Question about Hotpoint NVL333EY Electric Dryer
The back of the drum in my hotpoint dryer is hot but it takes a long time to dry clothes. What is the problem and how do I fix it? Air is going through the exhaust and it is a short hose.
  • terrymel55 Nov 11, 2010
    where is t he fan? Where can I get one? How much is it? Is it hard to do that?
  • 33 Answers
You need to change the fan
Posted on Nov 11, 2010
Hot Point Dryer won't dry, gets hot on top.
An educated guess would be either the lint tube or the tube that exhausts the air outside is blocked with lint----no airflow or greatly reduced flow will cause this symptom.
Nov 06, 2012 | Hotpoint Dryers
Dryer takes a long time to dry, air is hot
Check the hoses going from the fan to the drum looks like you have a leak somewhere
If you can access the back of the dryer take off the back cover watch out for live wires check all hoses
Feb 06, 2012 | Kenmore Dryers
I have a hotpoint aquarius tdc 30 conderser dryer. It gets hot and rotates the clothes, but they aren't drying. what's wrong?
Hi, Well if it is getting hot but not drying the clothes than most likely you have an airflow problem. Take off the vent hose on the back of the dryer. It will be plugged up with lint either inside that vent on the dryer or the hose will be plugged somewhere. If you clean this or just plain replace the old hose this will take care of the problem. Good Luck. feed back is appreciated.
Jan 12, 2011 | Hotpoint Dryers
How do you dry on this machine? if you dry on the green, does it completely dry?
The automatic preheat and drying cycle kicks in as the final wash spin is under- way. The system employs a condenser dryer in which the hot air used to dry the clothes is channeled into a drum, instead of being released into the great outdoors via a dry vent hose. Cold water is drawn into the drum at the same time. The two mix, and the result is a condensing process.
The chlothes should be dry. there may be a damp feeling to them but otherwise dry. If your machine is not drying then the element could be going bad, or a thermal cutoff. those would be the easyiest fixes.
The BIG drawback is drying. It takes about 90 minutes to dry a load, and the clothes come out very wrinkled. Because the drum is so small, the clothes don't 'toss' in heated air and don't fluff at all. Clothes also come out stiffer than a regular dryer.
Jan 06, 2011 | Equator EZ 1500 Front Load Washer / Dryer
My hotpoint dryer takes hours and hours to dry clothes?
clean the vents as it is an air restriction, first take off the vent house run dryer and feel for hot air, if no or little hot air then then inside of the dryer needs to be cleaned, now if you run the dryer with the hose off and it drys like it should then the vent hose needs cleaned/unrestricted. Hope this helps Tim
Nov 07, 2010 | Hotpoint Dryers
Long time to dry clothes
The dryer has one of its rows of heaters open. Open up the dryer and check the coils behind the drum. read more
Mar 09, 2009 | Hotpoint NVL333EY Electric Dryer
Ive got a hotpoint electric dryer that intermitantly blows hot air..in other words sometimes it wroks while other times dosent blow that much needed hot air to dry clothes..ive tried different things like...
Sounds like the drum is not turning under heavy load.this is a common problem with dryers but usually easily remedied if a competent diyer. first check the theory by putting in big load and see if drum turns. if not then replacing capacator should cure it.
Nov 06, 2008 | Dryers
Hotpoint aquarius ctd40
most likely, there is a blockage in your exhaust. take it apart and check every inch from your dryer to the outdoors. i clean mine once a year, it keeps the dryer running efficiently. when lint backs up in there, the heat cannot get out and there is a sensor that will shut off the heating element when it gets to a certain temp, so your clothes will take a long time to dry
Oct 27, 2008 | Hotpoint TDC32 Electric Dryer
Hotpoint bwd129 washer dryer won't dry my clothes.
my Hotpoint dry will not dry my clothes. It will run for hours and the clothes still haven't dry just felt hot.
Oct 05, 2008 | Washing Machines
Taking to long to dry
This could be two problems. First problem, you must have good ventilation. Blow out the dryer vent with a leaf blower or some other type of fast moving air. Also be sure that the vent on the outside isnt blocked by little woodland creatures trying to find a nice warm home. Also be sure that the vent isnt kinked or blocked between the dryer and the wall. If that doesnt work, you may have only 1 of the 2 elements actually heating behing the drum. This would entitle removing the front and drum to check. Let me know if you need further help.
Dec 08, 2007 | Hotpoint NBXR463EBWW Electric Dryer
Hotpoint NVL333EY Electric Dryer Logo
42 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Dan Webster
Dan Webster
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
