Question about Canon PIXMA MX310 All-In-One Printer
I am getting rid of my dedicated fax line and am adding it to my land line. I am told when I have a fax coming in I will hear a double ring which mean my fax line is ringing. How do I set my fax to recognize the double ring and pick up the fax?
  • 823 Answers
There are two ways to configure a fax machine to answer the phone line. The first way is by pushing the "auto answer" key on the keyboard of the fax itself. When this key is used, the fax machine answers all calls that come in after a certain number of rings. The other way is to manually press the fax button when an incoming call is happening. You can set the number of rings for your machine to pick up by using the keys on the fax machine under the menu feature and then scroll using the up and down arrow keys until you see fax set up and then number of rings.
I have heard about the option that your speaking of, where they give you a separate phone number for your customers to fax when you own a business line but I don't know how the fax machine itself would be able to distinguish between the normal ring of a regular call and the double ring of the merged fax line call. I was told that when I set that up for my friends business recently, that the machine would auto recognize the double ring without any programming and to use the auto answer feature for all calls. He has not had any faxes yet (its a new business) so I can't say for sure if it works or not? I can say that none of his regular calls have been picked up by the fax so far though.
Posted on Nov 11, 2010
Receiving faxes whilst connected to a phone line automaticly
Check video for 'fax receive set up' in similar model:
Manual receive: In coming call receives like telephone
Fax/tele: Incoming call rings like telephone if its not fax, if incoming is fax it will entered in fax mode automatically
Automatic: Incoming call converts in fax mode after ring count ends( ring to answer option also avail in fax set up mode rage 1-6 rings)
Fax: Incoming calls straight away converts in to fax mode.( this option only for dedicated fax lines)
Set up your best option as per your requirement.
Nov 29, 2012 | HP LaserJet 3050 All-In-One Printer
No incoming fax tone
Sounds like it's not set to auto-answer faxes. Do you have the manual so you can see how to check that setting? If not, I can try to find it.
Aug 30, 2007 | Brother IntelliFAX 4100 Laser Fax
There is a fax failure when receiving a fax. The activity report said REMOTE FAX ERROR. What have I not set correctly? We have never set up the fax before so have no previous history. We are using a...
If you have specifically requested a "double" ring pattern for your fax from Telus, then you have the right setting, otherwise, select the Any ring pattern to avoid fax transmission failure.
For more troubleshooting steps, please refer to this Lexmark article about Main Contributing Factors to a Fax Receive Failure on Inkjet All-In-Ones.
Sep 23, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Phone company added a dedicated fax line to the outside of my house and my home phone rings to my fax
Your wall outlet has four wires, the center two are the first line and the outside two are the new fax line. You need to go to Radio Shack and get an adapter to split your first and second line into two separate wires. The part number is below.
Steren® 2-Line 4-Conductor Splitter/Adapter (Ivory) pixel.gifModel: T07843 | Catalog #: 55034722
Mar 09, 2010 | Panasonic KX-FHD332 Plain Paper Thermal...
Fax machine problem
You are hearing the fax machine hand shake. You should have a dedicated line for your fax.
If not scroll through the menus and set your fax to the maximun NUMBER OF RINGS.
Nov 12, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
2 phone lines causing problems for fax machine
Fax machines are designed to have their own dedicated phone line.
Nov 09, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Not recognizing new phone line - Double Ring
Fax machines are designed to have their own dedicated fax line.
Anything else is a **** shoot.
Aug 12, 2008 | Brother IntelliFAX 1840C Plain Paper...
Can't receive fax - fax rings 2ce then just stops / says phone off hook
Hi Iryan,
Instead of switch box, a more dependable option is to get a distinctive ring. Your local phone company offers this option. What's neat about is you get a seperate fax number. Its like having a dedicated fax line without adding extra lines to your service. I think the monthly fee is around 3 dollars a month for this feature, but, believe me its well worth it.
anaanymous
Jul 15, 2008 | HP Officejet 4110 All-In-One InkJet...
How do I get a fax number?
you are correct just use a splitter and if you hear a fax . beep beep then hit answer
or just set your fax to answer on the 6th ring.
or purchase a dedicated phone line for faxes.
who uses faxes any more.
May 12, 2008 | Philips FaxJet 375 Plain Paper Inkjet
Can't receive fax
Pick up the receiver and see if you hear a fax tone noise. If so then push the start button and hang up. Is this machine on a dedicated line or shared with the main phone number? Sometimes some people will pick up the receiver on their fax machine dial the fax number and wait for a tone before sending. If this is the case the machine can not recognize that is a ax. Make sure your machine is set for auto receive if it is on a dedicated line.
Apr 06, 2007 | Brother IntelliFax-2820 Laser Fax
Canon PIXMA MX310 All-In-One Printer Logo
384 people viewed this question
old marine
old marine
