Question about Moen Bathroom Sink Faucet - Single Handle with Drain - Monticello by
Need to change washer faucet - Moen Bathroom Sink Faucet - Single Handle with Drain - Monticello by
    Genius:
  • 1,015 Answers
Probably what you need to do is change the cartridge. You will need a Moen cartridge puller to help with removal and reinstallation. You can get these and the cartridges at most hardware stores. Shut Off Water first, remove set screw that secures handle and carefully remove handle. You may have to tap lightly on rim of handle to free it. There is a retaining clip that holds cartridge in place, it will have a small round hole on top. Carefully remove clip using neddle nose pliers or perhaps ice pick inserted in hole to remove clip.Install puller as per instructions and tighten nut to remove cartridge. Install new cartridge andclip. put handle back on and install screw. I need to back up here and say that screw is normally located under moen insignia in middle of handle. Pry cover off with screw driver or knife blade to access screw. After you have cartridge, retaing clip and handle reinstalled turn water back on and check for leaks. Hope this helps. Thanks.
Posted on Nov 11, 2010
How to stop a driping tap
Try to follow these two you tube videos and see which one applies to your style of faucet.
Good luck.
How to change or tap washer to stop dripping tap or replace the type of...
How To Fix Dripping Tap Washer Change Plumbing Tips
Aug 05, 2014 | Plumbing
Not gating flam
follow this steps and fix it. God bless you
Service a compression faucet:
  1. Turn off the water supply and open the faucet handle to relieve water pressure.
  2. Carefully pry off the trim cap with a small screwdriver or putty knife.
  3. Remove the locknut with an adjustable wrench, then lift the spindle out of the faucet.
  4. As needed, remove and replace the O-ring. Before reinstalling, coat the stem lightly with plumber's grease.
  5. As needed, remove the retaining screw and pry out the washer. Install an exact-replacement washer and tighten it.
  6. As needed, inspect the seat and replace if damaged.
  7. Install the valve and tighten, then reinstall the handle and test.
Repair a reverse-compression faucet:
  2. Carefully pry off the trim cap with a small screwdriver and remove the handle screw. Unscrew the packing nut and lift out the stem assembly.
  3. As needed, pry out the washer under the packing nut and replace it.
  4. As needed, remove the seat washer and replace it with one that fits exactly. Rethread the spindle and washer back onto the stem, and reassemble the faucet.
Nov 30, 2013 | Plumbing
Need to change a washer on a leaky tap in kitchen sink
You will need to shut the water line off and disconnect from the faucet. Then you will need to unscrew the nut holding the faucet in place. Take the faucet out and then you will be able to disassemble the faucet and replace the washer. Newer faucets use a cartridge with the washer built in.
Aug 16, 2011 | Home
Repair RO faucet -- it drips Watts brand
It is possiable, taking off the handel and the handel body should reveile a washer ,that you can try replacing.
Feb 01, 2010 | Dmm Designer Water Filter Reverse Osmosis...
Leaking Delta kitchen faucet dual handle
Pry the hot/cold button off the top of the handle. Make sure the water is turned off below the sink.
Under the button should be screws. Remove the screws. Pry the handle off. Remove the stems by lifting then out.
That should give you access to the washers you need to change.
Apr 25, 2009 | Delta Faucet DELTA/PEERLESS FAUCET CO....
Moen Tub Faucet.. Water won't stop running.
change the washers first if that don't work change the inserts buy all at same time and return if not needed . Thank you for useing fixya please rate me
Feb 25, 2009 | Moen 2919 Chateau Two Handle Tub and...
Faucet kit
have you tried to change the washers in all the stem ends? this is what it sounds like,try beveled washers this may work.
Jan 26, 2009 | Danco Faucet Stem
Moen Bathroom Sink Faucet - Single Handle with Drain - Monticello by Logo
278 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
