-freezer' refrigerator's freezer door pops open when the larger fresh food door's closed, it's actually a good thing. That tells us the seals are in great shape, sealing well.
Some freezer door 'pop' is unavoidable bc the bottom door's so much larger than the top one and the hydraulic effect of compressing all that air kicks in. The two compartments share the same air via a duct between them, and that compressed air rushes up into the freezer compartment and can 'pop' the door.
To improve the situation, apply a few drops of oil (sewing machine oil or 'three in one' - NOT WD-40) to each freezer door hinge pin. (Even better: if you can, pull the doors and coat the hinge pins with petroleum jelly). This will help the freezer door swing back closed by itself. The freezer door usually stays ajar because it's binding a bit, and that's usually caused by it's swinging 'dry', with no lubrication.
It’s also a good idea to ‘kick’ the habit of letting the refrig door close hard.
Sep 04, 2008 | Refrigerators
Whirlpool LER5636P Electric Dryer Logo
219 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
