Question about LG WM-1832C Front Load Washer
LG WM1832CW Drain Pump
I am wondering if anyone can tell me how we can gain access and possibly remove the drain pump from our LG WM1832CW. It doesn't seem like there is a way to remove the front cover and it is very hard accessing the pump from the back of the machine.
Any help would be greatly appreciated.
  • Anonymous Mar 21, 2014
    it wont go into test mode only the pump runs first
  • Anonymous Apr 01, 2014
    DE error - problem draining... i have drained the tub manually now it wont go past the 21 minute mark.. cannot access pump or any other internal parts without dismantling... any help would be much appreciated!!
    Welcome Back:
    Visited the website for 2 consecutive days.
I drained it first with the pull out hose in the access panel on the bottom left. i tilted the washer back to remove it from the bottom.
Posted on Nov 30, 2008
LG Frontloader WM1832CW gets stuck on spin at 9 minutes... cleaned drain pump, replaced door lock, motor, hull sensor and bearings... reset a million times... anyone have any idea if it could be the final...
check for blocked pump or slow drains. if water cant get out, machine will keep trying to get rid of it. i put drain hose in a big bucket and tried worked fine had a slow drain.
May 16, 2013 | Washing Machines
LG wm1832CW Front load washer , error code OE and shut down, drain cleaned pump ok, ?
Yes, could be that the pump has dropped down on the efficiency.
check this link for tips to reset or rework the pump
Click on Pump
Jan 15, 2013 | Washing Machines
Water left in tub at end of cycle.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 27, 2011 | LG Dishwashers
Our dishwasher isn't draining
Hi
Daniel
Aug 04, 2011 | Kenmore Dishwashers
Oe drain error on lg wm1832cw washer: I replaced the drain pump, it still did not correct the problem.
OE - "No Drain"
Simply means the pump is blocked. Locate and clean the filter
Jun 28, 2011 | Washing Machines
The grey drain hose split, anyone know how to replace this? Is it attached to the drain pump in the front? Also discovered that black drain tube is clogged at the front filter. This tube seems to be...
the drain hose is indeed attached to the pump area... sounds like you may be on well water if it is breaking the hose down that bad... if not that is unusual to have hoses break down like that... its not hard to replace the hose as they just have hose clamps on them ,but yes you do have to tear apart unit to get down to drain pump assembly... some of the units have a front kick plate you can remove to get to them and some you actually go into from the rear... i didn't look this model up but we work on all appliances and normally there is a way to access the drain pump.... some units front loaders you can actually tilt up and the bottom plate will remove to gain access to it also... just going to have to look around and make access the easiest way for you... once your in though it is a simple task to replace hose...
Jan 01, 2011 | LG WM1814CW Front Load Washer
My LG is a few years old, Model WM1832CW and seems to work in all modes except rinse. It just started this morning and sounds like its slipping and grinding and won't pump the water out. any suggestions....
Replace the pump motor. On your model, it can be done without removing the front panel. Open access door at bottom left of front panel. drain water out small hose. remove screw from plastic recess and use putty knife at side of recess to remove plastic recess. remove screw holding pump. pull machine out 2 feet from wall and tilt it back to rest back edge against wall. depress plastic tab in base to release pump. remove hoses and unplug electrical connection to pump. remove 3 screws holding pump motor to pump housing. install new pump motor and re-assemble.
Nov 27, 2010 | LG WM-1832C Front Load Washer
I neet o replace drain pump on a LG wm1832cw model
its not easy, but you'll have to lay the washer on its back and take off the crate like bottom panel. Discontect all the hoses. Disconnect the electrical line going to the pump. If you can, try and seperate the pump motor from the housing by unscrewing two screws on the housing, which will seperate the motor from the housing, If you cant get to it, I actually broke the screws on the drain filter housing to get it loose. I secured it back with the other front loading screw and some gorilla glue, shouldnt be a problem. I should at least get another 6 years out of this pump. Good luck.
May 31, 2010 | LG WM-1832C Front Load Washer
LG front loader drain pump
Easiest way is to use a putty knife on the left and right side of the lower left access panel on front of the machine to remove the rectangular inset. (might have to remove a screw first) Next, pull machine out about 18 inches from the wall and tilt it back so you will be able to reach under machine. Next, remove the phillips screws you can see now that the plastic recess has been removed (not the two at the very bottom, the other ones). Reach under machine and remove pump assembly, which is held in place with a plastic tab on the bottom. If you break the tab, don't worry, it's not really needed as the screws will hold the pump assemble in place just fine. You should now be able to disconnect the electric wire plug and remove the hoses clamped onto the pump. Pump motor is a separate replaceable part.
Oct 30, 2008 | Washing Machines
Drain pump on my LG wm1832cw seems to be "clogged" I've cleaned drain filter check discharge hose and have made sure house drain is clear.
i took the pump out . then took the pump apart , water got past the o ring , where shaft goes into the center. i cleaned out the sludge & put grease on the o rings before putting it back together. it's worked since,
Jul 08, 2008 | LG WM-1832C Front Load Washer
LG WM-1832C Front Load Washer Logo
1,094 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
