Question about Simplicity Sewing Machines
I don't have any presser feet for my machine..where can I get some Someone gave this to me but there were no presser feet..She has died and her daughter gave me the machine but no presser feet.
  • 340 Answers
I find ebay great for small items like this.
http://shop.ebay.com/?_from=R40&_trksid=p5197.m570.l1313&_nkw=simplicity+presser+feet&_sacat=See-All-Categories
I think you'll need just a basic zig zag foot to start with and then can get some more specialised ones later on.
Hope this helps!
Posted on Nov 11, 2010
Presser foot to high?
Are you using the correct presser foot for your machine? Presser feet shanks come in different lengths. There are also a couple of presser feet (like darning or free-motion-quilting feet) that are shorter than standard because they are made to be used with the feed dogs dropped and the fabric can be manually manipulated. If it's the correct foot, then the machine probably needs to be adjusted.
https://www.sewingpartsonline.com/sewing-machine-presser-feet.aspx?sort.ss_cat_sort=desc&index=1
Aug 29, 2018 | Sewing Machines
Compatibility of sewing machine feet
If the width of both machines' presser feet are the same, the only thing you need to worry about is the shank and the form of attachment the shank has to the machine.
According to this, the feet may be compatible:
Generic Presser Feet Accessories
You'll need to verify that the shanks are the same between both machines. Perhaps the Juki dealer can tell you if the feet are compatible.
However, if the presser feet are not compatible with both machines, you can purchase an snap-on adapter shank for the Juki and pick up a kit of snap-on presser feet (these are generic, not Juki made) and you will be set to go for very little outlay of finances. In addition, you could pick up a snap-on adapter for the Husqvarna and you would be able to use the snap-on feet on both machines (in case you don't have some feet for your existing machine).
32PCS Sewing Machine Foot Feet Presser For Brother Janome Yokoyama Juki UL
Oct 07, 2016 | Husqvarna Sewing Machines
Presser foot wont connect
It is most likely the presser foot you are trying to install was not made for your machine. There are so many machines available and most of those machines have their own presser feet, which are not interchangeable. Unfortunately, even a Singer presser foot is not interchangeable with other Singers. Some have screw attachments, others have lever attachments, some have long shanks, others have short, some are straight, others are slanted. You need to figure out what style presser foot your machine takes and then search for either the presser feet that fit or a shank adapter that you can then use snap-on feet (kits are available on eBay).
http://www.sewingpartsonline.com/sewing-machine-presser-feet.aspx
Sewing Machine Feet eBay
Jul 17, 2016 | Sewing Machines
Can the presser foot be raised slightly on pfaff tiptronic 2030 to facilitate free motion quilting? There is not enough clearance with feed dogs down to freely move material to quilt. Thank you.
You need a special foot for free motion quilting--it is slightly shorter in height than a regular presser foot, which essentially provides space between the presser foot and the needle plate to manually move the fabric. Sometimes machines came with a standard darning foot accessory. Your Pfaff dealer probably has at least one style in stock. But there are other specialty feet you can probably use, ie Big Foot, clear free motion foot, C-shaped, oval, etc. You can also purchase a shank adapter (verify it is the correct shank for your machine) and use it with a kit of snap-on presser feet so you can have a variety of presser feet for different functions.
Pfaff Presser Feet
Pfaff Big Foot Free Motion Quilting Foot
Pfaff Free Motion Guide Presser Foot
Pfaff Free Motion Open Toe Quilting Foot
http://www.sewingpartsonline.com/snap-on-sewing-machine-presser-feet.aspx
May 07, 2016 | PfaFF Sewing Machines
I have a Sears Kenmore sewing machine I want to get a 1/4 in presser foot for it, is there one and where would I get it/
You first need to determine which shank the presser foot uses on your machine. You can compare your shank (current presser foot) with these photos to see which one your machine uses.
NOTE: If you purchase a snap-on presser foot, you will also have to buy a "shank adapter" that will attach the presser foot to the needlebar. Here are some pictures of snap-on adapters:
Kenmore sewing machine snap on adapter Google Search
However, you will still need to make sure to buy the correct adapter for your machine. The GREAT thing about buying a snap-on adapter is you can add a lot of presser feet to your sewing machine accessories because you can purchase additional snap-on presser feet or even a complete set of snap-on feet that will all work with your adapter and your machine!!!
Kenmore Presser Feet eBay
You will just snap one foot off and snap another on!!! Great idea!!!
OR--you can take your current presser foot along with the make & model of your machine and check with the local sewing repair shops to see if they have what you need.
FYI, once you know what shank your machine has, you can probably also find other specialty feet for your machine, ie walking foot, free-motion foot, etc.
Jan 17, 2016 | Kenmore Sewing Machines
How can I find accessories for an old machine?
Sewing shops are loaded with this stuff. You can order online too. You'll need the make & model number. Do a little research, I think Kenmores are simply repackaged Singers.
Aug 05, 2015 | Kenmore Sewing Machines
Where can i get a presser foot for a Janome 1017
Sep 18, 2012 | Janome Harmony 1017 Sewing Machine
Elna carina snap on presser feet
Yes, any low shank should work. If it doesn't you can always regift it to someone.
Oct 27, 2017 | Sewing Machines
Purchasing Presser Feet
Find out wether or not your machine uses low shank or slant shank presser feet . If you are not sure take your regular presser foot to any sewing shop and they will tell you quickly what kind of presser feet you need for your machine
Aug 24, 2009 | White Sewing 1418 Mechanical Sewing...
Sewing Machines Logo
43 people viewed this question
Top Simplicity Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Steve Allison
Steve Allison
Are you a Simplicity Sewing Machine Expert? Answer questions, earn points and help others
