Question about Food Processors
Cuisinart 14 cup Food Processor, Limited Edition Metal, purchased approx. Sept 8, 2008, Sears item #00821455000, Mfr. model #MP-14, $349.99........is causing outlet re-set button to shut power off. Help! email address: lrstone@prodigy.net
    Genius:
  • Food Processors Master
  • 1,280 Answers
Hi, you are probably just overloading that circuit. Try taking your food processor into a room of the house where you have no other appliances running such as a bedroom and plug it in there. Turn it on and if the outlet reset button doesn't pop there then that means you have to many appliances pulling wattage in your kitchen and you need to unplug them or just move your food processor to a different circuit in the house. Sometimes if you have an overhead light fixture with a lot of bulbs that can be the source of the problem (the culprit!) and you can shut off that big light too and that will help. If this helps please vote/rank/testimonial would be appreciated. ...thanks!
Posted on Nov 11, 2010
Do you have an online user manual for the Cuisinart Limited Edition Metal MP14 Food Processor? If yes, where can I find it?
I believe this pdf is the user manual. It is a pdf and is the
INSTRUCTION AND
RECIPE BOOKLET
http://www.cuisinart.com/share/pdf/manuals/mp-14n.pdf
Please let me know if this is what you were looking for.
Mar 28, 2010 | Cuisinart Limited Edition Metal MP14 Food...
I have a Cuisinart 14 cup food processor which will not turn on
Hi-
We have a Cuisinart and these tools are very rugged- so I doubt that the motor is bad. My only suggestion would be to make sure that the safety catch is being actuated when you click the cover clockwise to secure the mixing chamber. There is a hole in the housing that the acuator pin sticks into to disengage the safety switch. Perhaps the switch is not being pressed off.
Hope this helps,
Jeff
Oct 28, 2009 | Cuisinart DLC-7SFP Pro Food Processor
My Cuisinart food processor won't start!
Make sure work bowl handle is locked in so that the handle is facing the front of the processor, and that the feed tube and metal rod of the pusher are facing the back of the processor. If it is assembled in this way and still won't turn on, call Cuisinart for assistance, as you may have concelaed damage to one of the work bowl parts. 1-800-726-0190
Jul 27, 2009 | Cuisinart DFP-14BC Custom Food Processor
Cuisinart Processor workbowl lid fitting
Cuisinart DCL-7 replacement work bowl lid is cuisinart dlc-017bgtx work bowl lid fitting with large feed tube.
Jun 05, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
CUISINART FOOD PROCESSOR MP14 WON'T TURN ON ..NOT EVEN THE RED LI
You should not have taken it apart - that unit has a fantastic warranty. Call Cuisinart and get it repaired - don't even hint that you took it apart, or your warranty is void.
jo82 - here is how to test your motor to be sure -
Remove the workbowl completely, plug the base into the wall outlet, turn the machine on, take a pen and press in the little black/dark gray button on top of the base. If you hear spinning, then the motor is fine.
If the motor is fine, put the work bowl back in place with handle facing fromt of machine, lid lined up with bowl, and pusher sleeve with metal element lined up with front of machine.
If the motor test failed, call Cuisinart and get the unit repaired.
-Tha Mp3 Doctor
Feb 17, 2009 | Cuisinart Limited Edition Metal MP14 Food...
I can't get the blades on the processor. there is a holder that somehow snaps into the blades before they are put on the processor
The regular chopping blade requires a stem adapter. The other blades require the detachable stem. I would double-check the user manaul to get a visual on it. Cuisinart food processors are great, but they are also the hardest to assemble.
-Tha Mp3 Doctor
Jul 19, 2008 | Cuisinart Limited Edition Metal MP14 Food...
Plastic bowl of Cuisinart DLC-7P will no longer lock in place
Buy replacement plastic bowl of Cuisinart DLC-7P is Cuisinart DLC-005AGTX-1 work bowl 14 cup.
Jul 15, 2008 | Cuisinart DLC-5 Food Processor
CAN'T GET TOP ON TO OPERATE AND CANNOT FIND CD FOR 14 CUP CUISINART FOOD PROCESSOR
Do these directions in reverse - (the how-to DVD is generic - not for each individual Cuisinart food processor):
Removing a Cuisinart Food Processor Work Bowl
You have to remove the pusher first by twisting it off. Then press the sides of the pusher sleeve inward and slide the sleeve up and out of place. Then twist off the lid - all twisting on these food processors works either clockwise or counterlcokwise - not both. Then twist the work bowl to the left (clockwise). Voila!
-Tha Mp3 Doctor
Apr 13, 2008 | Cuisinart Limited Edition Metal MP14 Food...
Cuisinart MP14 Will Not Turn On
Cuisinart Food Processors – Motor Test
First, do a motor test by removing the work bowl completely and using a pen to press in the grey button on top of the base (with the food processor turned on of course), toward the back. If the processor spins, the motor is still good. At that point, I would inspect the work bowl pieces, lid, pusher assembly, etc for cracks/damage. If all appears well, insert ALL the pieces back into place and try again. If even one piece is out of place, the processor will not spin.
If it no longer spins, the motor has a problem. (This one has a 20-year motor warranty)
-Tha Mp3 Doctor
Oct 30, 2007 | Cuisinart Limited Edition Metal MP14 Food...
Food Processors Logo
Top Food Processors Experts
eyecam
Are you a Food Processor Expert? Answer questions, earn points and help others
