Regarding Infocus projector connection to Sony TV
I ' ve a Infocus Projector and how will I get my TV Channels On it.( Cable TV)
  • 2,237 Answers
The projector does not have an rf connector, so you have to have a modulator that has rf in and composite video and audio out.
Posted on Dec 23, 2009
Where is the projector connection on vaio fit
Insert one end of the VGA cable into your Sony Vaio. This is located on the left side of your computer.
Turn off the Infocus projector before connecting the opposite end of the VGA cable into the projector. The VGA input slot is located in the back of the projector.
Turn on the projector and allow time for it warm up.
Change the video output source on your computer to display through the projector. Press the "Windows" button and then "LCD/CRT" button on your Vaio keyboard to change the display source. On a Sony Vaio, the "LCD/CRT" button is usually "F7."
5
Focus the projector to most effectively display content from your computer. You can manually focus the projector or press the "Auto focus" button on the top of the projector.
Oct 02, 2013 | Sony Computers & Internet
Colour dispaly problem in LP 640
are you useing SVIDEO out from your pcs video card to connect the image to the projector?
have you set your pc to send video out correctly?
It seems your pc is not sending correct video / settings wrong.
Or then there is a problem with the projector. Try a difrent input?
Mar 29, 2008 | InFocus LP 600 Multimedia Projector
Infocus 5000 won't recognize my computer
How about a little more information?
Does the projector turn on?
has it ever worked?
What type of interface (VGA, DVI, HDMI, RCA)
What type of computer (notebook or desktop)
That being said, double check your cable connections and make sure you tell your computer to look for the projector (Dell laptops used to use FN+F8 to switch from laptop to projector). Windows 7 has a menu choice "Connect to Projector". Mac computers - check system preferences and make sure the projector is ON before you plug it into the Mac.
Nov 25, 2012 | InFocus ScreenPlay 5000 Multimedia...
I have an Infocus projector model LP 130 and I need to connect it to my new laptop but do not have the instalattion disc. What do I do?
Just plug it in and see what happens.
A projector is just a display, I've never installed drivers when I've used a projector.
Jul 10, 2011 | InFocus Office Equipment & Supplies
I have a infocus IN35 that at 100 hours burnt out a bulb. Thinking that it was just a bulb problem I bought a new bulb and it lasted 20 minutes. a t.v.repair shop said its probably the ballast that is the...
It is not a common problem. Ballasts rarely need repairs. Have you reset the lamp hours to zero after installing new bulb? If, yes to confirm about ballast please ask the TV repair shop man whether previously he had repaired any DLP projector. There is lot of difference in technology of DLP projector & TV (except DLP Projection TV). The problem could be in the projector main board. The lamp lights after getting Lamp ON signal from the projector main board. As the lamp ignites the ballast sends the signal of Lamp Lit. If the projector board senses that any blower/exhaust fan or colour wheel is not running then it will send a signal to Switch OFF the lamp. If you are tech-savvy then do as follows to check about lamp & ballast. Remove 5 pin connector from the projector. Connect projector to mains supply. Get a 5V DC power supply. Connect +ve to pin 3 & -ve to pin 4 of the ballast connector from this supply. The lamp should light. If it does not light then there is problem in the ballast (if the lamp is new). To give a chance you can check it for your lamp which lasted 20 minutes. Generally ballasts are made by OSRAM. You can get the ballast from OSRAM dealer. You will need the part number for that. Take out the ballast, it is there on it.
Apr 14, 2011 | InFocus IN35 Projector
Hi, I have a display out put problem from
reset the settings to factory default and make sure the resolution matches (native is 1024x768, max is 1280x1024). also activate the port on the computer. if none of that works, swap out the cable (vga-dvi). if all else fails, you'll need to send it in for repair.
Dec 06, 2009 | InFocus LP70+ Multimedia Projector
PS3 to Infocus LP 350 projector using HDMI
M1-DA is a type of DVI connection that produces both analogue and digital signals, the easiest and most quality source cable for you to get is a HDMI to M1-DA cable which is now widely available for purchase.
Infocus should have included this cable in with your projector, but instead the power at bee decided to put a M1-DA to DVI-D cable instead when most visual devices now support HDMI and not DVI nowadays.
Thanks
Sep 04, 2009 | Sony Playstation 3 (PS3) Console
Projector cable
The cable is an InFocus M1-D to VGA cable.
Easy to find inexpensive on eBay.
Aug 05, 2008 | InFocus ScreenPlay 4805 Multimedia...
Infocus X1 Projector
Thank you for your immediate reply. I could solve by myself. The problem was with power supply cable.
With regards
Gomohan
Aug 02, 2008 | Apple InFocus X1 Multimedia Projector
Infocus In24+ driver?
I think projector is do not need driver, i see in the infocus website as long as you connect it to the computer it always display.
please see the details of your infocus here:
http://www.infocus.com/Support/Products/Projectors/IN24.aspx
and also you can download updates firmware to fix some error display.
May this help, best regards, melnavz
Jan 14, 2008 | ASK Proxima Proxima DP2000S Data Video...
96 people viewed this question
jasbo
jasbo
