Question about Maxtor Personal Storage 3100 (M01E100) 100 GB Hard Drive
I Can fin my external hard drive. When my laptop found the hard drive and I going into properties and it said has 0GB. Why? what is the problem? Also when I connect the External hard drive It make sound.
    Brigadier General:
  • 10,406 Answers
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files.
For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge guarantee".
Posted on Nov 11, 2010
PROBLEM 0GB MAXTOR DIAMOND22 STM3160813AS
Your drive can be showing 0GB for a few reasons, if it is showing 0GB in BIOS, in Device manager or in any hard drive utility chances are the PCB is shot or one of the heads has stopped reading. In either case you will need the help of a data recovery expert if you wish to retrieve your data. If it's showing 0GB in My Computer but shows as 160GB(~155) in a harddrive utility or under device manager you simply require a software solution. If you require a recommendation for the professional recovery route simply reply back letting me know and telling me what country and state/province you live in, I can get you in touch with an appropriate service. If you simply need a software solution reply back with the drives original OS, your current computers OS and I can recommend a software package that will allow you to recover your own data.
Sep 30, 2014 | Computers & Internet
Simpletech external hard drive not workin on windows 7
Windows 7 seems to have a lot of issues with external hard drives and any usb attached devices
Click start control panel administrate tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
Automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start then after its finished return and tick the other box you should not
do anything while the chkdsk utility is in progress any input may damage this drive
i have found the best results ticking in one box the returning after it has finished then ticking the other box
it might take some time depending on the size of your disk but be patient
the next works on usb data / pen drives im not sure on external hard drives
Right click on your drive select properties then on customize restore Default in W 7
you might have to alternate doing this repeatedly until the problem is resolved
and i have found that leaving the a usb data drive plugged in and restarting my computer W7 my usb drive will work again (strange)
whatever works
hope it helps
Nov 05, 2012 | SimpleTech 120GB SIMPLEDRIVE PORTABLE USB...
I lost the installation cd driver for my external hard drive P/N 3188210, Model No.LDHD-UP2.I need a driver to open up my files in this Iomega HDD external hard drive. Kindly provide me with an...
hi if you are lost your driver to download your device suitable driver use http://devid.info step to download driver my computer manage, device manager, property on device whose driver are not found copy device id code displayed on example above site copy it and use to download suitable device driver after download extract and go to update driver whose device are installed enjoy
May 21, 2011 | ASUS Eee 4G Notebook
I want to share my external hard drive files over a network so that I can access them from my laptop.
Right click on the external drive (from the computer it is connected to) and select "Properties." Once that box has popped up, select the "Sharing" tab. Configure your settings in this tab and hit apply.
On the laptop, right click on My Computer and select "Map Network Drive." Find the drive you just shared and follow the prompts as guided. Now, you can access all the files from the external drive on the laptop by going to My Computer.
May 16, 2011 | Computers & Internet
Missing files after using the recover CD
In this case try some data recovery program to see if it can help rescue your data on your external.
May 31, 2010 | LaCie (300728U) 250 GB Hard Drive
My sandisk cruzer flash drive is showing its properties as 0gb. so pl help me to get the recovery tool
Try recovering the lost or deleted date with a recovery program (recovermyfiles is one program). If this doesn't work, then you should reformat the drive, and then try the recovery software again. Keep me posted.
Mar 27, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
When i engage it to the computer it takes a long time to boot up, and a lot of my data is gone.
The boot time issue is a common thing. one method to help fix that is to go into bios and turn off any options to "boot from usb" or similar wording.
That should decrease the boot time that is caused by the system looking at your external drive and finding that it has system files on it. external drives with system files may mean th computer tries for some time to boot from that device before it gives up and moves on to the proper boot device eg your hard drive.
As for your data being lost you should run diagnostics on the drive to make sure there is no corruption.
Do this from windows explorer or my computer and RIGHT click the external drive then select properties
Now click hardware and highlight your external drive, then click properties, then policies. Make sure to turn of write cache and set it for QUICK REMOVAL.
Click tools then error checking and make sure any boxes that offer to fix anything are also ticked. Click ok and it should go off and do what it needs. It may want to restart to complete the process and this is OK
If it found anything really bad and came up with any error messages take a note of thee for further troubleshooting purposes.
ALSO NEVER just kill the power to the drive or computer.
Your data should now be a lot safer
If you found this information useful please click below
Aug 18, 2009 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
Simpletech Signature 500gb "is not accessible"
Right click on MY COMPUTER and select MANAGE.
Go to DEVICE MANAGER and expand the DISK DRIVES category on the right side window.
You should see the Simpletech drive listed under there. Delete the Simpletech drive and click on OK. Restart the computer.
Windows should re-detect the simpletech and re-install the built in drivers automatically.
Jun 17, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
My Files on my external hard drive are saved as compressed files.
just copy them to the laptop and, asuming the folder you are using is uncompressed they shoudl expand. Or highlight the files rightclick on them and fo ro properties
Jan 13, 2009 | Maxtor Hard Drive
Maxtor Personal Storage 3100 (M01E100) 100 GB Hard Drive Logo
51 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
