Question about Singer CE-100 Futura Computerized Sewing Machine
I have a ce 100 and the bobbin thread comes up and gets into my embroidery pattern. how do i loosen the top tension to stop this from happening. my purple flower has white in it from the bobbin :(
    Novelist:
  • 233 Answers
Just an FYI-the bobbin thread needs to match your top thread. The majority of the thread that appears in the top of your embroidery actually IS the bobbin thread. The machine is working correctly. Don't use a bobbin full of white thread-instead, thread a bobbin with the color your doing the embroidery work in to match and you will have a perfectly beautiful embroidery.
Posted on Apr 04, 2011
My janome M/C 500e when I do any embroidery the bobbin thread comes through to the top of the material
Adjust the bottom tension, it needs to be looser. The top tension may also be too tight. Try loosening them just 1/4 turn and see if that helps.
Jan 02, 2018 | Janome Sewing Machines
I have a Bernina 145 S activa and I can't get my satin stitch to work , it brings the bobbin thread to the top , what can I do ?
Do you use stabilizer when you are satin stitching? I had a teacher who also hooped the fabric with a spring-loaded embroidery hoop (turned upside-down under the presser foot so the fabric is flat against the needle plate) that would keep the fabric taut.
It is not uncommon for bobbin thread to rise to the top when doing embroidery, satin stitch, etc., especially if you are using lighter-weight thread than usual. You would normally loosen the upper tension so the upper thread will sink into the fabric. However, if loosened upper tension is not doing enough, you may need to adjust bobbin tension when doing embroidery, applique... You might try tightening the bobbin tension just a smidgen to get the bobbin thread to stay below the fabric. Be sure to mark the bobbin case before making any adjustments so you can return it to the original setting when finished with the satin stitch. (If you do a lot of satin stitch or applique, etc., you may want to invest in a separate bobbin case that is set up only for doing that kind of work--saves having to alter the bobbin tension frequently.)
Sewing Perfect Satin Stitch Wildly Wonderful Wearables Patterns Notions...
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0ahUKEwiRr76k0sbLAhXBKGMKHei6AfIQFggqMAI&url=http%3A%2F%2Fmachinequilting.mqumag.com%2Fwp-content%2Fuploads%2F2014%2F12%2FSatin-Stitch-Techniques-Part-1.pdf&usg=AFQjCNFXYKp2C-RJEAAUMWwApqZlU895uQ&cad=rja
Mar 16, 2016 | Bernina Sewing Machines
Bobbin thread shows on embroidery pattern
The bobbin thread is being pulled too hard by the top thread. The idea is to get an even pull similar to a tug of war. When it is even the thread will form a knot in the middle of the fabric.
To fix this so the top thread isn't pulling too hard lower the tension of the top thread. This should fix it.
May 08, 2015 | Janome Memory Craft 10000
Have a c-150 furtura ...i'm getting a bad stitch on the bobbin thread with both reg and embroidery stitching how do i fix this been in repair shop 3 times comes back with still bad stitch they use...
ANOTHER THING IS TO CHECK THE TENSION OF THE BOBBIN THREAD. MAKE SURE THE THREAD YOU ARE USING IS GOOD THREAD THAT DOESN'T PULL THE COTTON UP AND CAUSE A PUFF BALL ON THE NEEDLE. CHECK THE WAY YOU ARE LOADING THE TOP THREAD. ALWAYS DO THIS WHILE THE FOOT IS UP SO THAT YOU CAN CONTINUOUSLY GIVE TUGS THROUGH EACH OF THE GUIDES. THIS HAS TO BE LITTLE TENSION WITH NO SNAGS.
Apr 23, 2014 | Singer CE-100 Futura Computerized Sewing...
I have a Singer Futura XL 400 the bobbin thread is showing on the top
Tension between top and bottom is a BALANCE, and when the bobbin thread shows on top, it means that your top tension is tighter than your bobbin tension, so it is pulling the bobbin thread up above the fabric.
Loosen the top tension to balance it--it should only take a couple of "ticks"--no more than one number. Loosening the top tension, by the way, is AWAY from the "S".
Apr 04, 2014 | Singer Futura Xl-400 All-In-One Sewing And...
How can i embroider with my artista 165
Try loosening your top tension or tightening your bobbin tension.
Nov 01, 2013 | Sewing Machines
When emroidering, the thread from the bobbin is showing through on the top embroidered pattern. Any suggestions
Make sure to use bobbin thread for machine embroidery, it is heavier and pulls the top thread slightly to the back of the design.
You could loosen the tension or use a double layer of stabilizer.
Mar 05, 2010 | Brother PC8500D
Bobbin thread is coming to top when embroidering. I have changed needle and re-threaded several times
Feb 16, 2010 | Singer CE-100 Futura Computerized Sewing...
Bobbin thread
Not completely sure on your model but you have to adjust (loosen) the tension on the top thread to match the tension on the bottom thread. Usually there is a wheel on the upper right of the machine. the tension adjust is the knob inside that wheel. Turn counter clockwise about 1/8 turn. Then try and repeat until it works. Check owners manual for top thread tension adjustment if needed.
Good luck.
Please rate me.
Nov 21, 2009 | Sewing Machines
Singer CE-100 Futura Computerized Sewing Machine Logo
178 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
