Question about Candy DQW150 Front Load Washer / Dryer
Towels still damp after drying even though ive pressed the extra dry button! only had one large and one small towel in the machine.
  • 33 Answers
Change your moisture control sencor
Posted on Nov 11, 2010
Takes 4 hours to dry a load of towels. plenty of heat - just not drying
How damp are the towels? More moisture= more time to dry
Is the dryer full to the top with towels? There needs to be enough space to allow for air flow in and out.
Also check exhaust vent to make sure it is not blocked.
Oct 09, 2009 | Whirlpool GEW9250 Electric Dryer
Musty smell especially in towels
Once towels have had mold grow on them, it's unlikely you will ever get rid of that smell. You can usually tell a towel has had mold grow by discolorations on solid color towels. You probably need to start over with new towels, make sure they are washed and dried frequently and that they don't stay damp for long after showering. If you live in a humid climate, a towel warming rack will help with drying.
Jul 21, 2009 | Fisher Paykel EcoSmart GWL15
HP Deskjet D4160 Won't print
In this case what i would request u to do is.......
Take out both the catridges from the Printer.........
Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry...........
Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out.......
Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds......
Now remove it and see whether u see any ink on the paper towel..........
U should see some ink on it now place the dry paper towel on the ink catridge in the same way........
Now do the same procedure again..........
Do the same procedure twice on the Black Catridge.................
Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel..........
Know insert both the catridges inside the Printer........
Good Luck.............
Apr 04, 2009 | HP Deskjet D4160 InkJet Photo Printer
My Dell printer has worked fine for years, for some reason the color started fading even though the levels were over 50%. Finally the black ran out so I went and had it filled like I always do. When I...
Know insert both the catridges inside the Printer...........
Good Luck
Jan 27, 2009 | Office Equipment & Supplies
Sheets wind together in a damp ball
I have a different model Bosch dryer, but I have the same problem.
I've found that the flat sheets dry okay if you have them in with other things (like pillowcases and t-shirts). I learned long ago though that you can't put those things in with deep fitted sheets; the little stuff winds up caught in the corners in damp wrinkly wads.
So I dry the fitted sheet separately, and throw in a couple of clean tennis balls. They're noisy, but harmless, and they keep the sheet from balling up.
Oct 26, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Dirty tv screen on plasma
Hi there
You get special cleaner for these screens from any good AV or PC shop.
Apr 11, 2008 | Office Equipment & Supplies
Hard towels
If you are drying your towels outside they will always be hard no matter what you try........ Drying them in the dryer is the only solution to that problem........ I have tried everything else and the dryer is the only thing that works..... Hope this helps
Oct 19, 2007 | Electrolux EW1000i Front Load Washer
Not running quietly
"A blinking light indicates when the blades should be wiped clean with a damp cloth." I actually had a "handyman" contract last year to visit an elderly gentleman once a month and clean all 9 of his Ionic Breeze GP air purifiers. Before I did that for him, they would make hissing noises and he really didn't like that. Here's how to clean the operative compnents of these machines: First, unplug the machine and place on a work surface, such as a table or kitchen counter. Second, remove the metal blade insert from the top by gripping the release tab and lifting it up and out. Also remove the front and back grilles by pressing on the plastic tab at the bottom and lifting up on them. Third, use a damp rag or paper towel to wipe the three metal blades clean. Do not immerse this assembly in water, because it has to be completely dry when re-installing it in the machine. Fourth, use a small piece of damp paper towel to VERY GENTLY wipe clean the two thin wires inside the unit. These are located behind the two rubbery flat blades just inside the unit and can be accessed from the front side. You won't damage these rubbery flat blades by pushing your hand gently between them, but be VERY CAREFUL when wiping the wires clean. (This step is important, as the wires must be clean.) Fifth, using another bit of damp paper towel, carefully clean the wire attached to the inside of the front grille. Dry this off with a dry bit of paper towel, then clean any accumulated dirt off the front & back grilles. Check the metal contact near the bottom of the front grille (attached to the wire) to verify that it's clean and will make good electrical contact. Sixth, pick the unit up and turn it upside-down & right-side up about 6 to 8 times. The two wires inside have plastic beads on them that slide up and down the wires. This brushes any bits of leftover dust or lint off of the wires. (Again, these wires must be VERY clean.) Seventh, replace the front and back plastic grilles by placing them in their slots and sliding them down to snap into place. Verify that the assembly with the three metal blades is COMPLETELY dry, using a hair dryer if necessary to dry off damp areas, then slide it back into place from the top of the machine. Now the cleaning process is done, so plug the unit in and turn it on to test operation. If it makes ANY noise, then some component is not completely cleaned off, or still has a presence of moisture, which must be completely dried off before the machine is ready for operation. Hope this helps! ;)
Jul 25, 2007 | Sharper Image Ionic Breeze GP SI730 Air...
Bad smell
washers and dryers dont make smells themselves its a problem with something u might be putting in it. if u tend to add alot more detergent then usual to your towels then they never completely rinse the water out and will have a mildew smell
Feb 18, 2007 | Whirlpool GEW9250P Electric Dryer
The low button light is going out.
Oct 24, 2006 | Ionic Pro 901P2RIP04 Air Purifier
Candy DQW150 Front Load Washer / Dryer Logo
Top Candy Washing Machines Experts
Marvin
Marvin
shaun taylor
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
