Question about Poulan Garden
Safety kick-back is broke. can this be fixed?
  • 7,733 Answers
Battery spring broke on wii fit balance board
I had a similar issue when my kids mixed rechargeable and regular batteries in the Wii balance board. The acid leaked and the springs corroded. But I figured out a quick fix - see photos. The springs look just like the spring-end of a safety pin, so I just snipped the ends of two safety pins and fixed them in with needle-nose pliers. Safety pins conduct electricity and the fix works fine. Cheers.11_25_2012_7_33_33_pm.jpg11_25_2012_7_33_48_pm.jpg11_25_2012_7_34_04_pm.jpg11_25_2012_7_34_17_pm.jpg
May 27, 2012 | Nintendo Wii Fit - Balance Board + Game...
Honda rebel 250 2004, clutch cover had a severe leak, resealed the cover reassembled now the bike shuts down as soon as you put it in gear. Nothing changed but the gasket. What's my main malfunction?...
Did you mess around at the lever. Adjust the clutch lever afterwards? There are two wires on a safety switch there. If the switch got broke or the wires unplugged may cause this.
Also check for a safety switch on the kick stand. And lastly, without looking (I have my mom's 87 Rebel in my garage) I think there is a transmission switch but believe its behind a cover on the left side of the motor.
Aug 30, 2011 | Honda Rebel Motorcycles
2003 Mercury Mountaineer, rear glass hatch latches broke. Dealer replaced and now glass won't open. $246 to replace relay module. It worked fire prior to them fixing latches. Could they have somehow caused...
did it stop working while it was in the shop or a day or two later?
if it broke in the shop it would fall into the duty of care to your vehicle. kick up a fuss if you havnt already paid for it. but if you have, goodluck getting any money back from a dealer.,
Sep 20, 2010 | 2003 Mercury Mountaineer
I kicked my emichine computer and it broke. First the screen went slightly fuzzy and when i turned it off and turned it back on and it wouldnt show what the cpu was thinking on the screen.What could be...
I would check the components inside the case...sounds like something wiggled loose while you were kicking it. Open the case...first check that all the cards (pci/video/RAM) are properly seated in their slots. Next make sure the hard drive plugs havn't wiggled loose. Post back if it still doesn't work
Jul 18, 2010 | E-Machines eMachines Desktop PC
Back brake broke on Huffy Tundra 24inch bicycle how do we fix it?
It could be anything between the brake lever and the wheel rim making it "Broke". If you care about the safety of the rider take it to a real Bike Shop for evaluation.
Mar 31, 2010 | Cycling
Just getting started with a new RCS1835. The motor goes but the chain isn't engaged. Is there another brake I need to release?
The plastic safety kick back may be engaged. 1) unplug the saw. 2) push the kick back safety ahead then pull it back ( it is the guard in front of the handle)
Now if your electric motor is turning, but the chain sproket is not, it may well be the clutch. Tap it with a small hammer, make sure it is free and not hanging up.
Jan 30, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Gas Furnace trouble
the thermostat sends a signal to the circuit board. Not knowing anymore than I do about your heater or furnace I would suggest that that is a good place to start. Any limit or safety switch wouldnt coincidentally shut off the heater when it reached the set temp.
Jan 09, 2010 | Heating & Cooling
Kick start broke and case broke
the kick start broke or did the shaft that the kick start bolts to?, if the shaft broke, you will need to remove the case and replace the shaft. as for the case, depends on how bad it broke, some people can weld alum. but i would buy a new case. and then install kick start on new shaft
Sep 25, 2009 | 2004 kawasaki KLX 125
Garden Logo
19 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
