Question about Dell V313w AllInOne InkJet Printer
How do i shut off my dell v313 wireless printer
  • 823 Answers
It has and on and off power switch. Locate it and push it. Or pull the power cord out of it if you are unable to find the switch.
The power switch is the one in the top left hand corner of the machine with the circle on it. It says "on" right above the circle. Press and hold the button for about 20 seconds or until the machine starts to power down. That will turn it off.
Posted on Nov 11, 2010
My dell v313 printer has power to it and wont turn on
Often this is due to the power adapter going defective. Try another power adapter (available cheap on eBay). If this model does not have an external power adapter, it is probably the voltage regulator or rectifier in the printer itself and would not be worth fixing.
Oct 05, 2014 | Dell All-in-One Multifunctional (V313)...
Where can I find replacement power cord and adpater?
what country you need to state voltage that come out of power point - is it 120 volt or 240 volt because it has to match with power supply check with seller before buying anything and definately before plugging it into a power point .
. Try amazon see http://www.amazon.com/Adapter-Supply-Charger-Dell-Printer/dp/B00L1WTFCA/ref=sr_1_fkmr3_2?ie=UTF8&qid=1404525964&sr=8-2-fkmr3&keywords=DELL+AIO+V313+ac+power+supply or search in google with Dell AIO V313 ac power supply
Jul 04, 2014 | Dell V313w AllInOne InkJet Printer
Printhead problem dell v313
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Mar 17, 2013 | Dell All-in-One Multifunctional (V313)...
I bought a Dell V313 Printer but i could not use with iMac OS 10.7. How can i get the compatible drivers?
Dell support does list Mac OS drivers. Go to the URL below and select your Operating System. There should be 2 print drivers for MAC.
http://www.dell.com/support/drivers/us/en/04
Feb 22, 2012 | Dell Office Equipment & Supplies
V313 dell printer is giving an error of a problem with the printhead. i have cleaned and put in new ink. still the same error. it looks like a grey wire has come loose. I have tried contacting support and...
Short of a warranty repair which sounds like is currently a dead-end for you, if you are NOT using the wireless model, my suggestion would be to buy another one, 59.00 new with free shipping on ebay under item number 380247897696. (I ordered two, one for spare parts)
Feb 11, 2011 | Dell V313w AllInOne InkJet Printer
Dell Printer Home is saying "no compatible printers" are installed even though the Dell V313 was just installed?
Make sure the drivers installed properly, try reinstalling them!
Make sure the drivers are correct for your operating system. To do this go to www.dell.com, and download the proper driver for your Operating System.
Jul 02, 2010 | Dell V313w AllInOne InkJet Printer
I have a dell Photo 964. I shut off the printer to clear a paper jam and it went dead. The on/off button light does not even light up.
lift the printer and shake to check if it sounds like a piece broken inside.. turn the printer off take the power brick out from the back.. manually pull the cartridge to extreme right then center.. check if cartridge is aligned correctly.. if nothing of this works.. contact dell for replacement under warranty.. if out of warranty.. inkjet printers cannot be repaired if broken.. u can buy a dell v313 of same quality for $119 with warranty..
Dec 23, 2009 | Dell 962 Photo All-In-One InkJet Printer
Dell V313w AllInOne InkJet Printer Logo
145 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
