Question about Linksys Wireless-G WRT54G Router
Our linksys wireless g router just stopped working.
  • Andrew Thompson
    Andrew Thompson Nov 11, 2010
    do you have powered at all to the router ?
  • Linksys Master
  • 7,733 Answers
In order to try to recover your router, the first thing to do is to try to reset the router to factory defaults. To do this: 1) Power down all computers, the router, and the modem, and unplug them from the wall. 2) Disconnect all wires from the router. 3) Power up the router and allow it to fully boot (1-2 minutes). 4) Press and hold the reset button for 30 seconds, then release it, then let the router reset and reboot (2-3 minutes). 5) Power down the router. 6) Connect one computer by wire to port 1 on the router (NOT to the internet port). 7) Power up the router and allow it to fully boot (1-2 minutes). 8) Power up the computer (if the computer has a wireless card, make sure it is off). 9) Try to ping the router. To do this, click the "Start" button > All Programs > Accessories > Command Prompt. A black DOS box will appear. Enter the following: "ping 192.168.1.1" (no quotes), and hit the Enter key. You will see 3 or 4 lines that start either with "Reply from ... " or "Request timed out." If you see "Reply from ...", your computer has found your router. 10) Open your browser and point it to 192.168.1.1. This will take you to your router's login page. Leave the user name blank, then in the password field, enter "admin" (with no quotes). This will take you to your router setup page. Note the version number of your firmware (usually listed near upper right corner of screen). Exit your browser. If you get this far without problems, try the setup disk, and see if you can get your router set up and working. When you get to the password prompt in setup, be sure to leave the user name blank.If this does not fix your problem, then report back with your results, including any error messages, and the firmware version number if you have it. Also report back the status of your router lights.
Posted on Nov 11, 2010
My wireless router stopped working. If I bypass the router, I have Internet. The error message says "wireless security types do not match. I have a linksys wireless g broadband router.
wireless security type is the encryption setting you are using.
you either need to change it to wpa/wpa2 mix or wpa.
make sure the client(laptop) is set for wpa or wpa2.
Feb 26, 2011 | Linksys Wireless-G Broadband Router
Linksys Wireless-N WRT150N suddenly stopped being detected
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Jan 12, 2010 | Linksys Wireless-N WRT150N Router
Wireless Router suddenly stopped working.
Try resetting the Linksys back to the factory defaults and configure it again.
Power up the router and press the pinhole RESET button on the back of the router for 30 sec
Connect a LAN cable to the wireless router and open a browser and enter to router's configuration IP address and configure the wireless settings, remove the LAN cable when configuration is completed.
You need to configure then wireless card in the computer/laptop with the router's wireless settings.
Dec 10, 2009 | Linksys Wireless-G Broadband Router
Linksys wireless -G 2.4 GHz router just stopped
I would try a factory reset of the router if there are not any special settings saved in the router. To factory reset the router press and hold down the reset button on the back with a pen or similar object for 30 seconds and then unplug the power cord and plug it back in.
Apr 09, 2009 | Linksys Wireless-G Broadband Router
Linksys wireless G router not working when connected to dsl modem
hey there, can u acces the gateway of the router
192.168.1.1 than enter ur login & password
than reset the router to fabric setting when done go back in the router and configure it as u like to have it
Jan 04, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
Linksys WRT54GS not working
  1. First you may need to check if the WLAN or Wireless light on the router is on.
  2. Try connecting your ITouch to a different wireless network.
  3. If you can borrow a wireless ready laptop from a friend, then borrow one.
  4. Check if the laptop will be able to detect a wireless signal from router.
Please update me about this matter.
Nov 16, 2008 | Linksys Wireless-G WRT54G Router
Bought linksy modem because of provider now wireless dont work
Hi Guys,
What needs to be defined first is the reason as to why it had stopped working. Before a suggestion is made, we first need to find out what the model number of your router is (there are many version of the linksys wrt54g router). Once that is defined i suggest you reset your router by doing the instructions as per this web page (cop and paste in your browser): http://technicallyeasy.net/2008/01/how-to-reset-linksys-wrt54g-wireless/
Once you have done that, the router should be set to factory default leaving you with a fresh clean slate. You can then proceed to configure the router for wireless security (if you need it) by following the steps here: http://technicallyeasy.net/2007/09/securing-linksys-wrt54g-wireless-router/
The instructions on these pages should help, however, if you face any uncertainties, please do feel free to get back to me and i shall attempt to cover whatever i can do to help the both of you out. Thank you.
Regards,
Technomancer.
Nov 10, 2008 | Linksys Wireless-G WAP54G 802.11g/b...
LInksys wireless router stopped working
Who is your internet service provider and what is the model no. and brand of your modem?
Jun 01, 2008 | Linksys BEFW11S4 Wireless-B Broadband...
Linksys Wireless-G WRT54G Router Logo
74 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
