Question about Echo Garden
Grommet on top of fuel tank leak. where can i buy one
    President:
  • Echo Master
  • 1,545 Answers
There is one here for a low price...but the shipping may be high. Check on Ebay also.
http://www.partstree.com/parts/?lc=echo&mn=SRM-210++S%2FN%3A+S65311001001+-+S65311999999&dn=8336
At least now you have the part number and any decent small engine shop could order one for you.
Posted on Nov 11, 2010
Do i need to replace fuel tank if rubber grommet has come out
cant find a picture of a cox ride on mower fuel tank
should be able to buy a grommet to do the job
mower repair shop first stop
Nov 05, 2016 | Garden
Gas leaks out around the gas cap when trying to trim anything above horizontal level. Replaced the gas cap and it did not fix the problem
most likely not the cap but the grommet around the 2 fuel lines at the top of the fuel tank
easiest fix is a new fuel tank that has the lines already installed
Apr 03, 2016 | Garden
I replaced the fuel lines on my Husqvarna 128LD and they are now leaking, is there a seal or a grommet of some sort to help seal it at the tank? I don't recall any when I pulled it apart.
Some fuel tanks will have a black rubber grommet that have holes for the fuel lines to go into, if your holes are in the tank itself, then no, there's no grommet. And if that's the case ,your lines are not the correct outer diameter. There are multiple sizes of fuel lines. In my shop I have multiple sizes, if you don't have that kinda stock, you're better off either ordering the ones of a parts drawing of your model or simply take your unit and old lines to the closest small engine shop and have them match em up, u actually can just bring the tank with ya.
Aug 20, 2015 | Husqvarna 128LD 28cc 2-Stroke Gas-Powered...
Gas leak at grommet on gas tank where gas lines enter and leave tank
Yes you should be able to replace the rubber tank seal that the fuel line goes through. Be sure to replace the fuel line(s) when you do.
Apr 01, 2014 | Toro 2-Cycle 25.4 cc Straight Shaft Gas...
Gas leak where gas lines enter and leave tank
Also, make sure that the vent for the fuel tank is working. the vent is either on the fuel cap itself or thru a device commonly known as a duck bill valve, so named because of the shape of the valve. All the vent does is allow a slight amount of air to enter the tank while the trimmer is running.
Gas leaking from grommet that goes into the gas tank.model pb-2111.
replace grommet. you may want to replace the fuel lines to you can use echo part number # 90098. its a fuel line kit and it come with all fuel lines, grommet, fuel filter, and vent. its plug and play.
Sep 21, 2011 | Echo Garden
Primer bulb will not remain full. Blower will start but dies when throttle is used. Appears to be leaking air around the grommet to the fuel tank.
you should maybe change grommets/pipes to the fuel tank,also the primer bulb maybe is not working properly,consider changing the primer bulb,rgds
Sep 25, 2010 | Echo Garden
Fuel leak from evap canister
if you continually overfill the gas tank by trying to top off after the pump clicks off you will get raw fuel into the canister. if that is the case you will need to replace the evap canister and filter.
Aug 06, 2009 | Hyundai Motor 2003 Elantra
Gas leaking out where you fill the front tank
You probably have a defective fuel-tank selector valve. Its located on the left frame rail, halfway down. While the vehicle is running, tank"A" is pumping fuel to the engine, while tank "B" is getting the unneeded fuel that is returning from the engine. Thats why it is overflowing.
Jun 18, 2009 | 1990 Ford F150
I have a code p0452 low fuel tank pressure. Is the fuel tank pressure sensor in the tank (fuel pump assembly)? is it changable by itself? Is the sensor bad or is it something else?
yes the pressure sensor in mounted in a rubber grommet on the top of the fuel tank. it could be the sensor but the only way to know for sure is have the dealer do a evaporative emissions fuel tank pressure test, they have the special tools to do this, outside shops do not. Have u tried a new gas cap, they can leak and cause the problem, in fact that is very common.
Mar 07, 2009 | 1997 Oldsmobile Bravada
Open Questions:
Garden Logo
117 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
