Question about Toshiba 57H83 57" Rear Projection HDTV
Color issue In upper left hand corner of TV the green/red (purple) colors are blurred and blended. Recently moved and have changed satellite box out. Problem still exists. Any ideas on how to repair?
  • mchenry52 Jun 17, 2008
    Please advise what part/parts I need to ask for when I order these items.
  • 796 Answers
Replace 120k resistor on the blue video output module. Resistor is located next to the blue video output transistor (has heat sink). If you replace it with a 1/2 watt carbon type, it will probably never happen again. I recomend the same resistor on the red and green video boards at the same time.
Posted on Jun 17, 2008
How to make folder in dos command how to rename the folder in dos command how to change the font color of the dos command
To make a folder type: mkdir FOLDER_NAME Where FOLDER_NAME is the name that you want to give your folder.
To rename a folder type: rename FOLDER_OLDNAME FOLDER_NEWNAME Where FOLDER_OLDNAME is the old name of the folder and FOLDER_NEWNAME is the new name of the folder.
To change your font colour, use the color command by typing: color XY Where X is a hex value representing the colour of the background of your window and Y is the colour of your.
The values that you can use for X and Y are:
0-black
1-blue
2-green
3-aqua
4-red
5-purple
6-yellow
7-white
8-grey
9-light blue
a-light green
blight aqua
c-light red
d-light purple
e-light yellow
f-bright white
Mar 25, 2011 | Computers & Internet
Green and purple shadows in the left upper corner
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
There is a wave (color change) on the upper left hand corner of
Convergence is dead.Know how to solders?Must replaced the 2 convergence ICS,and all it resistors to solved this problems.Buy a convergence kit to fix it ur self.Tries Tv repair World.com,Tvrepairkits.com for the convergence kit.The shop will cost U $300 for parts and labors.
Feb 06, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Still, bright images on my PS3 change the color of my TV in areas
hi verifies if you are connecting good the video cable i mean the red, the yellow, and the white, if this dont serve you, is because your tv is to old.
Sep 19, 2009 | RCA TruFlat 27F520T 27" TV
The color seems to be off. No red, and lots of purple. This is a Toshiba 57H81 wide screen big box tv. It was purchased in 2002.
Could be a bad board within the tv but it is sometimes the source input meaning it could be dvd player, cable/satellite box, etc causing the loss of color but it is unlikely. I have one of these tvs and they use red green and blue projectors to reproduce the colors so when the red projector fails then you get purple which is green and blue colors combined without the red. I have found it to be sometimes a bad connection inside the tv and I found insects such as roaches inside others. Using extreme caution when opening the rear cover of any tv due to dangerous and fatal high voltage. You might find that simply cleaning out the inside of tv and reseating all the connectors might resolve your issue otherwise you would have haul this tv to a repair shop where you pay half the price of a new flat screen lcd for just repairing this tv which will probaly have another color go out next month.
Aug 15, 2009 | Toshiba 57H81 57" Rear Projection...
Intermitant color bursts of red, green, purple
Kevin,
for the color problem,most likely you do have problem with loose contact of components from C-board ( small board connected at the back of CRT "picture tube" which drives every color and size of the screen)if you have knowledge with soldering electronic component parts, resolder this board and also check main board for possible loose contact.
cheers,
mark
Feb 04, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Color distortion
Move any speakers or electrical devices away from the set. It could also be anything electronic or magnetic. Anything near the set that generates a magnetic or electromagnetic field could be causing the distortion.
Jun 04, 2008 | Zenith A36B41W 36" TV
Color separation
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Mar 03, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Green blur bot-R and up-L corner and no audio
If a standard TV has color splotches in 1 or 2 corners of the screen, it is possible that a large magnet, such as a large speaker, is or was near the set and has magnetized the picture tube. The set has a built-in degaussing coil but it is small and will only demagnetize small magnetic fields. Make sure there are no magnets near the set and if the colors are still off, have the picture tube demagnetized with a strong portable demagnetizer. As for the audio, when there are audio output jacks on the back of the set then there is usually an option to turn the speakers off. Some sets have a switch somewhere and some sets have a setting in the audio page of the on-screen menu. Look for a switch or go into the menu, navigate to the audio page and look for a speaker setting (ON / OFF) and make sure the speakers are set to ON.
Aug 28, 2007 | Konka K2386U 23" TV
Toshiba 57H83 57" Rear Projection HDTV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
