Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Scanning to SMB
Hey,
Ive been trying to scan to my PC from the C250. I follow the directions and set up the IP address and destination but every time i press the scan button it says job done improperly..Any suggestions??
Thanks a million
DJ
    Champion:
  • 214 Answers
You have to input your computer name instead of ip address. also you may use reference or something to look up your computer form lan network, thats the best way. and if you find your computer and shared folder and first scan is completed successfully you may add this path to address book
Posted on Jun 19, 2008
Fuji xerox DC-II 3005 have 027-516 error, how to solve?
[Cause] During the transfer using SMB of the scan to PC
feature, the SMB server could not be found.
[Remedy] Take one of the following actions, and try again:
Check the following to see if the destination SMB server
and the machine are set up properly for network
communications:
- Check the network cables are plugged in securely.
- Check the TCP/IP settings.
- Check communications of port 137 (UDP), port 138
(UDP), port 139 (TCP).
Check the following to see if the computer correctly
works as an SMB server.
- Check if the file sharing service for Microsoft
Network is activated.
- Check if [NetBIOS over TCP/IP] for TCP/IP
is activated.
- Check if the file sharing service (using
communication through port 137 (UDP), port 138
(UDP), and port 139 (TCP)) are authorized for the
Firewall settings.
For communications which exceed the subnet, check the
WINS server settings, and check if the server address
can be resolved correctly.
For Windows NT 4.0 Server/Workstation, use the
following steps to see if the NetBIOS interface device is
activated on the destination SMB server:
1. Select [Start] > [Settings] > [Control Panel].
2. Display [Services], then select [Messenger] service.
3. Select [Startup] > [Auto] > [OK], then select [Close].
4. Select [Devices] in the [Control Panel], then select
[NetBIOS Interface].
5. Select [Startup] > [Auto] or [Manual] > [OK], then select
[Close].
6. Reboot the
Oct 11, 2016 | Xerox Office Equipment & Supplies
Our computer maintenance company was able to set up our scanner about three months ago. Over the weekend we have lost that capability. We are receiving an error message: Setting how do I fix scanning...
Click this LINKfor the Scan to SMB setup guide which will walk you through the settings. If it had been working then stopped most likely just one setting has changed; the two things I would look at first is the password for the folder you are scanning to and and IP/Host Name of the computer you are scanning to.
Does your Domain require you to change your password on a regular bases? If so then the password set in the copier to access the folder on the computer may have changed and the new password needs to be set in the copier.
Also the person that setup the scanning originally may have set it to scan to the IP address of the computer you are scanning to but if the computer is setup for a dynamic IP address the IP will change from time to time and then the copier will not be able to find the computer you are scanning to. Change the IP that the copier is set to scan to, to the Host Name of the computer you are scanning to and that will no longer be an issue.
The Scan to SMB setup guide goes over these settings.
You can also call Kyocera's free help desk Monday - Friday 9 am - 6 pm EST at: 1-800-255-6482.
Dec 20, 2010 | Kyocera Km-3060 Mfp Copier Copy Machine...
How can i hook up the scanner?
Hook the network cable to your scanner nec card on the machines, note that this machine has two nec cards, one for printer and one for scanner.
after that Go to the setting and under setting/Scanner Default create and ip address for the scanner. after you done from that go to the computer browser, type in the ip address, you can choose scan to smb or pc.
Scan to smb needs shard folder but scan to pc needs to run software on your computer on your pc.
Setup the sender list which you need to fill only the ip address of the machine as sender.
Go to destination setup the ip address of the computer you scanning to, the path is the shared folder name, and the user name and password of your computer and you good to go.
To make it easy for you, Provide me your email and i will attach the scanning manual to help you setup it correctly and you can always get back to me in any question.
Best Regards
Kyocer/copystar Expert
Jul 13, 2010 | Kyocera Copystar 221 Black and White...
SMB Scanning - Virtual Server envirnoment
A quick fix for that would be to enter the fix IP adress instead of the host name, or to check if the host name on the SMB server is correct, and reboot the SMB server.
A good help is to do that from another PC to check if that works:
ping the IP adress try to connect to smb://IP_adress_or_hostname
If that works on the PC, there's no reason that it shouldn't work for the scan
Jul 03, 2009 | Konica Minolta bizhub C250 All-In-One...
Can not make bizhub c252 scanning trough e-mail feature
Can you print to your PC? if yes you know how to assign ip address to the copier. I suggest is to go web browser and type the ip adress of the copier. log in to adminstrator the password 12345678 click network scan you have choices which scanning you want. SMB, ftp scan to email. If choose SMB first you have create Folder to your desktop and name it SMB all upper case and right click sharing and permit everyone . Then back to copier web browser click tab scan and type all the names you want. Scan to e-mail you have to click network and enable the scan to email enter the SMTP leave the port 25 do not change assign a valid email address to copier and enter email address of the administrator user id and the last is the pasword. Note: everytime you visit this page you should enter the password. then click the scn tab and enter all your email address. enjoyprograming!!!
Jun 01, 2009 | Konica Minolta bizhub C250 All-In-One...
Bizhub c350 will not scan to hdd
Easiest way is to change to SMB scanning which will give you direct scanning to PC or server. Create a new address in the machines address tab in the browser add the (must be a fixed) ip address of the machine it is going to with the folder name, user name and password and it will work a treat.
Mar 30, 2009 | Konica Minolta bizhub C351 All-In-One...
Canon IR C3100N Scanner Setup
Hi Its fair simple, if you are scanning to windows PC, Create a folder called scans in your C:\ drive. Share it and give all the permissions. Thereafter log on to your copier using the IP address in your internet explorer. Go to address, click address book one, click the second tab on your left saying register new address. thereafter enter you name, then change from FTP to SMB and then host name will be your computer name\ip address, followed by scans(\\computername\scans)just like that. followed by your username and password.
Thanks
Mar 12, 2009 | Canon imageRunner C3100 Copier
Weird scan problem with Konica Minolta Bizhub C351
It sounds like you have setup a fax forward box.
You need to set up a one touch, scan to SMB.
this can be easily done via your web browser by typing in the IP address of the MFP and set it from there.
You need the IP address of the laptop and is best to put the shared folder in the main drive (C).
Then for the file path you just need to enter the name of the shared folder EXACTLY as it is on the lap top.
You also MUST enter the ID a password to give it access.
Oct 14, 2008 | Konica Minolta bizhub C351 All-In-One...
with scan to Email on this machine you need a mail server that is local with ftp scanning you need IIS running on either XP Pro or server OS SMB Scanning can be done but only if you are using an eithernet connection which one of these do you want do to do
Sep 20, 2007 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
1,069 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
