Question about Kenmore 23313 Whispertone Bagged Canister Vacuum
The brush roller is not rotating on my Kenmore Whispertone. It will pick up on floor surfaces. Help!
  • 244 Answers
Be sure that there are no fibers wound around the roller or lodged in the wheel well of the brush roller. That is usually the cause of a brush roller not rotating. You might need to use scissors to clip the fibers and then pull them from the roller. The fibers might range from human and pet hair to carpet fibers, threads, string, yarn, embroidery floss. They wind around the roller and eventually "tighten up" so that the rotator will not move. I have found that, depending on my current craft project, I may have quilting thread, knitting yarn, embroidery floss, or other such goodies wrapped around the roller. When our daughters were at home we would have long, beautiful blonde hair tangled in the roller. I hope this helps.
Posted on Nov 11, 2010
The brush bar isn't going round ?
your problem seems to be the belt has snapped. Underneath the the hover there is a rubber belt that connects around the brush bar and around the motor, this belt will be broken. They can purchased from any hoover shop for a couple of pounds.
Jan 06, 2013 | Dyson DC24 Ball All-Floors Upright Vacuum...
Does not pick up lint on carpet
I have a four suggestions. First, check the wand and see if the suction vent is completely closed. If this little vent has the slightest opening, the suction is reduced. cSecond,if that's not the case, you might want to check the brush/roller area. Threads and fibers caught on the brushes can prevent the vacuum from picking up lint. Third, make sure there are no fibers in the wheel of the vacuum head. And fourth, make sure the bag is not full! I often forget to check and back and a full bag is one of the main reasons a vacuum will not pick up items. I hope this helps. If one of my suggestions solves your problem, please contact Fixya and rate my solution!
Nov 21, 2010 | Kenmore 23313 Whispertone Bagged Canister...
Sears Kenmore Whispertone Vacuum Problem:
If you push inwards on each side of the light cover on top you can remove it. With the light cover removed remove the (2) access screws. Now you will be able lift of the entire top cover from the base. You will then see the belt and roller brush, remove the old belt and replace with a new one. You can get the replacement belt you need here:
Kenmore Whispertone Replacement Belt
Oct 28, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Belt keeps breaking.
your brush roller isn't turning unplug the vacuum and see if you can turn the brush roller and also notice if it turns freely or is it stiff,take the roller out and remove strings,carpet strands and hair.if you can pull the ends off clean the ends good and maybe add just a little drop of machine oil on the bearing on the inside the roller where the bearings are.clean the motor shaft.there is probably old burnt rubber on the motor shaft.you can use a pice of emery cloth ,clean it till you see the polished finish .but i would say your problem is in the brush roller and the motor shaft.i hope i was some help to you.can you please leave some feedback
May 03, 2009 | Kenmore Whispertone 29512 Vacuum
Dyson o7 animal pick up problems
Hi.
If your machine is A few years old it may need new brush roller fitted.
To check roller for wear lie machine on the floor & pull back head end as if vaccuming carpet.
Now get A rule or straight edge hold this over brush roller & sole plate oppening.
Now rotate brush slowly by hand the bristles of the brush should just kiss the edge of rule. If ther is a gap you will need toreplace the roller.
http://dysonmanuals.llc.nu/
Jan 11, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Kenmore 116 bagged canister vacuum
something is jamming the brush roller, or the bearings are seised
Aug 08, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Brush is rattling
If this model has a cogged belt, it may need to replaced. When you cath stuff in the roller some times cogs get stripped off of the belt.
May 26, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Need new power brush
Get the number off the power head, it should be on the bottom, then go to Sears.com, click on the parts link, put in the complete model number, a parts list will come up and you can order your part.
Jan 28, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
Kenmore 23313 Whispertone Bagged Canister Vacuum Logo
179 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
