Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I have a sears model # 139.655000. The remotes have 9 dip switches. I need the transmission frequency so I can match up the right replacement remote.
    President:
  • 3,197 Answers
Your opener is very old and I'm positive you can no longer get the remotes. You might look into one of these.
Craftsman - Model #00953751000
It is a universal remote and receiver that operates on the new frequency and has the rolling code feature.
Posted on Nov 12, 2010
We have an old sears garage door opener with one remote. it's model 139536006. There is no "Learning Button" on the motor, only a series of 9 code or dip switches that have to be set in one of...
You don't need the original switch positions. Make sure the row of switches in the motor unit are set exactly the way the remote is. The switches are normally marked + 0 -. Move all of them to the plus sign and try.
Jan 12, 2011 | Sears Craftsman LiftMaster Chamberlain...
How can I reprogram an old style 61LM to a garage door with a learn button? Thanks!
This Liftmaster 61LM remote is the equivalent remote t? the Sears Craftsman 139 model number listed above. It h?? dip switches inside the battery compartment that ??? match up w?th ???r existing remote t? m?k? ?t open ???r garage door. There is also a set ?f dip switches ?n the overhead opener itself ?f ??? n? longer h??? a working remote. It ?h???? b? easy t? find ?n the garage door opener. This remote operates ?n a 390 MHZ Frequency, and works ?n models fr?m 1984-1992 essentially.
There will be a colored learn button on the motor head. Press and release this button and then press the button on the remote. That is it. Thanks BB Sorry about the lousy question marks in the last post
May 13, 2010 | liftmaster Chamberlain Garage Door Opener...
Th?? Liftmaster 61LM remote ?? th? equivalent remote tο th? Sears Craftsman 139 model number listed above. It h?? dip switches inside th? battery compartment th?t ?ου match up w?th ?ουr existing remote tο m?k? ?t open ?ουr garage door. Th?r? ?? ???ο a set οf dip switches οn th? overhead opener itself ?f ?ου nο longer h?ν? a working remote. It ?hου?? b? easy tο find οn th? garage door opener. Th?? remote operates οn a 390 MHZ Frequency, ?n? works οn models frοm 1984-1992 essentially.
Mar 21, 2010 | liftmaster Chamberlain Garage Door Opener...
How to set dip switches on remote for Chamberlain Liftmaster 1000
I would go with a chamberlain clicker on this issue. These remote are phased out and the 9 dips don't work well with them. Thanks BB
Mar 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener will not open or close with remotes
Put new batteries in the remotes.
Check the DIP switches in the opener
Check the dip switches in the remotes. They must match the opener.
Feb 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Need to match DIP switchs on a universal garage door remote
I find Clicker products confusing. Might want to buy whole new replacement readio control set. how old is operator?
Jan 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Remote
open the remote there are dip switches in side and also the same looking dip switches are in the door opener check to see if they match
Sep 23, 2008 | Sears Craftsman LiftMaster Chamberlain...
Installed
The dip switches on the remote and on the fan have to match - which makes the remote and the fan on the same radio frequency so they can talk to each other. They all come with the same default setup of the dip switches (all in the "on" position and therefore they are all on the same radio frequency). That's fine unless there is a similar remote control fan nearby. So a remote might talk to several new fans if they are similar brand or same remote etc on the default dip switch settings and therefore same radio frequency. It's up to you to change the dip switches if you need to. You need to. They give you the ability to change the frequency so you don't control a similar fan down the hall, upstairs etc , while also controlling the one in the room that you intended to control ie your problem. As long as the remote and the fan match, they will talk to each other. So you have to change the dip switches on one of the remotes and the fan you are using that remote on to something different, but matching. There are usually four dip switches, usually all in the "on" position. So, for example, change the first dip switch to off on the remote and do the same to the fan - turn first dip switch off. You'll probably have to take the fan down and take off the top to get at the dip switches. That should fix the problem.
My fan: Hampton Bay 54 In. Brushed Steel with Remote Model 55295
Mar 08, 2008 | Hampton Bay 54 In. Flemish Pewter Ceiling...
Remote Control Problem
I had this problem. One day everything worked. The next day the fan ran at 1 speed and the remote didn't turn on the light, change fan speed, nothing. I changed batteries on the remote - no good. As you should know, the dip switches on the remote and on the fan have to match - which makes the remote and the fan on the same radio frequency so they can talk to each other. (They let you change radio frequency so that you don't control a similar fan down the hall as well as the one in the room that you intended to control.) Anyway, come to find out from the fan guy at Home Depot that sometime the dip switches on the fan "fall" out of place leaving the remote unable to talk to the fan. Sounded crazy, but sure enough one of the dip switches on the fan wasn't tightly in place. Once all the dip switches were tightly in place (with the fan dip switches matching the remote dip switches) everything ran fine. To change the dip switches on my fan that meant uninstalling the fan from the ceiling and taking the big top cover off to expose the dip switches.
Dec 23, 2007 | Hampton Bay 54 In. Flemish Pewter Ceiling...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
546 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
