Question about Samsung Refrigerators
Iam having problems with my samsung firdge the problem seems to be with control system.The temp on the fridge seems to get to cold, and freezes every thing but the freezer is al right, i cant seem to get the proper temp. on it, i would like to know wat is the correct temp for some reason when i try to change it switchs on me and becomes colder.the model type is RB195BSBB
  • pepe4164 Dec 16, 2010
    I post a problem with my fride about a month ago and i got the answer, i order the part i got it about a week ago.Now i would like to put it my self. But i need a back up from you guys,can you tell me how to pull out the part , the location, and tolls i need to do it ..The part is electronic board PBA M " i got a message saying somthing went wrong tha you have the solution to this in the previus post. i I hope tha i get the right answer, because i got the part already"
    THANK YOU.
  • Samsung Master
  • 1,711 Answers
Your model has a separate evaporator in the refrigerator department and separate fan motor. So from your description it seems that the fan motor is running even if the temperature is reached. The reasons for that is the following two.
One is either the temperature sensor part no 13 SENSO
Part Number: AP4138824 made by SAM
is malfunction and is not reading correctly the temperature in refrigerator.
And second part is the part no electronic board PBA M
Part Number: AP4137443 made by SAM
Which the one relay have gone bad and is stuck to on so the evaporator fan keep running even that the required temperature reached. Despite that the problem is only one relay on the board you have to replace the complete board.
The above parts and all the parts of your fridge can be found in the following link.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5172084&diagram_id=1342285#d1342285
Posted on Nov 11, 2010
  • espressonist
    espressonist Nov 11, 2010
    We beleive somthing went wrong, we have the solution to this in our previus post.
Why are vegetables freezing in crisper?
There is a control on refrigerator that controls the amount of cold air that is directed from freezer to refrigerator section. Locate that control and lower the amount of cold air going into refrig.
Oct 07, 2015 | Samsung RF265AA Bottom Freezer French Door...
Whirlpool 6wmv43ns/02 Fridge Too Cold & Freezing Food
I would first try replacing the control in the fridge. If that doesn't remedy the situation, I would try replacing the thermostat next.
May 14, 2012 | Whirlpool Refrigerators
Kenmore 596 - temp control panel not responding when up or down buttons selected. Fridge too cold. Freezing items in fridge after power outage last night.
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Okay, hope this will help in solving problem
Aug 07, 2011 | Kenmore 26.0 cu. ft. Side-By-Side...
The refrigerator and the freezer are staying too cold. The temp controls are at the lowest possible and still things in fridge freeze. I can hear the compressor cycle of for a while then on for a while....
things: Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Hope this will help out.....
Jun 09, 2011 | Refrigerators
Hi i have a samsung cooltech fridge freezer and the fridge freezes everything overnight...turned the thermostat down to min but made no difference...best way to fix it ????
I hope that this will helpout in solving the problem.....
Dec 09, 2010 | Samsung Refrigerators
My samsung rsh1dbbp will not cool down, when it is on the freezer won't go below -20 and the fridge +14, and it is constantly beeping even when switched off? Can you help?
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for the air deflector As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control.
I think this help in solving the problem.....
Nov 02, 2010 | Samsung Refrigerators
Magic Chef MCBR445W1 seems like it dosen,t stop
Check on the cold control if faulty, replace the cold control, not having found any other problem, do check on plastic air deflector at the top rear of the frig had been knocked off. replaced it if faulty. As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control, which is now functioning properly.
Good luck.......
Aug 01, 2010 | Magic Chef MCBR440 Compact Refrigerator
The refrigerator ignores temperature setting.
Hello, This problem is going to be the cold control/thermostat, this part can be located in the control console inside the fridge bhind the freezer temp control knob (can also be found sometimes in the freezer depending on type/model) The reason your food in the fridge is freezing is because the thermostat controling the freezer temp is not shutting down and the air being blown into the fridge is too cold. Replace this cold control/thermostat and you should be fixed. If you have any other questions or concerns please feel free to comment again and give me some time to respond. Good luck! Mike
Sep 08, 2009 | Kenmore Refrigerators
Side by side fridge freezer
Based on your weird display issues I'd lean toward the control board problem. At least that can be "one" of a couple problems...
Feb 01, 2007 | Samsung RS2578BB Side by Side Refrigerator
Refrigerators Logo
107 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
