Panasonic CT32D-11 turns itself off after a few minutes on; on periods getting shorter and off periods getting longer. Sometimes an arcing sound is audible, with some hash visible in the middle of the screen during that noise.
  • r_gravlin Nov 11, 2010
    Thanks! With the arcing sound, I suspected a transformer of some kind. I'll try to find a Panasonic repair faciliity in my area.
    Quick, concise, accurate. Now if I could just get him to come over.
    Thanks
    Bob
  • 12,061 Answers
This is a classic switchmode power supply, the Protection Circuitry has sensed a severe potential problem, and is shutting down to avoid a fire, explosion, or both. The "Fault" is sensed, the set shuts down, the "Fault" clears, the PSU starts up detects the fault, shuts down, and so on, this will keep on, until the faulty components finally do fail completely, often with catastrophic results. This set had developed a problem, that is so severe that the set must be shut down, This set should be removed from the Power, and in my professional recommendation, you should get a "Quote" for repair, from, an, Approved Service Center, Panasonic, in your case, now, this point is very important for a good result, Always contact, "their" local, "Head Office" Now, when you get the information you want, then you can decide as to repair of replacement. The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free. There are many, many, many reasons that display this symptom, one must work through the troubleshooting steps to isolate and identify, the Cause and repair that and any damage done
Below is a link for your service manual.
http://elektrotanya.com/?q=showresult&megnev2=CT32D20B&kategoria=tv
Posted on Nov 11, 2010
Clicking sound when you turn the tv on but won't work until a few minutes sometimes longer .
The clicking sound is an indication that the power supply is trying to start but is failing
Apr 16, 2013 | Televison & Video
Flat panel TV comes on by it's self
It sounds that the voltage output from its internal power regulator board is not proper. Check it.
Feb 04, 2013 | Samsung UN19D4003 TV
Just bought the panasonic HM TA1 an its charged an everything an when i connect the camera to the computer it turns on for a second an says connecting then goes off . it wont turn on at all when i havent...
Sounds like it needs a battery.
After a few years those batteries will charge up to the correct voltage, but the length of time that charge lasts gets shorter and shorter, You probably have a drill, a razor, a laptop computer, or a flashlight that do not hold a charge as long as they used to, I know that you have a camera that doesn't hold a charge .
Sounds like a battery problem,
Mar 03, 2018 | Panasonic HMTA1 Camcorder
05 Suzuki Forenzo Radio Problem
Display connection faulty, take apart and check connection from the display screen.
Apr 21, 2017 | 2005 Suzuki Forenza
LG projection TV model 52SZ8D-UA sound go on and off
your audio board is going out take it to a shop and have it fixed
Dec 07, 2008 | LG RU-52SZ51D 52" Rear Projection...
Sony kv35s66: No picture, just sound and red blinking
This should be a quick fix. Try resoldering the vertical IC. This is a small flat IC attached to a heat sink with about 11 pins. It should be marked LA7837 or something similar. That should resolve the problem.
Keep us posted.
Dan
Sep 08, 2008 | Televison & Video
My rca 52 inch hdtv turns itself off after a few minutes
Sounds like the green tube shorting intermittantly. Have a qualified tech use a tube restorer to check for shorts, or the loss of the 300v line to the green tube.
Aug 30, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
