Question about Dayton Permanent Split Capacitor Motor Fan
I have a 5k117bd motor and need to install it in a 208-230 power supply, the electric diagram in the motor is not clear abaut the conections. can you send me a conection diagram that helm me to do the proper conections. Thanks
3 Suggested Answers
SOURCE: wiring diagram for dayton ac electric motor
i need wiring diagram for a dayton electric motor 4mb22
Posted on Oct 21, 2010
  • 569 Answers
SOURCE: I have a dayton 3phase motor that i would like to
A 3 phase motor will not work on a single phase supply so I'm sorry but a wiring diagram will not help you.
Posted on Feb 08, 2011
I have done a conversion iv put a jetta 2 cli 1.8 motor in my golf mk 1 I want to know if I need both fuel pumps or wil the pre supply pump be enough? and because the golf had a mechanical fuel pump...
you cant just steel power.you have to have fuel pressure regulator conected with fuel pump relay and pump itself.best way would be to install fuel tank from MK4 with el.pump inside,add relay conected with ignition switch and fusible power from battery
Oct 03, 2013 | Cars & Trucks
Electrical wiring manual or diagram on isuzu giga power window switch
i encountered this problem already check if the fuse is okay..remove the panel get a tester to see if there's a power supplying the motor. if none check the wires near the door hinges that's the place where the wires got pressed and prone to breaking. other thing is check for corroded switches
Nov 13, 2011 | Cars & Trucks
I want to run this compressor "RITIN RT2012" 2HP 12L (1.5kW) compressor. It's a 110V AC drive unit and I have 240V. Can I run it or do I need to convert the Power supply.
You can't just run it on the 240 Volt supply. Check the motor nameplate. If it says it is rated for 110/220 or 115/230, or 120/240 Volts, then it is capable of running at 240V. This will require a wiring change, and you may need a larger size power cord.
The electrical diagram should be on the motor name plate or under the cover to the electrical terminals on the motor.
May 25, 2011 | Air Tools & Compressors
No clear installation instructions for electric box on air vent
Go to their website, they have installation instructions, pretty simple
Jun 19, 2010 | Air Vent (53857) Fan
Wiring diagram for electricmotor with capacitor
On most motors the wires with the tabs are connected to the capacitor (usually brown). White wire is neutral and color wires are speeds.
May 09, 2010 | Heating & Cooling
I do not have a diagram for you, but depending on the motor, I can tell you a couple of things. 1. All capacitors are wired in series with the start winding. Most multi-speed motors, that require capacitors, have two brown leads, along with the motor winding leads. If this is the scenario, then just connect line power to neutral and the speed you wish to use, and connect the two brown leads, one to each side of the capacitor. Hope this helps.
Apr 01, 2010 | Heating & Cooling
Where do i find the jumpers for cmos reset on a L4S5M/DX+ - ECS Elitegroup
Dear asker, you can find a maual for the board here:
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=24&DetailName=Manual&DetailDesc=L4S5M/DX%20%20%20(V3.02)&CategoryID=1&MenuID=82&LanID=0
if you dont want to read, it is at the left of the battery , marked as jp1. usually the 1-2 pins are the normal operation, 2-3 pins to clear. Please notice that no power supply needs to be connected to the computer at he time of clear!
Bios clear takes abaut a half minute, then restore the jumper and power on the computer.
Hope this helps.
Mar 24, 2009 | Computers & Internet
Wiring diagram for dayton ac electric motor
Dec 13, 2008 | Dayton Permanent Split Capacitor Motor Fan
PROBLEM UPLOADING PICTURES TO WINDOWS XP COMPUTER
If you have a driver disk:
Install the driver. After conect the camera.
If not working use the manual select, driver cd, brose while find someting similar name with your camera.inf on the disk and use this file when windows ask about the driver file.
If you dont have a disk downoad the driver from the internet and do the same process.
Maybe you have to install and reboot 2 times, dont worry, we tolking abaut windows op.system.
If you need more help send more data. Brand full model nunber...
Nov 11, 2007 | Polaroid i733LP Digital Camera
Abaut firmware
Have you tried formatting it.
Jun 19, 2006 | Teac MP-111 MP3 Player
Dayton Permanent Split Capacitor Motor Fan Logo
185 people viewed this question
Top Dayton Dryers Experts
Jay Finke
Jay Finke
AZBen
AZBen
Piyal Perera
Piyal Perera
Are you a Dayton Dryer Expert? Answer questions, earn points and help others
