Question about Intex Easy Set Pool 15x36
Can I use the filter pump to pump air into the easy set pool?
    President:
  • Intex Master
  • 1,378 Answers
Simple answer is no...you can not.
John
Posted on Nov 11, 2010
My intex 637r pump is not pulling the water through to the filter and letting it discharge back into pool could it be that the pump and hoses are sitting to high on the ground and not far enough under the...
Air release valve for air trapped inside filter chamber
Intex 1000 GPH Easy Set Pool Filter Pump Instructional Guide 637R
The link has a set-up video for the 637R pump. Make sure water flows out of the air valve on the top of the filter cover. This will purge air out of the filter and prime the pump. Hope this helps you....
May 13, 2014 | Intex Krystal Clear Model 635 Pool Filter...
How do I remove air from pool filter lines?
with out seeing your set up not to easy,but lets try
1 your pump room is below surface of pool, make sure your pool level is high enough to return water to pump via the skimmer hole in side of pool at surface level. water should fil pump basket. check that you have a good seal on glass cover. no water in basket check if valve from pool is open still no water close valve fill filter chamber with a hose close glass cover start pump and open valve immediately.
2 pump room above pool level, close inlet valve fill pump filter with water close glass cover securely start pump and open valve.
a good drawing of you equipment and its position relative to pool how and ware u connect vacuuming hose
May 30, 2012 | Hayward Pool & Spa
I have forgotten what hose connects to what from pool to pump. above ground simple pool pump.
Discharge of pump goes into inlet of filter, outlet of filter goes back to pool.
Line from pool skimmer or bottom goes into inlet of pump.
Dec 21, 2010 | Intex 1000 Gallon Easy Set Swimming Pool...
10000 gal pump
as with any pool pump they have to prime themselves,, close up the unit as it was before,, and turn it on,, remember that water is also the cooling agent for these pumps, check to see that its pumping water as before,, ( yours may even have a place to prime it,, Look for an easy access prime hole in the pump unit itself )
Aug 02, 2010 | Intex 1000 Gallon Easy Set Swimming Pool...
I LOST MY OWNER MANUAL FOR MY 18X48 EASY SET INTEX POOL AND I DON'T REMEMBER HOW TO SET UP THE PUMP AND FILTER
Attach the hose from the lower part (the pump) to the lower hole (intake) on your pool. The attach the hose from the taller part (the filter part) to the taller hole on your pool.
Open the spigot on both parts of the pool (turn, lift and lock into open position) openings. You'll hear water fill up the filter section. Make sure the knob on top of the filter section is a little open and let the air bleed out. You'll know when it is full of water when it starts spitting water out. Close the top then.
Plug in your pump and turn it on. If it doesn't take much water in at first, reopen up the knob on top of the filter to let more air out. Once it spits water, close that up.
Hope this helps!
Jul 14, 2010 | Intex Pool & Spa
2500 Gal Easy Set Swimming Pool Water Filter Replacement Pump only: how to converte to larger filter...
You can simply buy a larger pool filter that is designed for pools in your size range. Look for one that is designed for smaller above ground pools. You can find lots of different pool filters at backyardcitypools.com.
May 17, 2010 | Intex 2500 Gal Easy Set Swimming Pool...
How do we get our pool pump back to filtering the pool? It was working for the first day! Now it not doing anything and we have taken the hoses off and did the air in the pipes check, and still not working...
Make sure the selector on the filter is set to "filter" also check that there isn't any obstruction found in the intake pipe coming from the pool to the pump. Make sure the pre-filter basket just before the pump is clean and free from obstruction. Check all valving is open on the intake pipes and discharge pipes exiting the filter.
Jul 05, 2009 | Intex 15' X 42" Easy Set Pool Complete...
Intex Easy Set 530 Gallon swimming pool filter pump is leaking. How do we get it to stop?
You will need to go to the manufacturing web site and get a new seal for the pump.They cost some where around $1.00 to $2.00.
Jul 02, 2009 | Intex Easy Set 530 Gallon Swimming Pool...
Intex Easy Set Pool 15x36 Logo
178 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
