Question about Maytag EPIC MFW9700S Front Load Washer
Laundry soap is leaving spots on clothes. - Maytag EPIC MFW9700S Front Load Washer
  • 33 Answers
It may not be goin thru the rinse cycle all the way
Posted on Nov 11, 2010
My GE Profile washing machine leaves soap suds in the bottom and on the clothes. I use Cheer liquid detergent. My husband says it is because of placing too heavy of items, such as towels, in the machine....
Use ONLY the recommended amount of detergent per the label on the detergent.
Pour detergent in the tub first then start the water,then add the laundry.
Do not overload the machine.
Use a bathroom scale to weigh 12-15 pounds of laundry and no more.
Big tubs invite more laundry.
Don't be fooled by a big tub.
Feb 20, 2011 | GE Washing Machines
GE WSXH208FWW washer leaving spots on clothes
If you are getting round dark spots on your clothes after washing, the problem would be cause by a bearing seal leak. What happens is water leaks pass the seal into the bearings, and the grease leaks back into the wash water. To fix it would require the machine to be literally taken completely apart to get to the bearings. Very costly to repair. Sorry.
Aug 24, 2010 | GE WSXH208A Front Load Washer
Leaving brown stains on clothes, messing them up,
If it isn't rust, I suspect cotton can decompose if moist for a long time (in the laundry or machine), causing brown spots. In that case, the spots probably cannot be removed. Or can they?
May 09, 2010 | Washing Machines
Grey spots on our white clothes after wash
do you use affresh to clean your front loader? deposits of soap and other such things can be stuck around the inside tub of your washer. try this porduct out it works great on all front loaders use hot water with the affresh pellet with no clothes and run the machine through a cycle this also helps with any stagnant water smells also have you cleaned out your pump lately. * note remeber to put the pellet on the inside of the machine not in the soap dispenser
Apr 28, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Smelly clothes after washing
yes musty is actually cooked soap
from the dryer
take a clean just washed towel and put it in the washer alone with no soap
turn on the machine and watch what happens you will see the suds start to form
with this unit, if your using too much soap it will be spun into the cloths and then cooked in the dryer
do one towel load without soap then cut you soap usage way back
anything more than a tablespoon is way to much
remember you bought this unit to save water
1/6 the water 1/6 the soap
and he should be less
Oct 24, 2009 | Maytag MAH2400A Front Load Washer
Dark spots on my clean clothes
do you use a lot of fabric softner? If you do this might be your problem try to change soaps and stop useing fabric softner. try useing powder detergent and make sure that it is HE. let me know how it goes thanks
Jun 02, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore 80 series washer leaves soap residue on clothes no matter
After speaking with someone with trouble shooting experience in these matters, I now believe the problem lies NOT with the washer but with a bad batch of laundry detergent which fails to dissolve properly in the water.
Mar 12, 2009 | Kenmore 22422 Top Load Washer
Lg wm1812cw front load washer
We had the same problem- for us it was because we were mixing laundry booster (Oxyclean) with liquid soap in the dispenser. It seems the water running through the tray had insufficient pressure to properly flush the tray out, so residue accumulated on the back & underside of the tray. Our water pressure is good here, and we don't use a water softener or filters that can reduce the pressure. Unfortunately it seems to just be a bad design of the soap dispenser tray.
We also had a problem with water/bleach leaking from our soap dispenser- when we used the bleach compartment in the dispenser we got leaks dripping onto the floor from behind the front cover of the washing machine. It was running down the front of the washer behind the front cover & coming out onto the floor. The repair guy said this was because the dispenser tray was pulled out too far, but the reason we were pulling the soap tray out so far was because the bleach compartment was too far back in the tray to use if we didn't. Now we just leave the drawer partially closed & pour the bleach directly into the soap compartment along with the soap.
Jan 16, 2008 | LG WM1814CW Front Load Washer
Moldy Smell
try running about 3 cups of vinegar in your washer and always leave the door open when you are done doing laundry
Dec 10, 2007 | Kenmore Elite 45986 Front Load Washer
Oil Like Stains on Clothes
possibility is that the bearing seal is breaking down and oil from the bearings reaching the clothes. if so, the bearings will shortly follow. not an easy job and you are faced with a bill if i'm right
May 11, 2007 | Kenmore 45081 Front Load Washer / Dryer
Maytag EPIC MFW9700S Front Load Washer Logo
108 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Donni Steen
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
