Question about Canon PowerShot SD1100 IS Digital Camera
We have a Canon SD1100 IS. We wanted to take a photo, but the screen is black. We took a photo anyway and tried to view it and it does not come on the screen, and the screen is still black. We tried the DISP button and that does not work in this case. Everything else seems to be ok. We can see the other photos we have taken. Do you have any idea what is wrong with the camera or where we can take it to have it looked at or fixed? Brian Anderson
  • 6,831 Answers
Hello Brian
The solution below is something you can try. I know it might sound off topic, but, this sounds to me like the tell-tale signs of a lens error.
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Nov 11, 2010
My display screen is showing pixelated noise, or completely black. When it does display, all I get are off colour, horizontal dancing lines.
Camera is defect for sure, but don't tell anyone in the service centre, because they warn you not to take a camera out in extreme cold. You should not se the camera in environments below zero degrees
I'm afraid you can't fix it yourself, and before bringing it to a Canon Certified repair centre, ask them what it could cost.
Mar 01, 2015 | Canon PowerShot G10 Digital Camera
We have a Canon SD1100 IS and we have a black screen. If we take a photo we can not see the photo we have taken, but we can see previous photos. We tried the Disp button and it does not fix the problem....
Brian, A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Nov 11, 2010 | Canon PowerShot SD1100 IS Digital Camera
Can't get date/time to not appear on screen or download to comp
Are you sure your canon battery pack is OK?If not ,replace it with a high quality replacement battery pack.
Jul 25, 2010 | Canon PowerShot SD1100 IS Digital Camera
Black screen when taking pictures and videos.
I just had this problem! And the answer is simple - just hit the DISP. button and the image should return.
May 28, 2010 | Canon PowerShot SD1100 IS Digital Camera
I want to save picture that we took in a zoomed in mode -magnified larger than it was originally taken? is this possible?
You can do that in a photo-editing program. It's called "cropping". You select the area you want and the rest is cropped out.
Feb 23, 2010 | Canon PowerShot SD1100 IS Digital Camera
View screen won't work
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Dec 05, 2009 | Canon PowerShot SD1100 IS Digital Camera
LCD screen is black in Photo mode Canon SD1100;
Press DISP. button, and repeat untill the display shows up
Aug 10, 2009 | Canon PowerShot SD1100 IS Digital Camera
Black screen on canon sd1100 is
Actually, the problem was that the DISP button was pressed causing the screen to turn black to save battery life. Easy fix. Just pressed the DISP button again until the display showed what i was looking at through the view finder.
Jun 23, 2009 | Canon PowerShot SD1100 IS Digital Camera
Black Screen/Viewfinder
Mine too! Thank you so much for posting this issue!!
Apr 22, 2007 | Canon PowerShot SD100 / IXUS II Digital...
Canon PowerShot SD1100 IS Digital Camera Logo
29 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
